Old 06-18-2009, 12:15 PM   #1
dmitriygolos
Member#: 191111
2005 evo VIII
Silverrrr
Default my 04 wrx stage 2 track time
hey guys i went to the track couple for the first time the other day.
ran 4 times and improved every single time.
mods include: perrin downpipe, spt catback, k&n short ram intake, cobb ap stage 2.
on my last run here are my numbers
R/T ... .762
60'... 1.961
330 ... .000
1/8 ... 9.005
MPH ... 77.48
1000 ... .000
1/4 .... 14.024
MPH ... 96.53
my question is with this being my first time, could i probably get faster numbers or is this average for a wrx?
dmitriygolos is offline   Reply With Quote
Old 06-18-2009, 12:41 PM   #2
hammyt
Member#: 92585
2005 Saab 9-2x Aero
13.6@100 EJ205 VF48 93Oct
I ran 14.2 the other day with a 1.9 60' on a cobb stage II OTS map. A lot of people with stage 2 2.0 liters were running 14.0-14.4 that day.
hammyt is offline   Reply With Quote
Old 06-18-2009, 01:16 PM   #3
BaNaNaS
Member#: 171902
2004 WRX Sport Wagon
PSM - Stg 2
I think you answered your own question! Keep practicing!
BaNaNaS is offline   Reply With Quote
Old 06-18-2009, 03:11 PM   #4
pushnpounds
Member#: 207683
02 bugeye
wrb
i tracked my car twice my best time was a 14.1 et with a 1.9 60ft my mods were catless tbe, custom ext wastegate dump on the internal gate, k&n typhoon intake w/o heat shield, turbo xs type h rfl bov, dc sports short shifter, 17" wheels that weigh a lil more than stockers w/ fresh kelly fierce hp tires, and a jdm catless uppipe with the egt temp disconnected, all this and no tune on my car 140k just got cobb ap stage 2 tune and gizzmo launch control can't wait to test it
pushnpounds is offline   Reply With Quote
Old 06-18-2009, 04:06 PM   #5
STi Mikey
Member#: 114631
2007 11.5 @ 118
Stock Turbo Record Holder
R/T ... .762
60'... 1.961
330 ... .000
1/8 ... 9.005
MPH ... 77.48
1000 ... .000
1/4 .... 14.024
MPH ... 96.53
Good deal for your first time out. Once you get the driving down, low-mid 13's are do-able.
GL
STi Mikey is offline   Reply With Quote
Old 06-18-2009, 07:20 PM   #6
DirtyBanana
Member#: 211802
2003 Wrx
Sonic Yellow
You should be proud of your first run man. Most people get nervous and wind up running in the 17's (I should know heh). Practice makes perfect, you need to get those 60's down, and it'll run like a champ. Good luck.
DirtyBanana is offline   Reply With Quote
Old 06-19-2009, 11:54 PM   #7
dmitriygolos
Member#: 191111
2005 evo VIII
Silverrrr
yup. i reallly wanna get into mid 13s with some practice.
Old 06-20-2009, 09:10 PM   #8
04_scooby
Member#: 202957
2004 04 DoVe
sliver
Default nice
i ran a 13.1 @ 103 MPH with my stage 2 rex
04_scooby is offline   Reply With Quote
Old 06-20-2009, 09:23 PM   #9
dinosmash
Member#: 143598
1993 impreza v3 powa
blue
first time out thats good.but others running 14 to 14.4 stage 2 is weak as hell.i ran 13.9 on my stage two.its hard to get stage two ej20 motors into the low 13s.
dinosmash is offline   Reply With Quote
Old 06-20-2009, 09:53 PM   #10
04_scooby
Member#: 202957
2004 04 DoVe
sliver
Default kool
not really you just gotta really get to know your car and the power it produces......plus need good launch an 60 ft......two man key in getting good times....actually my first time at track with stage 2 tmic i did 13.4 best and then with fmic i did 13. 1 best
Old 06-21-2009, 03:38 PM   #11
Headstart101
Member#: 192664
2004 gt30r WRX STI
R/T ... .762
60'... 1.961
330 ... .000
1/8 ... 9.005
MPH ... 77.48
1000 ... .000
1/4 .... 14.024
MPH ... 96.53
u trap 96mph in the 1/4...i ran a 13.6 in my stock 04 sti trapping 96 but i miss a gear.......
Headstart101 is offline   Reply With Quote
Old 06-21-2009, 03:53 PM   #12
JSarv
Member#: 163445
l33t *******
12.07@115.9mph-EJ205
I almost trap 96 in the 1/8th....
