Old 06-26-2009, 10:18 AM   #1
Ti Pit
Member#: 146009
2005 Baja Turbo
Default Transmission swap in a Baja? What would I need
Alright
So I'm having doubt on both 5speed Turbo baja's that I found for sale at a decent price.. one had a salvage title and the other one isn't the color/optiomilage/combo I really wanted.
How hard would it be to swap an Auto Turbo baja to a 5speed? I'm not talking how hard to do it physically but what parts need to be changed and do they have to come from a baja or some legacy GT parts could be used?
I'm guessing the tranny could be from a legacy GT. What about the Axels, drive shaft, rear diff, would the automatic ones be good with the 5speed tranny? Does the Automatic Turbo Baja also have the rear LSD?
Other parts I guess I'd need would also be a cluster, pedals, slave/master cylinder, ecu?
Thanks for your help
Alex
Ti Pit is offline   Reply With Quote
Old 06-26-2009, 04:10 PM   #2
kingofl337
Member#: 200340
2005 Baja Turbo
Dark Blue
It can promise you it would be allot cheaper to just get a manual baja. What color combo are you looking for? I think the manual was on available in certain colors.
So far I've seen blue, grey, and red.
kingofl337 is offline   Reply With Quote
Old 06-26-2009, 08:05 PM   #3
su-be3
Member#: 78702
2004 BAJA Turbo
Frost Pearl White
Cool
In 2004, 5 speeds were available in White, same color as mine.
Keep it under 90, folks!
su-be3 is offline   Reply With Quote
Old 06-26-2009, 09:50 PM   #4
Ti Pit
Member#: 146009
2005 Baja Turbo
Well I`m looking at Blue or Black Turbo + leather + sunroof + 5spd + ac I`d also like a tow package but it`s not a must.
So far I found 3 in my price range
1 black, 1 blue, 1 red and silver.
I was going to buy the black one but found out it was a salvage title.
the red one has 78,000 more miles then the black one and is selling for the same price no clue about the interior and no tow package.
the blue one is automatic but has every other option I need.
Problem is, I have a low budget of about 10kus maximum since once Imported into Canada thats about $15-16k when the taxes, fees and inspections are paid.
All the ones I listed above were 9800-9900.
I;m looking all over the US, I don`t mind traveling.
Old 06-27-2009, 09:49 AM   #5
twheats1
Member#: 147722
2004 Baja Turbo
00 R 1100RS
In the US, leather was only available with the automatic, IIRC.
twheats1 is offline   Reply With Quote
Old 06-27-2009, 10:31 AM   #6
Ti Pit
Member#: 146009
2005 Baja Turbo
Are you sure? Both the 5 speed I found both had leather in them ..
is there suck a thing as full leather and half leather? I know for sure it`s not full cloth because I saw those in base baja`s and I hate that interior.
As a little insider info, I`m buying the baja to replace my stolen WRX. I hope Ill be able to enjoy it just as much.
Old 06-27-2009, 04:24 PM   #7
texwr1889
Member#: 139147
2004 WRX
If u find a wrecked wrx u can pull everything from that all the bajas use the same manual transmission from all wrxs 04 and up the bugeye transmission had sti ra gearing in random models U could even put the sti six speed if u wanted to but the 5spd is better suited for everything and u wouldn't need a cluster in all it would be easier to paint a car than swap trannys so it's ur call
texwr1889 is offline   Reply With Quote
Old 06-27-2009, 04:30 PM   #8
Ti Pit
Member#: 146009
2005 Baja Turbo
Would I need to change the rear diff, axels and driveshaft or would they be good for the swap?
