Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 06-16-2009, 09:18 AM   #1
xaznxeclipsex
Member#: 179310
2015 Forester XT
Default Viper 5901 installed but alarm goes off when auto start when armed. HELP
I just got the alarm installed yesterday, viper 5901 w/ backup battery, backup siren, and glass break sensor. Before I left the installer, we tested everything but we did not test autostarting when car is armed. This morning when i tried to autostart it when armed the alarm went off. So i thought it was the glass break sensor. So I went and took off the kick panel and totally unplugged the glass sensor. Then went to autostart it again and same thing happens. It will autostart fine if I unarm the alarm first then autostart. Any ideas?
xaznxeclipsex is offline   Reply With Quote
Old 06-16-2009, 09:53 AM   #2
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Y
E
P..
Take it BACK... if it's not set up to do what it's supposed to do, it's the installers problem and the shop that installed it..
What EXACTLY are you doing unplugging things? Do you have a clue as to how to troubleshoot an alarm?
I don't want to sound overly harsh, but seriously, you got it installed YESTERDAY..
Take the thing back and tell them to make it right..
Old 06-16-2009, 10:15 AM   #3
xaznxeclipsex
Member#: 179310
2015 Forester XT
Well i watched the whole alarm install precedure, my guess was the glass sensor, now i know its not. I'll take it back to the installer tonite.
Old 06-16-2009, 10:52 AM   #4
Biznatch231
Member#: 170676
2005 Forester XT
Could be they wired the dome light to one of the door switches. This will cause the light to turn on, but also appear like the doors are open.
Biznatch231 is offline   Reply With Quote
Old 06-16-2009, 11:09 AM   #5
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
On Subarus the dome light supervision and the door trigger is one and the same.
I have a 5901 and it works perfectly..take it back to the installer and let them deal with it. You didnt pay them $85/hour so you could troubleshoot something they screwed up..
Old 06-16-2009, 11:16 AM   #6
rooobaru
Member#: 144965
04 WRX STi
wrb
if the starter is integrated with the factory alarm,the wire used to disarm the factory alarm may turn on the domelight briefly enough to cause the viper system to see it as an open zone and trigger...
if so you may have to shunt that neg input wire for a couple seconds to avoid this situation...
let us know what the installer comes up with...
rooobaru is offline   Reply With Quote
Old 06-16-2009, 02:14 PM   #7
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
03 2.5ts BRP long gone
the first question I would have is . . . is it the viper system going off or your factory alarm system?
As for the external sensors, the alarm ignores them during remote start. So the glass break and shock sensor will not cause the alarm to go off.
thedaddyb is offline   Reply With Quote
Old 06-16-2009, 03:48 PM   #8
xaznxeclipsex
Member#: 179310
2015 Forester XT
I saw him put in a "xpress kit", so i believe that is going off my factory alarm?
I read in the manual that it takes 4 seconds for me to get paged if the alarm went off, i tested it while sitting inside the car and made the alarm go off, i got the page in 4-5 seconds. My friend's compustar will page him the second the alarm goes off, is there anyway to adjust this so i get paged quicker?
Old 06-16-2009, 05:09 PM   #9
couchflambeau
Member#: 102145
'04 STi/Cobb St. II
18L Java Black Pearl
problem = no-talent hack installer....
Certainly sounds like something isn't configured right, and if you paid for professional installation, it ain't your problem...
Take it back mang!
couchflambeau is offline   Reply With Quote
Old 06-21-2009, 04:00 AM   #10
strife1012
Member#: 136611
2007 spec B
I bet your alarm system is still active, we had a similar issue with my car. My Navi had a system selection to disable the Stock Security, your Subaru Dealer can disable it for you. Also check to see how sensitive the vibration sensor is.
He may want to use the DEI BitWriter and look at every setting one by one, it may have a error that sets off the alarm. Did he actually connect the Tach senor?
strife1012 is offline   Reply With Quote
Old 06-21-2009, 12:34 PM   #11
TheShadow
Member#: 62558
09 WRX
Deactive/Disarm Factory Alarm
1. Sit in the driver's seat and shut all doors and rear gate.
2. Turn the ignition switch to the ON position.
3. Hold down the UNLOCK side of the driver's power door locking switch on the door and Open the driver's door within the following 1 second!
