Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 06-09-2009, 12:11 AM   #1
Sb22284
Member#: 168386
Default sold !!!
sold !!!
Sb22284 is offline   Reply With Quote
Old 06-09-2009, 12:30 AM   #2
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
it is the tmic hitting the hood, i have the same problem which is why i am going FMIC. it is only like that because of the bigger turbo, if u or i had a stock turbo, it would fit nice..
Boxer112 is offline   Reply With Quote
Old 06-09-2009, 08:37 AM   #3
my94saleen
Member#: 97791
2006 sti
wr blue
nice set-up.shouldnt there be a lot more torque(like about 50).is it because of the tmic?only reason i ask is i just got my 06 tunned w/ the atp gt3076r bolt-on and made 386whp and 375lb tq (stock is 201 whp 200 lb tq)at a.m.r. on 93oct at 23 psi.they said there was a lot more power available but im still running stock internals.
my94saleen is offline   Reply With Quote
Old 06-09-2009, 08:44 AM   #4
chlnOrSlpn?
Member#: 97785
2015 WRB STi Limited
EFI Logics/CTSUBIE
Your bolt on 3076 will make power easier on pump. The true GT3076 shines on race fuel or meth. P&L's dyno tends to always read lower than others I believe.
Good results to the OP.
chlnOrSlpn? is offline   Reply With Quote
Old 06-09-2009, 08:55 AM   #5
my94saleen
Member#: 97791
2006 sti
wr blue
i didnt know that. on amr's dyno stock sti's put down 201whp 200 lb tq
Old 06-09-2009, 09:33 AM   #6
LittleBlueGT
Member#: 96204
2013 STI GR
Originally Posted by Sb22284 View Post
Only downside is the car will idle like crap when you first start it
Because of the TGV deletes?
LittleBlueGT is offline   Reply With Quote
Old 06-09-2009, 09:37 AM   #7
ASHRAF
Member#: 193921
2010 Impreza WRX STi
more info on this please...
sweet numbers, now all you need is meth injection
ASHRAF is offline   Reply With Quote
Old 06-09-2009, 10:36 AM   #8
chlnOrSlpn?
Member#: 97785
EFI Logics/CTSUBIE
From what I've read up on and seen typically bolt on stock location turbos will yield better pump gas results than rotated kits on stock blocks.
Old 06-09-2009, 10:55 AM   #9
my94saleen
Member#: 97791
2006 sti
wr blue
wow, i honestly didint know that.so if your mainly gonna use pump gas for d.d. like most people do ( unless your loaded$$$$ and can afford race gas for d.d. or dont want to use meth) your better of with a stock mount?
Old 06-09-2009, 11:01 AM   #10
LittleBlueGT
Member#: 96204
2013 STI GR
Deleting the TGVs does nothing for cold starts, hot starts, any kind of starts.
I took out my TGVs and my car starts just fine when it is -35 out.
They are only there for cold start emissions.
Old 06-09-2009, 11:29 AM   #11
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
Good numbers.
Running it @ the Shootout?
zeropsi is offline   Reply With Quote
Old 06-09-2009, 01:05 PM   #12
Sb22284
Member#: 168386
sold !!!
Old 06-09-2009, 01:08 PM   #13
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
Nice!
Sounds like your power band is almost identical to mine except yours is on 93 and mine is on 100.
RexFTW is offline   Reply With Quote
Old 06-09-2009, 01:47 PM   #14
Prevent
Member#: 149114
SB, you need to give me a ride.
Prevent is offline   Reply With Quote
Old 06-09-2009, 02:05 PM   #15
chlnOrSlpn?
Member#: 97785
EFI Logics/CTSUBIE
Well a rotated turbo can be just as fun on a DD as a stock location turbo. They just don't really "Shine" on pump fuel and stock blocks. They can still achieve good power levels and leave a lot of room on the table. I loved my Perrin 30R on my DD STi, it all depends on the turbo you choose for your application. You don't need to run Race fuel or Meth to enjoy a rotated turbo kit, you just won't reach it's full potential without it, but it's best to have everything built to hold the power and maintain longevity.
Another thing to consider is every dyno reads different and they are just used as a tuning tool. The ATP turbo probably has to work harder to achieve the same power as a GT30R at the same boost level because it is restricted in flow in certain areas.