Old 06-27-2009, 04:32 PM   #9
texwr1889
Member#: 139147
2004 WRX
also the bajas and 2.5 gt's have almost nothing on common the bajas are most closley related to the 04-05 sti motor with an 06-07 setup td04, small intercooler, with the same tranny as 04-07, and highly detuned making only 11 pounds of boost from the factory
Old 06-27-2009, 04:34 PM   #10
texwr1889
Member#: 139147
2004 WRX
Maybe the rear diff but I'd have to check but the rest is good
Old 06-29-2009, 05:23 PM   #11
Subie_Sleeper68
Member#: 166403
2006 Baja Turbo
Silver 340 AWHP 365 AWTQ
EXCEPT Bajas have a 4.44 final drive and WRXs have 3.90s. A trans from a Forester XT has the right ratio. ALL Baja Turbos have the LSD. GOOD LUCK
Subie_Sleeper68 is offline   Reply With Quote
Old 06-30-2009, 10:02 PM   #12
texwr1889
Member#: 139147
2004 WRX
I'd rather have the 3.90s wrx final drive for sure
Old 06-30-2009, 10:16 PM   #13
steven765
Member#: 105920
2006 Baja 5 Speed
I was able to add the leather, power heated seats to the Manual. It's not too terrible. I can describe the details if you need. I even added the heated mirrors, likely a must up in CA.
The other options, sun roof, AC are standard.
And the tow package is super easy to bolt on
steven765 is offline   Reply With Quote
Old 07-03-2009, 01:20 AM   #14
qmania2
Member#: 215369
'07 STI - Alice
Urban Gray Metallic
I'm actually doing an STI 6 speed swap in my '06 Baja Turbo. To do a 5 speed swap here is the list:
1: tranny+shifter linkages and shifter assembly
2: clutch+flywheel along with clutch fork, bearings and all hardware
3: clutch master cylinder with reseroir, line, and slave cylinder for 5 speed
4: 5 speed standard drive shaft
5: rear diff (R160) to suit the gearing of the front diff or a ring and pinion swap
6: standard baja wiring harness
7: ability to flash a standard baja map onto the ECU and being able to tune out the couple CELs that will arise
8: 5 speed crossmembers as well as all bushings and transmission crossmember mount
9: depending on the year tranny you get you MAY need front axles
10: the skills, time, and money to do the swap!
The WRX 5 speed will be a better choice than the LGT (to my knowledge) but the STI 6 speed will be even better!
If you want specifics, just PM me, I can give you the list seeing as how i will be preceding with the STI 6MT swap in a week and a half, I'm waiting on the parts to arrive at my doorstep haha
qmania2 is offline   Reply With Quote
Old 07-03-2009, 01:22 AM   #15
qmania2
Member#: 215369
'07 STI - Alice
Urban Gray Metallic
also the motor is that of the 06/07 WRX TR, yes it has the td04 that cam standard on early WRXes, I have lists upon lists of compatibe parts with other platfroms, if anyone needs any info I have ALOT of it haha, feel free for anyone to PM with any questions regarding anything!
Old 07-03-2009, 12:17 PM   #16
twheats1
Member#: 147722
2004 Baja Turbo
00 R 1100RS
I know it is a lot of work, but it would be great if you could post the lists and get it "stickied".
Old 07-03-2009, 06:57 PM   #17
qmania2
Member#: 215369
'07 STI - Alice
Urban Gray Metallic
I'm workin on it now, it is a lot of work but it will help a lot of people
Old 07-04-2009, 08:15 AM   #18
steven765
Member#: 105920
2006 Baja 5 Speed
hmm given your list. I wonder if swapping the 6 speed into my 5 speed manual would be easier?
Old 07-04-2009, 10:27 AM   #19
kingofl337
Member#: 200340
2005 Baja Turbo
Dark Blue
He forgot to post the pedals, and slave cylinder that need to plumbed in. You basically have to rebuild the whole car.
Old 07-04-2009, 01:59 PM   #20
qmania2
Member#: 215369
'07 STI - Alice
Urban Gray Metallic
Alright
Alex
That was my exact same dilema, exactly haha.
What I did was bought the auto turbo, the exact one that I wanted, and planned to do a 5 speed swap, down the road. If you keep the car at stock power level, you can MAYBE get away with the 5 speed. It is sooooo freakin fragile. That is why everyone calls it the "glass tranny" I HIGHLY recommend shlling out the few extra clams and getting the 6 speed.
