Welcome to the North American Subaru Impreza Owners Club Thursday February 26, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'General Sale' Forum
Closed Thread
Old 07-01-2009, 06:05 PM   #1
RaceComp Engineering
Vendor Sales Rating: (30)
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Subaru Stars Racecomp rolls the clock back with 2007 prices!! 2nd Annual RCE Summer Sale !!
Racecomp Engineering rolls the clock back with 2007 pricing !! 2nd Annual RCE Summer SALE-A-THON
This is the time of the year when people travel and so buying car parts tends to be put on the back burner. We are trying to give you the type of savings that motivates you to tell your wife, girlfriend or Fiance'e,," LOOK,.I am buying some car parts and thats how its going to be..." ( or at least you can practice that in the mirror !! None the less as some of you may remember, around this time last year we had our first annual Summer SALE-A-THON. It was a huge success so we have decided to do it again this year! We don’t do this often so these are the lowest prices you will find on these parts, with discounts on our ever-expanding line of RCE/GTWorx parts, as well as brands like Ohlins, Whiteline, Performance Friction, Pagid, Hawk, and more! We have also put together some packages with additional savings.
Racecomp Engineering Super Sport Street/Track Springs
The highly anticipated Super Sport Street/Track Springs, an OEM replacement spring for 2004-2007 Subaru WRX STi from Racecomp Engineering. Designed for use with standard STi inverted struts or Ohlins Fixed Perch Replacement Struts, these springs are intended for both the daily driven street driver as well as the autocross and track day weekend warrior. Finally, after years of being the authority on Subaru suspension options for everyone from the daily driver to the professional racer, Racecomp Engineering can now provide their own solution to owners looking for the ultimate OEM replacement spring for their Subaru Impreza WRX STi. Using the very popular JDM STi springs that we brought to the U.S. market in mid 2003 as the benchmark, Racecomp focused on improving on track and autocross performance, while maintaining acceptable ride quality. Extensive research, design, and testing was performed to develop a completely new spring unlike anything currently available. With springs rates increased approximately 25% stiffer then the popular JDM Pink Springs, the springs are perfect for those with wider tires worried about rubbing, as well those looking for a little more rear spring rate to promote a more neutral handling characteristic. Much care was taken not to exceed the limits of the stock struts. The mildly progressive design and spring rates properly matched with the dampers ensure that ride quality is not diminished over stock. The car is lowered 20mm in the rear and 23mm in the front for an even look.
$301 Shipped
Racecomp Engineering Black "Regular Guy" Springs
Introducing the RCE Regular Guy Springs (RCE Blacks), an OEM replacement spring for 2004-2007 Subaru WRX STi and the next in the Racecomp Engineering growing line of performance springs for Subaru Impreza, Subaru Legacy, and Mitsubishi Evolution. Designed for use with standard STi inverted struts or Ohlins Fixed Perch Replacement Struts, these springs are intended for both the daily driven street driver as well as the autocross and track day weekend warrior. Using similar spring rates as the extremely popular and successful RCE Yellow Springs, but having a much more subtle/mild drop in comparison, these are perfect for STi owners not looking for a ride height much lower then stock, and yet are still looking for increased spring rates. Spring rates are still 10% stiffer then JDM Pinks with an emphasis on the rear rate, so you will still be outpacing just about everything on the track and auto-x course.
$301 Shipped
__________________________________________________ ____________
GTWorx Camber Plates
Drawing upon the extensive chassis design knowledge and experience that comes from designing several suspension and brake components with RCE, GTWorx is proud to announce their Camber Adjustment Pillowball Mounts for 2002-2007 Subaru Impreza. 2008+ Subaru Impreza GR chassis and 2005+ Legacy will be available shortly. These camber plates are currently intended for coilovers only, however, testing is underway for use with OEM style fixed perch struts.
Key features of these new front camber plates include a very low stack height, which means that these top mounts are non-raising at most camber settings. For a coilover at a given ride height, the user will have MORE bump travel with the GTWorx plate when compared to most other currently available plates on the market which raise the car substantially.
In addition, +.8 degrees of caster are built in to the camber plate, which helps minimize dynamic camber loss in a turn for the camber challenged Impreza chassis.
These lightweight alloy camber plates use the same high quality PROVEN pillowball bearing used in the popular Racecomp Engineering Camber Plates, which are known for smooth, long lasting, and quiet operation. Hardware is zinc coated stainless steel. Each bearing is rated at 37,000 lbs radial and 7,730 lbs axial force.
