Old 06-10-2009, 11:46 AM   #1
miata_racer
Member#: 109358
2007 STI
Default BSP legal pistons
Are there any? I have a friend who needs to replace hers in here 07. And since they are getting replaced...why not put in something that will hold up better?
Looking for something forged of course. Not really caring if it's .020 or stock bore either. Just strong and reliable.
miata_racer is offline   Reply With Quote
Old 06-11-2009, 09:14 AM   #2
neilschelly
Member#: 94902
1988 911 Carrera 3.2
Subaru stocks 0.010" and 0.020" standard overbore pistons (or at least they do for the EJ22). They were really cheap for my car too, only $45 or so apiece.
I doubt you'll find much of an aftermarket that would make 0.040" over pistons and be sure they have the same or greater weight as stock, but STis do get a lot more aftermarket attention. At the very least, they won't be as good a value as the Subaru ones.
-N
neilschelly is offline   Reply With Quote
Old 06-14-2009, 11:56 PM   #3
miata_racer
Member#: 109358
2007 STI
hmmmm,....problem is...the pistons and rings need replacing because of the running too lean with the cobb program on the 07. I was hoping I could find something forged that might hold up better.
Old 06-23-2009, 11:27 PM   #4
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Forged would not be BSP legal.
bcblues is online now   Reply With Quote
Old 06-24-2009, 07:22 AM   #5
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
Yes they would. You'd probably have to have them made to insure dimensions/dome, ring sequence, and weight were identical. Most aftermarket ones change some or all of these things.
Read 15.10 S.
To the OP I would just call Mahle, Weisco, etc...talk to them.
mccanixx is offline   Reply With Quote
Old 06-24-2009, 12:49 PM   #6
bcblues
Member#: 17256
04 STi
Yeah, you are correct. Since there are no BSP legal forged pistons (to my knowledge) available as off-the-shelf parts. I assumed this precluded using them. A clear case of me thinking inside the box.
FS : STi intake manifold and throttle body jcovey2.5 Engine/Power/Exhaust 173 12-05-2011 09:38 PM
04 sti with 5x114.3 hub swap - BSP legal? nhat Autocross 6 04-03-2010 07:33 PM
heat reflective tape legal in STU or BSP? Mojambo Autocross 5 03-23-2010 04:22 PM
AutoX Gurus - Aftermarket pistons ok in BSP? T-WRX Motorsports 11 01-19-2009 08:21 PM
Legality of STi Limited Trunk in BSP.. crystalhelix Motorsports 54 12-13-2006 12:24 PM