Kingof, it looks like I did forget the pedals, I just did that swap from an 04 STI pedal set, almost direct bolt in ALMOST.
I am working on "master swap list" for these kids of swaps, it will take me a few days because there is SO much detail haha.
With a 5 speed swap, you're looking at around 3K-3.5K of parts with good milege on an 05/06 or so tranny. Labor will be around 1.5K leaving you 4.5-5K in the hole. A 6 speed swap is about 4K (with good deals) and about 1.5K install, leaving you at about 5.-6K. I definitely recommend going with a PROFESSIONAL install, not midas, or any place like that. Here in CT we have East Coast Swappers, they are #1 in the whole swapping industry here on the east coast, they are extremely knowledgeable and fair priced.
To me its common sense, the 5 speed WILL break at some point down the road, I guarantee it. With a good install, good parts, the 6 speed will outlast your car (with out absurd abuse)
Any other questions feel free for anyone to chime in! I have been looking up info on this for 6 months, I have a lot of knowledge!
Old 07-04-2009, 02:03 PM   #21
qmania2
Member#: 215369
'07 STI - Alice
Urban Gray Metallic
Yes! 100 times easier!
if you're not in a rush and can hang around for a few days I will work on that "master swap list" and will have ALL the details that are involved. 5MT to 6MT won't need a new wiring harness, it won't need an ECU reflash, it won' need the clutch master cylinder, line, pedals, but it will need a slave (I think, give me a few days on that too) you won't need the shifter trim inside of the car, you will need anew driveshaft (from a 4EAT) etc, there are a few differences. It will be cheaper and definitely easier.
Old 07-04-2009, 06:50 PM   #22
steven765
Member#: 105920
2006 Baja 5 Speed
yes i'm not in any big hurry as I was just in an accident and am awaiting the return of mine from the body shop
Old 07-04-2009, 07:27 PM   #23
qmania2
Member#: 215369
'07 STI - Alice
Urban Gray Metallic
oh noooo what happened? U alright?
Old 07-05-2009, 01:23 PM   #24
steven765
Member#: 105920
2006 Baja 5 Speed
yea i was stopped getting off the interstate. Lady in front starts to go, so I followed. I start watching oncoming traffic then i see red out of the corner of my eye. She STOPPED! I did the best i could but still hit her at like 10mph.
I went up under her bumper so almost no damage to them. Mine is like 4300 in damage for the new hood, bumper, light and fender, and 3 structural pieces underneath that need to be replaced (gotta love spot welds!)
Amusing part is as a i recall traffic was just leaving the red light.. 3 lights away and the alabaaaama driver didn't think she could make it. le sigh
So either way I am screwed since I hit into her it goes against me, but the cop was nice and wrote it up as a traffic incident not out of state accident.
Old 07-05-2009, 02:08 PM   #25
qmania2
Member#: 215369
'07 STI - Alice
Urban Gray Metallic
Damn dude, that suckss
stupid alabaaaama driver
hahaha. Did you have to file with insurance or no? Be lucky if ya didnt. But hey, thats cool that the cop wasn't an ass lol. At least ur okay too and ur baja isn't totaled or anything, lucky the air bags didn't go off too!
jdm sti V7 or 8 transmission swap in 03 wrx youngW03 Subaru Conversions 11 09-16-2010 12:55 PM
2.5 RS swap in 02 WRX...What is needed? Tr2laozboi Newbies & FAQs 7 01-01-2010 11:11 PM
Closed Deck EJ20G swap in 02 WRX??? What esle do i need? Wrx_Fan_0717 Built Motor Discussion 13 03-06-2009 05:01 PM
VF39 Swap in 2008 WRX What do I need? x Mr Awesome x Factory 2.5L Turbo Powertrain 21 10-03-2008 04:47 PM
Looking for help on transmission swap in Carlsbad triguy Southern California Impreza Club Forum -- SCIC 6 10-14-2007 04:29 PM
Message Board Statistics All times are GMT -4. The time now is 07:56 AM.