$349 Shipped
RaceComp Engineering Swaybars
We didn't try to reinvent the wheel here, just provide another option for GD Impreza owners looking for a swaybar set that will work well with stock springs, lowering springs, or coilovers.
Specifications:
25.5mm physical diameter
4142 Chrome Moly
Heat treated and cold finished.
Ends are hot forged on a 125 ton press.
Front and rear adjustable.
Washer tabs on front and rear to prevent walking
The settings for the front are 25.5 and 28.5mm.
Rear are 25.5, 27.0 and 28.5mm. So you could run these and not have to go to a bar that is actually 27mm thick.
$209 each OR $409/pair
__________________________________________________ ______________
Racecomp Engineering Tarmac II Coilovers
Separate bump and rebound adjustability
500 lbs/in front and 400 lbs/in rear spring rates
Custom spring rates available
We ship these already assembled, with ride height preset and settings set. Making installation an ease !!
$2649 shipped and assembled with Group-N Front and Rear Mounts
$2799 shipped and assembled with GTWorx Front and Rear Camber Plates
__________________________________________________ _______________
Racecomp Engineering Tarmac Zero coilovers
We've been pretty busy lately working on some new parts for the 08 STI, but we're not done yet for the GD body style Impreza.
First, our new Racecomp Engineering Tarmac Zero Coilovers, our new more affordable coilover entry based on our highly successful RCE Tarmac 2s.
Built by KW Suspension in Germany to our specs, these use the same high quality stainless steel corrosion resistant construction as our RCE T2s.
The difference here is our Tarmac Zeroes have preset damping that maximizes both performance and ride quality. This allows the end user to just put them on and drive without worrying about playing with too many adjustments. It also keeps them more affordable. Ride height is still adjustable of course.
Linear spring rates:
400 lbs/in front
340 lbs/in rear
Front and rear helper springs included. Can be used with camber plates or Group N strut top mounts.
04-07 STI and 02-07 Impreza WRX 1699.00 plus shipping.
__________________
512 Shaw Ct, Suite 104
Severn, Maryland 21144
410-846-5407
RaceComp Engineering is online now
Old 07-01-2009, 06:07 PM   #2
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Suspension Packages
Package 1
-RCE Springs (Black or Yellow)
-GTWorx Front Camber Plates
$649 shipped
Package 2
-RCE Front and Rear Swaybars
-Kartboy Rear Endlinks
$1109 shipped
Package 3
-Whiteline Com-C Front Strut Top Mounts
-Group-N Rear Strut Top Mounts
$699 shipped
Package 4
-Group-N Front and Rear Strut Top Mounts
$659 shipped
Brake Components
Pagid Brake pads, made in Germany, have long been used by many of the top endurance racing teams across the world. Top notch initial bite and modulation characteristics, along with impressive temperature ranges make these some of the best available pads for street, light track, and heavy track users.
Like most other well engineered German hardware, they were expensive. But this month, we'd like to offer a discount on these fantastic pads to our customers.
Pagid Blacks (Street) – $439 shipped
Pagid Blues (Street/Track) – $439 shipped
Pagid Yellows (Track) – $519 shipped
add Goodridge Lines - $95
Hawk Performance's leading-edge brake friction technology is proven everyday in severe-duty aerospace, military, commercial truck fleet, motorsports and performance street brake applications. Hawk Performance has dominated Motorsport race tracks since 1990, offering highly-engineered friction products for nearly every type of racing! Now you can get that same "race proven" materials and brake pad technologies for your street car.
Hawk HPS F+R - $186.94 shipped
Hawk HP+ F+R – $246.75 shipped
Hawk DTC-70 F+R - $499 shipped
Hawk DTC-60 F+R - $439 shipped
Hawk DTC-30 F+R – $429 shipped
Hawk HT-10 F+R - $409 shipped
Hundreds of races and more than 1,500 championships have been won on Performance Friction Carbon Metallic® pads, ranging from NASCAR Winston Cup to IndyCar to the Australian Porsche Cup. Last year alone, over 120 racing champions all over the world drove to victory on Performance Friction brakes.
PFC 01 Pads F+R - $599 shipped
PFC 2-piece Front Rotors - $849 shipped
Brake Packages
For those of you who like to do everything at once, we have put together some brake packages. If you don’t see one you like, or you just want to make a substitution, don’t hesitate to contact us so we can put something together for you!