5. Wait 10 seconds without releasing the switch (holding the lock button).
The setting will then be changed as follows, as indicated in the odometer/trip meter display:
If the system was previously activated: The odometer/trip meter screen displays 'AL oF' and the horn sounds twice, indicating that the system is now deactivated.
If the system was previously deactivated The odometer/trip meter screen displays 'AL on' and the horn sounds once, indicating that the system is now activated.
TheShadow is offline   Reply With Quote
Old 06-21-2009, 01:33 PM   #12
Ysidro
Member#: 197418
07 WRX Ltd
The Mighty Evo;Fun CRZ
Once it gets a signal to autostart, the brain will send a signal to disarm the factory alarm through the alarm disable wire before it starts it. If it gets another signal to shutdown, it will shutdown the car, and send another signal to rearm.
Im guessing, the factory alarm aint getting the signal, and its the factory alarm thats going off. What car do you have?
I know newer cars need the immob bypass install to get remote starting to work properly. And theres no wire to actually disarm the factory security.
Ysidro is offline   Reply With Quote
Old 06-28-2009, 10:29 PM   #13
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
Express kit:
I would have your installer to just use the 5901 alarm rather than the factory alarm. But if there was an "express kit" that only utilizes the OEM alarm, I guess you have no choice. There should be two wires that arm and disarm the factory alarm. I have no idea what wires are interfaced with the factory alarm, but its obviously not wired correctly or you have a defective alarm.
Daddyb makes a good point about the factory alarm; that has to be disabled when the autostart initiates. I had installed my own 5701 (shouldn't be much different than a 5901 in this case) and just disabled the factory alarm completely
Domelight door trigger:
I am not sure if the domelight can be used. The domelight dims so it still gets some voltage when you close the doors. I know the alarm system needs a full 12v as a trigger, but I just did a little extra work and used the 4 door sense wires in the DKP and diode isolated them all.
Your autostart problem:
If is indeed your factory alarm, then your installer did not wire the factory disarm wire correctly. If autostarting triggers the viper alarm then it is defective. The integrated autostart automatically disables (not disarm) auxilary sensors as well as integrated triggers (like shock sensors or starting sensor etc). Regardless, take it back and give em hell.
Ysidro
Ysidro, if you are right about no wire for the viper system to disarm the factory security then you definitely need an aftermarket alarm system (your 5901) to be triggered. Also, I think all the 08's have an immobilizer chip, but I don't think DEI (Viper's momma) makes a bypass for the Subie's, or at least NTIKO.
Henry H is offline   Reply With Quote
Old 06-29-2009, 12:38 PM   #14
Ysidro
Member#: 197418
07 WRX Ltd
Originally Posted by Henry H View Post
Ysidro
I got the info from DEI directech diagram. They say the only way to disable the alarm is by remote only. I believe 06+ models are all the same because they have immobilizers. This makes it really hard to integrate DEI with the factory alarm, and I probably have to carry around 2 remotes to get it to work. SO, I abandon the idea of having one for later when I dont get so lazy.
It probably would be cleaner if we can remove just the factory alarm
and replace it with a DEI alarm with remote starter integrated unit so that way, we can have 1 remote for everything. And also integrating the DEI with the immobilizer wouldnt be hard.
Old 06-29-2009, 05:01 PM   #15
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
if he did use the express kit . . something is funky.
I've installed a few of the newer bypass kits and they are great for the new subies. I've done a wrx and a few foresters.
The module connects to the CAN wires in the vehicle and it gives you the ability to control the door locks, factory alarm features, and bypass the immobilizer without loosing a key.
tying into the factory alarm system was not an option in the previous model years (02-07)
stock alarm goes off when I lock it while it's running and cold outside IVGottaBDreamin Car Audio, Video & Security 0 12-17-2009 09:33 AM
i NEED A VIPER 5901 installed.. esker Southern California Impreza Club Forum -- SCIC 9 01-12-2009 09:24 PM
alarm goes off AUTOmaticly HELP PLZ!!!!!!!!!!!!!! Ronaldo Car Audio, Video & Security 17 03-13-2006 10:21 PM
Alarm goes off when opening UNLOCKED doors. WTH??!! cwb124 Car Audio, Video & Security 3 04-05-2005 09:15 PM
alarm goes off when i use the key bziller Car Audio, Video & Security 4 07-16-2002 01:22 PM
