Welcome to the North American Subaru Impreza Owners Club Tuesday April 28, 2015
Old 06-10-2009, 05:36 PM   #1
Jrags87
Member#: 119324
2005 Impreza WRX STI
Crystal Grey Metallic
Default Bridgestone Potenza RE-11
I tried searching and found nothing ..
Has anyone tried a set of the new potenza re-11's?
Im curious to see how they compare to other summer tires.
Jrags87 is offline   Reply With Quote
Old 06-10-2009, 05:46 PM   #2
yzer
Member#: 89291
03 WRXSedan+SSR/XS
mbp
yzer is offline   Reply With Quote
Old 06-10-2009, 06:05 PM   #3
tuskenraider
Member#: 65699
15 WRX
WR Blue
I have both, but on different cars, so not an equal comparison. The RE-11's seem to be the better rain tire and provide more grip in cooler weather(50's). The warmer it gets, the better the Kumho's feel. For the price the XS great, but just on all round performance I'd go with the RE-11.
tuskenraider is offline   Reply With Quote
Old 06-10-2009, 06:15 PM   #4
Jrags87
Member#: 119324
Interesting ... thanks for the input
I'm currently running the potenza re-070 (stock for STI).
Would there be any noticable improvement running the re-11s over the re-070s, (stiffer sidewall, better grip, ect?)
Also, would I benefit from going with a wider tire on the bbs wheels; something more than 225? What is the point of diminishing returns?
I use my car as a daily driver, with light track use.
Maximum grip is what I'm after here ...
Old 06-10-2009, 08:50 PM   #5
yzer
Member#: 89291
03 WRXSedan+SSR/XS
mbp
I drive the XS but haven't driven the RE-11 so I'm relying on the shootouts for comparison. GRM said the XS did not have the stiffest sidewall but overall design proved the "stiff sidewall" quality was not essential for performance. For GRM, XS outperformed RE-11 in aggressive driving. Designing past heavy sidewalls also made the XS lighter in weight.
Some of the Tire Rack drivers got their best times with the XS. Luke said different driving styles may account for some drivers doing better with the XS.
In my own driving I felt XS was not quite as good on the wet as the MX I had before, but a lot more dry grip with XS.
This all seems to bear out the theory that XS is tops in dry grip but not a standout as a rain tire.
Driving XS is the 50's seemed fine for me. The tire warmed up after couple of minutes and had a lot more grip than anyone behind me.
With XS ratings so close to RE-11 in shootouts so far, price is a valid comparison.
Old 06-11-2009, 08:37 PM   #6
tuskenraider
Member#: 65699
15 WRX
WR Blue
I agree they certainly have great grip at those temps with a little warmup, just that the RE-11's are good to go colder.
The 070 is about the stiffest sidewall you can get in a performance street tire, so anything else most likely will feel less crisp. The RE-11 has a softer sidewall than the RE01-R, but certainly isn't "soft". All have more grip than the 070. The XS' will handle heat better for sure, so for track use, that'd be my pick then. As far as size, you could certainly go with a 245/40/17 on the 8" BBS'. Keep in mind in doing so you will certainly give up some crispness by squeezing a bigger tire on the rim, but you'll have more grip.
Old 06-11-2009, 09:22 PM   #7
STi-MAN
Member#: 70252
05 STI
blue
how are the side walls on the kumhos? thats the thing i hated most on the mx.
STi-MAN is offline   Reply With Quote
Old 06-11-2009, 11:00 PM   #8
tuskenraider
Member#: 65699
15 WRX
WR Blue
Sidewalls don't feel bad at all, but there is a reason they're a lighter tire. I'm running 215/40/17's on a 6.5" rims for my Mazda3 and I don't find them sloppy by any means doing autox with 44 lbs. up front in them, running 48 in rear for some rotation. If your sensitive to sidewall feel, I suppose you should expect them to be similar to other Kumho products and additionally, more grip means more flex.
Fs:chicago: Brand New Set of Bridgestone Potenza Re-11 Tires (245/40R 18); Warranty stigette Wheels/Tires 3 03-04-2010 12:07 PM
FS SoCal: Bridgestone Potenza RE-11 255/35/18 DiscoWagon SCIC Private Classifieds 10 09-09-2009 02:32 AM
FS SoCal: Bridgestone Potenza RE-11 255/35/18 DiscoWagon Wheels/Tires 1 09-09-2009 02:13 AM
Bridgestone Potenza RE-11 Tire Brings Formula One Inspiration To The Street AVANTI R5 Non-Subaru News & Rumors 11 03-14-2009 09:46 PM
Bridgestone Potenza RE-010's dch General Forum Archive 13 09-13-2000 07:05 PM
