Welcome to the North American Subaru Impreza Owners Club Friday April 18, 2014
Old 06-18-2009, 12:19 AM   #1
cribbie
Member#: 184505
Sonic yellow
Default The piston height on my ROSS pistons are out to lunch!
Hey guys, For those of you who do know I am under going a EJ22T build for my WRX. I am using the stock crank and regular length eagle rods, I had a set of custom ROSS pistons made to over come the low CR people encounter when using the EJ22 block with WRX heads.
Yesterday I took the ring set out of the package to only find out that they are 88mm rings. ( ROSS pistons are 97mm) So after a few selected words i called up ROSS pistons and gave them my builders card number, just moments later the gentleman had told me that they had made a mistake and they had sent me the wrong rings... Noo *****... So i asked them if they could send me the proper rings, he then told me that the pistons were made to those rings and the only solution is to send them back and they will make a new set for me... That is great to hear, but i have already had my pistons ceramic coated. After speeking with the maneger they told me that they would have them coated for me as well for no axtra charge
So after all this was said and done I decided to install the pistons on the rods and then placed them in the block. When i rotated the assmebley to TDC this is what I ran into.
Here is a stock EJ22T piston to compare to...
I need some help by you guys to help me solve this problem. I call ROSS again today and emailed them the these pictures and they told me to resend what exacly i need and they will try to make everything right the secondtime around..
Does anyone know what type of custom piston is needed to run the ej22t with WRX heads and no special rod lenghts?
I really hope someone can shine some light on this dark situation....
cribbie is offline   Reply With Quote
Old 06-18-2009, 12:24 AM   #2
cribbie
Member#: 184505
Sonic yellow
More pictures.
Can i have them leave everything the same and just change the wrist pin location?
Here is a picture of the piston spec sheet, maybe someone will be able to tell where the mistake was made.
Old 06-18-2009, 12:24 AM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
well, that sucks man...that's why I still say leave subaru's to subaru people....also why I started 3MI Racing for filling custom internal orders and helping guys out with them.
With that compression height it looks like they were expecting you to run some NA length rods with 79mm stroke crank. 30.5mm is the 'standard' EJ25 piston CH
Old 06-18-2009, 12:30 AM   #4
cribbie
Member#: 184505
Sonic yellow
Does any other piston manufacture make an off the shelf piston for this setup? I know Wiseco has a ej22t hybrid piston but that is designed for the 2.35L stroker. I did not think a basic ej22 build with WRX heads would be that complex.
Old 06-18-2009, 01:16 AM   #5
All_talk
Member#: 57843
2007 Spec B
Looking at the build sheet it looks like they used a 1.161 (29.4mm) compression height. I think it should be 33.5mm... 201mm deck height - 37mm for half the stroke - 130.5mm for the rod = 33.5mm. 29.4mm would leave them 4mm (0.157") low, its hard to tell from the pic, are they that far off?
All_talk is offline   Reply With Quote
Old 06-18-2009, 01:43 AM   #6
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Measure how short the pistons are from the deck, I bet its 2mm short, which would be a stroker piston....
reddevil is offline   Reply With Quote
Old 06-18-2009, 01:45 AM   #7
gto7419
Member#: 44256
2002 WRX Wagon
wiseco has .20 over pistons for the ej22t - to be used with stock crank and rod length...
gto7419 is offline   Reply With Quote
Old 06-18-2009, 07:17 AM   #8
cribbie
Member#: 184505
Sonic yellow
All i have to refer to is the pictures, I had the pistons packaged up and sent back to Cali in order to speed up this fudge up ASAP.
I can use what i have for information from the pictures and try to measure up the distance by just sliding the stock piston down the cylinder and use my camera to mimic the same location. Its not the best way but i might give a ball park figure.
Old 06-18-2009, 07:18 AM   #9
cribbie
Member#: 184505
Sonic yellow
Old 06-18-2009, 07:22 AM   #10
cribbie
Member#: 184505
Sonic yellow
With DOHC WRX heads?
Because if i can find something that has already been done i will just copy and paste that informaion to ROSS.
Old 06-18-2009, 08:47 AM   #11
All_talk
Member#: 57843
2007 Spec B
Check the Wiseco chart here: http://www.wiseco.com/Catalogs/Sport...baruToyota.pdf
It shows a 33.25mm (1.312") CH for the EJ22. Note the 1.161" shown on your Ross spec sheet is listed for the EJ25 with the 131.5 rod.
To confirm you can measure the CH of you stock piston, the new ones should be the same assuming you did not want the deck clearance to change.
