Old 10-11-2002, 01:52 AM   #26
axis
Member#: 13382
06 STi
WRB/Gold
better than buying one
axis is offline   Reply With Quote
Old 10-11-2002, 01:55 AM   #27
axis
Member#: 13382
06 STi
WRB/Gold
still waiting for my EGT gauge though...
Old 10-11-2002, 01:58 AM   #28
axis
Member#: 13382
06 STi
WRB/Gold
the beginning
Old 10-11-2002, 02:09 AM   #29
axis
Member#: 13382
06 STi
WRB/Gold
more
Old 10-11-2002, 02:13 AM   #30
axis
Member#: 13382
06 STi
WRB/Gold
autometer makes one really similar but it's been on backorder through my vendors since spring with no ETA so I decided to make my own. A few imperfections, but for the price you can't beat it.
Dan
Old 10-11-2002, 02:41 AM   #31
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Nice!
Can you please describe the process of how you did it. Thanks.
-Alex
Imprezer is offline   Reply With Quote
Old 10-11-2002, 03:01 AM   #32
axis
Member#: 13382
06 STi
WRB/Gold
first, I planned out where I wanted the gauges to be, then I measured it out so that both sides would be even. Next, I took a dremel to the factory bezel and went to town. I cut just enough so that the gauges would have proper support. Then comes the bondo. I used bondo to build up the outter sides to determine the degree that the gauges would be angled in towards me. After that, I used fiberglass strips to make the "cup" for the pods. Three layers later (I used three just to be on the safe side for structural support) I began to build up the inside of the bezel so that everything would be smooth. The rest is just hours upon hours of sanding, sanding, sanding and more sanding.
Just to let everyone know, this was my fist attempt at fiberglassing and bondo work and it took me three weeks to complete ( a few hours here and there about every day). So it is very time consuming.
Dan
Old 10-11-2002, 12:47 PM   #33
skibri
Member#: 20787
2002 wrx wagon txs2+
wr blue
axis
that is the coolest gauge set up i have seen, i wish i had the balls to try something like that.
Where did you run the wires so that they were not really visable?
great work
skibri is offline   Reply With Quote
Old 10-11-2002, 12:58 PM   #34
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
Axis,
Very very nice!
Matt
mattjk is offline   Reply With Quote
Old 10-11-2002, 03:18 PM   #35
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
Axis, that is a nice setup.
Does anyone have the part number to guage cluster, to try?
Jay
illmatic is offline   Reply With Quote
Old 10-11-2002, 07:47 PM   #36
axis
Member#: 13382
06 STi
WRB/Gold
Originally posted by skibri
axis
great work
the wires are run behind the dash and go to the gauge controller which I mounted in the center console. The controll unit has features like peak-hold, peak warning and playback if I want to record what is happening at a certain time.
Dan
Old 10-11-2002, 08:30 PM   #37
rayder
Member#: 14535
02 Impreza WRX
the blank spot is now filled with the new Blitz Power Meter SJ
rayder is offline   Reply With Quote
Old 10-11-2002, 10:35 PM   #38
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
wow..
Blitz DC gauges...yummy...
very nice!
anyone with greddy peak/hold gauges?
KIMUTAKU is offline   Reply With Quote
Old 10-11-2002, 10:36 PM   #39
TonyWRX
Member#: 21146
Question
rayder those gauges look hot like that. There's no gauge pod right?? Anymore pics?
looks good
TonyWRX is offline   Reply With Quote
Old 10-13-2002, 02:58 PM   #40
rayder
Member#: 14535
02 Impreza WRX
they attach with suction cups.. live unit hidden under dash. it's great.
Old 10-14-2002, 03:33 AM   #41
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
Default Something different
I put mine down here.
khail19 is offline   Reply With Quote
Old 10-16-2002, 12:14 AM   #42
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
My Greddy 52mm electronic gauges (boost, EGT, oil pressure). Modified OEM pod and faceplate from Derres.
Zola is offline   Reply With Quote
Old 10-16-2002, 12:17 AM   #43
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
And a night shot...sorry it's a bit blurry, my hands weren't very steady taking this picture!
(also the EGT isn't hooked up yet since I haven't bought an uppipe...will do those at the same time one of these days)
Old 10-16-2002, 09:38 AM   #44
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
It's from my old GC8, but still turned out nice!
click the pics to see a larger version.
Thanks - Jon
omahasubaru is offline   Reply With Quote
Old 10-16-2002, 09:47 AM   #45
imprezive one
Member#: 16906
2k3 wrx wagon
omahasubaru that pod is sweet! I'm trying to design something along those lines for the WRX because I want to put a flip out video screen in the center area where the clock goes, but I want it to be hidden under a flip up defi pod. I dunno if it's possible but it was just an idea that I had. Did you make that pod yourself or did you buy it somewhere?
imprezive one is offline   Reply With Quote
Old 10-16-2002, 09:56 AM   #46
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
Originally posted by GDB
those are phatty guages man, I'm definitely going with Defi BF guages for mine. I just can't decide if I only want 3, or if I want to get more.....hehehe......but what made you all decide what guages to get?
I'm thinking Oil Pressure, Boost, and EGT.....
ScreaminFast is offline   Reply With Quote
Old 10-16-2002, 10:36 AM   #47
scottm1978
Member#: 13284
Originally posted by jetskizero
Defi gauges in stock pod -
jetskizero are those the 60mm gauges.
scottm1978 is offline   Reply With Quote
Old 10-16-2002, 02:16 PM   #48
mdot
Member#: 15884
2002 wrx wagon
i bolted mine to the bezel too
mdot is offline   Reply With Quote
Old 10-16-2002, 06:24 PM   #49
WRX Power
Member#: 7142
Here's mine. Greddy gauges with stock pod and Derres mask.
WRX Power is offline   Reply With Quote
Old 10-16-2002, 09:22 PM   #50
extraducksauce
Member#: 18555
SWRT BLUE (what else?)
here's mine:
Autometer a-pillar dual gauge set up, oil pressure and boost.
peace
eds
extraducksauce is offline   Reply With Quote
Post Pics Of Your Navigation Setup ( Eclipse , N1 ,N2 .... ) minx1225 Interior & Exterior Modification 1 09-06-2005 01:43 AM
Post pics of your FMIC setup KitchenerWRX Member's Car Gallery 2 08-30-2005 01:27 PM
Post pics of your gauges lit up... MomoWRX Electrical & Lighting 22 12-11-2004 10:21 PM
post pics of your gauge clusters/bezels 03wrx 03twrx South East Region Forum 5 11-13-2004 09:28 PM
Post Pics of your gauges and cluster shots! Leo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 02-19-2004 10:16 AM