But I'm no expert, just my thoughts.
Old 06-09-2009, 02:14 PM   #16
Sb22284
Member#: 168386
Exactly what he said. I have no doubt there is room to grow. With what you have to spend on this kit to get where i am its tough to add in the price of a rebuild and clutch. I could buy a new cobalt for that price
Old 06-09-2009, 05:31 PM   #17
chlnOrSlpn?
Member#: 97785
EFI Logics/CTSUBIE
that is funny !
Old 06-11-2009, 12:33 AM   #18
Sb22284
Member#: 168386
For what its worth, i get 16.5 MPG sitting in Chicago traffic... lol
Old 06-11-2009, 12:45 AM   #19
woodys77
Member#: 192147
2007 STI EfiLogics
422whp 421wtq fpgreen
. Only downside is the car will idle like crap when you first start it
if you have a big maf its probably your culprit not the tgv delete.
woodys77 is offline   Reply With Quote
Old 06-11-2009, 02:24 AM   #20
zeropsi
Member#: 175453
AE86 GT-S coupe
Very good point.
I can't wait for the MWSOC shootout, between this car and a few of the other local cars, it's going to be a whole lot of fast times this year.
Old 06-11-2009, 07:54 AM   #21
MattPersman
Member#: 139385
so wait poor fuel economy, TMIC hitting something driving you crazy and poor idling cold starts = great service and happiness?
I thought most wanted the opposite, decent fuel economy, no noises from ill-fitting parts and good smooth tunes from $200/hour tuners?
not hating, IMO you shouldn't have to compromise this much, its not an all out race car its still an everyday street car
MattPersman is offline   Reply With Quote
Old 06-11-2009, 02:03 PM   #22
Sb22284
Member#: 168386
The TMIC problem is probably something i can work out. The cold start issue has been getting better over time
Im still annoyed with the power steering noises i get for about 1 mile. Again, something that will work itself out over the next few weeks
Old 06-11-2009, 02:18 PM   #23
c'dalerider
Member#: 92388
04 WRX, 06 STI
wrb x 2,900awhp combo
+1 on poor fuel economy, with any bigger injectors realy.
+1 , i expected better tq #s on an STi (cam timing), but the 07 maps are difficult and the tuner there is tops so i dont know.
+1, 850 injectors are not very good on cold start up and idle poor, especially PE's! DW's are much better for those issues. My car idles to wrong for me. Im changing things up asap.
i love my gt 30r kit on a DD 06 STI. Im tuned to 21.5 psi with meth and 418/403, high reading dyno. Boost almost comes on to quick and she just stops 'pulling' at 55k rpm..sortof...ha. Great powerban.
c'dalerider is offline   Reply With Quote
Old 06-11-2009, 02:28 PM   #24
STimo
Member#: 110273
450 whp 30R STI
11.3@123, 10's a commin'
Odd, i get ~320 miles to a tank of gas with my PE850's and 30R. I cruise to vegas from orange county which is ~260 miles, and im still at ~ 1/4 tank when i arrive. Also i've never had a problem with cold starts or idle with my PE850's, in fact they idle great! IMO tuning has everything to do with these two issues..
STimo is offline   Reply With Quote
Old 06-11-2009, 02:48 PM   #25
Sb22284
Member#: 168386
320 damn...
I might be that i did a reflash on my way to work after i threw the code. Coming back home was 2 hours of stop and go in Chicago traffic. I'll have new numbers this weekend from the shootout
FS : 07 sti springs, 04 wrx springs shsjr89 SCIC Private Classifieds 8 02-16-2012 07:26 AM
FS : 02-07 STI Axleback muffler ai42 TXIC Private Classifieds 23 08-17-2010 10:53 AM
07 sti tranny scoobydoo914 Private 'Wanted' Classifieds 0 06-04-2010 07:14 PM
FS : FL 04-07 Sti Blitz throttle controller Imprezsti5 Engine/Power/Exhaust 5 06-03-2010 06:27 PM
FS/T: Roof Vane Spoiler, 07 STI headlight, 07 STi grill, 07 STI trunk and wings SD marrenr813 SCIC Private Classifieds 42 09-28-2007 11:59 AM