Gary
Old 06-18-2009, 10:25 AM   #12
cribbie
Member#: 184505
Sonic yellow
Do you think this piston is designed to be used in a hybrid stroker?
Also would i be better off trying to achieve the wrx ej20 piston deck height of .014- so i can use stock head gaskets with the wrx heads?
Old 06-18-2009, 10:46 AM   #13
gto7419
Member#: 44256
2002 WRX Wagon
wiseco makes a lot of different pistons...
there are two for stock ej22t crank/rod - a .20 over and a .40 over
wiseco also makes a variation for an ej22t stroker...
Old 06-18-2009, 10:53 AM   #14
cribbie
Member#: 184505
Sonic yellow
I am making the call right now... I will post the information they give me...Thanks for all the support up into this point.
Old 06-18-2009, 11:39 AM   #15
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
It depends also on what gasket you plan to use. This is what you need:
Compression height 32.9 mm, dish 14cc for CR 8.0:1 with 1.00 mm Cometic EJ22T gasket
Compression height 32.9 mm, dish 9cc for CR 8.5:1 with 1.00 mm Cometic EJ22T gasket
Compression height 32.7 mm, dish 14cc for CR 8.0:1 with 0.80 mm 11044AA542 gasket
Compression height 32.7 mm, dish 9cc for CR 8.5:1 with 0.80 mm 11044AA542 gasket
Marnix is offline   Reply With Quote
Old 06-18-2009, 05:48 PM   #16
cribbie
Member#: 184505
Sonic yellow
There is a 3mm difference between the two compression height.
Old 06-18-2009, 05:55 PM   #17
cribbie
Member#: 184505
Sonic yellow
Old 06-18-2009, 06:38 PM   #18
All_talk
Member#: 57843
2007 Spec B
Yep looks like a stroker piston based on the EJ25D (like the wiseco stroker), 2mm for the difference in stroke and 1mm for thr difference in the rod length.
Unless you wanted to change the deck clearance on purpose as part of your CR adjustment the compression height should be the same as the stock piston.
Gary
Old 06-18-2009, 07:39 PM   #19
Maxwell Power
Member#: 190729
DO THE STROKER!!
Get a 79mm dual thrust billet crank and call it good!
Old 06-18-2009, 08:17 PM   #20
cribbie
Member#: 184505
Sonic yellow
DO THE STROKER!!
I wish it was that simple!!!!!
But iv got so much invested in machining.
Old 06-18-2009, 09:49 PM   #21
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Or just a stock dual thrust crank. I was tearing down 3 motors today and randomly decided to see if my extra 79mm cranks were dual thrust. 3 were! So I will be doing a few stroker ej22 builds.
Old 06-18-2009, 11:32 PM   #22
Maxwell Power
Member#: 190729
it IS that simple. Nothing else changes. You only need to do 2 things. verify the rod and main bearing clearances, balance the crank.
Everything else is the same.
Old 06-18-2009, 11:44 PM   #23
cribbie
Member#: 184505
Sonic yellow
But i have already had the hole rotating assembly including flywheel and crank pulley internally balance which took a lot of time because it had to be sent out and not to mention the cost... Also the crank had to be reground and that alone was $250. And what about crank and con rod bearings? I would love to have my car back on the road this season.
Old 06-19-2009, 12:10 AM   #24
DSM_Outback
Member#: 56345
93 Swapped L
Green
Call Ian @ Ross, kindly let them know they fuqued up. But have all your measurments laid out before you call.
As for balancing, no one that I know of uses a bobweight on a Subaru crank. So you should be good there.
DSM_Outback is offline   Reply With Quote
Old 06-19-2009, 12:12 AM   #25
cribbie
Member#: 184505
Sonic yellow
Are there any other methods? if not does this mean it was not balanced?
I am really surprised nobody has made a comment on the picture with the turbo in it
How do I remove the dash kit on my 1994 landcruiser, to take out my stereo? Nightwing Off-Topic 6 05-17-2010 09:15 PM
Dropped the cash for coatings on my new pistons. Convince me it wasnt a waste of $$ Davenow Built Motor Discussion 11 03-14-2008 03:36 PM
What are the limits of the roof racks on my Rav4? Cjchaps Off-Topic 12 01-27-2007 10:57 AM
Are the spherical bearings on my Perrin end links supposed to be this stiff? dsc Brakes, Steering & Suspension 1 02-21-2003 12:41 AM
My dash guts are out, the headunit is hooked up, but it won't fit in 2k2 Car Audio, Video & Security 3 07-10-2002 10:12 PM