OP I know you can do faster - Your tune is probably not up to par (far from it)
I have seen guys run sub 9 1/8ths in a completely stock Bugeye...
I ran 8.49 @84 on my stage 2 map with a bit more boost...
I know its hard to do with the 5 speed... But be EASY on it while still being hard on it
-Jerod
JSarv is offline   Reply With Quote
Old 06-21-2009, 04:58 PM   #13
Headstart101
Member#: 192664
2004 gt30r WRX STI
-Jerod
^^ how do u go about doing? ........
Old 06-21-2009, 05:11 PM   #14
JSarv
Member#: 163445
l33t *******
Burn the piss out of your clutch
Use the absolutely "weakest" clutch you can for your power...
I always used OE with my 5 speed
Old 06-21-2009, 05:13 PM   #15
Spenk
Member#: 7164
---> Spoiler alert:
Everyone dies at the end.
^^^^^ ...and you still pooched your tranny.
Spenk is offline   Reply With Quote
Old 06-21-2009, 05:14 PM   #16
JSarv
Member#: 163445
l33t *******
Your right I did - Third gear though... It was a pure power pooch
Made it nearly 5k miles on E and 23-24 psi from an 18g.....
5k miles on E and Td04 (lots of torque)
10k miles on Stage 2 93 octane
25+ launches 10+ launches w/18g
And then third craps out on me..
Old 06-21-2009, 05:25 PM   #17
dmitriygolos
Member#: 191111
2005 evo VIII
Silverrrr
update: yesterday i went to the track and got 13.805
and i feel like i could do a bit faster....
Old 06-21-2009, 06:30 PM   #18
JSarv
Member#: 163445
l33t *******
See practice makes perfect... Just remember the more/harder you beat on your gears the bigger the chance of failure becomes...
Old 06-21-2009, 09:46 PM   #19
Audiosavvy
Trust me, I'm a scientist
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Will you please quit talking about your car? I know it makes good power and you run good times, but it seems like you add something about it to each of your posts here
Audiosavvy is offline   Reply With Quote
Old 06-21-2009, 09:49 PM   #20
Audiosavvy
Member#: 150794
Qcab dakota 4x4
OP, your 60ft time leaves room for improvement, but it's not bad for someone new to drag racing at the track. With a 1.8 60ft, which is definitely possible with your setup, you'd cut roughly .3 off your E/T, dropping you to the upper 13s, which is respectable.
From there, I think some better shifting techniques and possibly different shift POINTS could get the trap speed up to where it should be, closer to 100.
Those 2 things together in a solid run should net a 13.5, even better with practice .
Old 06-21-2009, 09:53 PM   #21
JSarv
Member#: 163445
l33t *******
I have been patting myself on the back a little much lately
I'll have to put an end to that...
Old 06-21-2009, 10:10 PM   #22
Audiosavvy
Member#: 150794
Qcab dakota 4x4
It's cool, I know the feeling, just save it for when it's really necessary
Old 06-22-2009, 06:44 AM   #23
WRXstyle
Member#: 188762
2008 STI
its about time your in the 13's lol, i remember your first times. we raced all 4 times i think lol
WRXstyle is offline   Reply With Quote
Old 06-22-2009, 05:09 PM   #24
Farnk
Member#: 91093
2002 Wrx
When I had my 02 at stage 2 I ran 13.7 WHILE i missed 3rd. Which surprised me cause that was also my best time.
Farnk is offline   Reply With Quote
Old 06-23-2009, 06:02 AM   #25
2.5ReallySexy
Member#: 167943
maybe if you stop hanging out with crazy courtey you could run a better time. two faced sob
2.5ReallySexy is offline   Reply With Quote
New stage 2 track times BradsWRX Proven Power Bragging 5 03-15-2009 02:03 PM
04 WRX stage II ..first time at track SubbyPAT Proven Power Bragging 17 06-17-2007 12:36 AM
FS: 04 WRX stage 2.5 JBP cobbler Private Vehicle 'For Sale' Classifieds 7 02-04-2007 11:06 PM
LA: 04 wrx stage 2.5 fs cobbler Private 'For Sale' Classifieds 1 05-07-2006 06:07 PM
TX 04 WRX Stage 2 Wagon phares1 Private 'For Sale' Classifieds 2 06-08-2005 07:08 PM
Message Board Statistics All times are GMT -4. The time now is 10:49 AM.
