Old 06-11-2009, 11:29 PM   #1
04slprwgn
Member#: 201075
2004 WRX Wagon
Default hybrid wagon
Figured i would post up.. nothing too incredibly special...
2.5 block
18g
650cc injectors
catted dp
intake
protune by Scott Siegel at TopSpeed (18psi)
made 296hp and 329tq on the stock wrx intercooler
stock intercooler couldn't take anything past 18 psi... planning on doing a top mount and few other goodies...
04slprwgn is offline   Reply With Quote
Old 06-11-2009, 11:40 PM   #2
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
powerband looks really good for the amount of supporting mods you have. its just funny that you have a whole bottom end mod but a stock top mount.
ownnij is offline   Reply With Quote
Old 06-11-2009, 11:44 PM   #3
04slprwgn
Member#: 201075
2004 WRX Wagon
well i decided to have my tranny redone since i had some syncro's going bad and was going to putting alot more through it, basically pushing the 5spd to the limits... so the intercooler had to wait...
Old 06-11-2009, 11:51 PM   #4
mulva
Member#: 62539
2002 WRX Wagon
2009 Impreza OBS
Which which 18G did you go with and was there any head work done? I'm about to bite the bullet on a Blouch TD05H-18G 8cm for my hybrid with stock 205 heads. My car is just driven back and forth to autox and this looks like the ticket!
-Tom
mulva is offline   Reply With Quote
Old 06-11-2009, 11:54 PM   #5
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
The thing is, I too ran the stock TMIC with a hybrid setup (VF39, 8.8:1 CR). It ran great, but then I switched to FMIC holy hell was it faster. It was a huge difference. Lag measure by rpm was about the same, throttle response was only a hair slower, but power was WAY up. I wouldn't be surpised if you pick up 20whp tuned.
Nice numbers.
TypeC is offline   Reply With Quote
Old 06-11-2009, 11:57 PM   #6
04slprwgn
Member#: 201075
2004 WRX Wagon
with a fmic or tp mount on the exact set up i have right now i would push about 350 wheel because i would be able to up the boost... trust me i cant wait to upgrade and retune
Old 06-12-2009, 12:03 AM   #7
04slprwgn
Member#: 201075
2004 WRX Wagon
-Tom
deadbolt 18g stock heads.... basically bolts beside the supporting mods
Old 06-12-2009, 12:11 AM   #8
Midwestrider
Member#: 42955
2004 Bone Stock..
What is your transmission - 5spd with upgraded gears or 6spd swap?
Have to love all that torque!
Nice setup btw.
Midwestrider is offline   Reply With Quote
Old 06-12-2009, 12:23 AM   #9
04slprwgn
Member#: 201075
2004 WRX Wagon
Nice setup btw.
thanks
5spd with all new oem parts... i plan on doing the 6spd swap later on
Old 06-18-2009, 01:56 PM   #10
compressro
Member#: 193383
2004 WRX WRB
97 Impreza Wagon
Very nice numbers. I'm going to be running pretty much the same set up accept I have an AMR top mount and a couple of other small things. Can't wait to do my swap, only 2 more weeks! Same as you though, stock trans =( .
compressro is offline   Reply With Quote
Old 06-18-2009, 02:03 PM   #11
04slprwgn
Member#: 201075
2004 WRX Wagon
your trans will hold up as long as you are not harsh with it... i never launched my car or left hard and try not to catch second very hard either... mine has held up with no problem... also if you put a clutch in that will slip it will help save your tranny... because the clutch will slip before it can really put too much stress on anything
Old 06-18-2009, 02:06 PM   #12
compressro
Member#: 193383
2004 WRX WRB
97 Impreza Wagon
Yeah I'm hoping for the best with this tranny to last me some time. I never launch mine either and try to only get on it once in second.
Old 06-18-2009, 02:08 PM   #13
04slprwgn
Member#: 201075
2004 WRX Wagon
oh i just realized you have an 02 with the even weaker tranny... i might suggest tuning the car to see what you can get out of it and then detune it some so you do not run so much torque on that tranny... i know the 02 is suppose to be weaker
Old 06-18-2009, 02:40 PM   #14
Gixxer1K
Member#: 81631
Lightweight flywheel helps also to reduce shock loading
Gixxer1K is offline   Reply With Quote
Old 06-18-2009, 02:43 PM   #15
04slprwgn
Member#: 201075
2004 WRX Wagon
have that
Old 06-18-2009, 03:02 PM   #16
compressro
Member#: 193383
2004 WRX WRB
97 Impreza Wagon
Yep 02' tranny. I'm going to do a more conservative tune because it is my daily driver.
Thanks for the info, haven't considered that yet.
Old 06-18-2009, 05:26 PM   #17
csmithwrx'05
Member#: 171293
'05 WRX Hybrid
EJ257 w/Blouch 18G 8cm^2
Looks good man. That stock TMIC is definitely holding your back. The graph looks somewhat similar to mine. My setup is very similar to yours except I am running 16PSI, stock BCS, Perrin TMIC and 264/264 cams (moves the power band to the right a bit, but holds on much nicer in the higher rpms). I am keeping the boost low for the tranny's sake too. Can't wait until get a new job and can afford to grenade my 5-speed (on unemployment right now), then I will get a Grimmspeed BCS and go in for a retune at like 20PSI or so.
My dyno chart for comparision if anyone is interested: http://i395.photobucket.com/albums/p...AN2927_000.jpg
csmithwrx'05 is offline   Reply With Quote
Old 06-18-2009, 06:07 PM   #18
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
Be careful of what clutch you use too. A full face is best for easy shock loading. Any 'puck' clutch (6-puck, 3-puck etc.) will be much more harsh and sudden, and increase shock loading.
zeropsi is offline   Reply With Quote
04 2.5l Hybrid wagon 8cm 18G - 326whp Eskram Proven Power Bragging 20 10-24-2008 12:47 PM
Hybrid Wagon Build using stock Wrx heads on Sti 2.5L block wrxwagon253 Built Motor Discussion 30 02-26-2008 05:22 PM
Hybrid Wagon :) Spec V to Wagon Member's Car Gallery 32 11-24-2007 08:54 AM
OR, 02 2.5 Hybrid Wagon. Highbred Private Vehicle 'For Sale' Classifieds 80 08-28-2007 06:40 PM
Axis hybrid wagon slurppin GT30 air... ka mano Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 12-21-2005 06:19 PM