Package 1
-Pagid Blacks F+R
-Goodridge SS Lines
-ATE Super Blue Fluid
$539 shipped (Add $29 for Pagid Blues or $59 for Yellows)
Package 2
-Performance Friction 2-piece Rotors
-Pagid Blacks F+R
-Goodridge SS Lines
$1199 shipped (Add $29 for Pagid Blues or $59 for Yellows)
Racecomp Engineering Kool Brake Kit
[b][size="3"]This kit was designed to cool and vent the braking system, thus reducing rotor temperatures. Initial testing at Summit Point Raceway showed up to a 200° F drop in rotor temperature when using aggressive pads. Testing was done with Pagid Blue RS-42, Pagid Yellow RS-19 and the new RS-29 brake pads. Designed to work with both stock STi rotors and any aftermarket 2 piece rotor, this kit is available now.
The Kool Brake Kit includes 12 feet of high quality, motorsport grade, high temperature hose far better then other options on the market. There is no need to upgrade. Stainless steel hose clamps are also included.
The RaceComp Engineering Kool Brake Kit is now exclusively offered in dry carbon fiber to improve unsprung weight savings. The spindle ducts are considerably lighter then the OEM dust shields that are replaced during installation.
$399 for the Carbon Kool Brake Kit!!!
Current applications are 2004-2007 STi.
2008 WRX and 2008 STi applications coming soon!
__________________
410-846-5407
Old 07-01-2009, 06:08 PM   #3
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
GR Impreza STI
RaceComp Engineering “Regular Guy” Functional Lowering Springs
Finally, a performance spring designed with function over form is available for the latest Subaru Impreza STI. The Regular Guy Functional Lowering Springs for the 2008+ Subaru Impreza STI are designed as the ultimate performance spring upgrade for the newly redesigned GR chassis.
Specfications:
5mm drop front and rear
320 lb/in front and rear
Shortened bump stops included front and rear (12mm shorter front, 18mm shorter rear)
Paying special attention to the completely new rear suspension design of the GR chassis, the Functional Lowering Springs provide a mild 5mm drop front and rear to maximize the extremely limited suspension travel available. Shorter bump stops are included front and rear to take things one step further, resulting in more bump travel than stock. Rarely does an aftermarket spring set-up add suspension travel, but in this case it is a crucial design aspect that improves performance while helping to maintain a civil ride on the street.
Spring rates of 320 lbs/in front and rear are intended to work with the completely new rear suspension of the GR chassis, which has a lower motion ratio in the rear than previous Imprezas. In addition, the OEM dampers have been carefully examined on a shock dyno to match the new spring rates to the dampers.
$349 Shipped
**NEW POST**
Spring Packages
Our springs alone are a great upgrade for the OEM suspension, but we have found that some additional mods really complement them well. We have put together a few packages with some of the more common suspension parts that people choose to add.
Package 1
-RCE Lowering Springs
-Whiteline Anti-Lift Kit
-Whiteline Roll Center Kit
-Whiteline Front Control Arm Bushings
-Whiteline Rear Camber Kit
$799 Shipped
Package 2
-Whiteline 22mm Front Swaybar
-Whiteline 22mm Rear Swaybar
-Kartboy Front Endlinks
$849 Shipped
Package 3
-STi Group-N Front Strut Top Mounts
$519 Shipped
Package 4 ( the Myles Special) lol.
RCE lowering springs
RCE 25mm hollow sway bars( front and rear)
Whiteline Steering rack bushings
Whiteline ALK caster bushings
Whiteline rear camber bushings
Whiteline trailing arm bushings
999.00 shipped
If you don’t see a package you like we can put one together for you. Don’t hesitate to give us a call!
__________________________________________________ ______________________
RaceComp Engineering Tarmac II Clubsport Coilovers
These are a true 2008 STi Impreza fitment with valving and spring rates specific to the completely new 2008 chassis. These are not cobbled together from existing parts....these are designed from the ground up to provide a track worthy, easily serviceable and long lasting threaded body coilover suspension system for the 2008/09 STi.
These coilovers feature the same inox-line stainless steel corrosion resistant construction as previous versions of KW suspensions. Spring rates are 8kg front and 8kg rear. These are aggressively valved, 2 way adjustable, performance coilovers. These are valved more aggressively then the standard KW Variant 3's, yet still offer an amazing ride quality not felt with other brands. These do not come with strut top mounts, but we have a few options available.
$2180 Shipped (Coilovers Only)
$2550 Shipped (Group-N Front Tops, STi Rear Tops-Fully Assembled)
$2699 Shipped (GTWorx Front Camber Plates, STi Rear Tops-Fully Assembled)
Project New York Package
This was one of the first packages we ever put together for a GR chassis STi. We were so impressed with it that we have continued to offer it, now at a reduced price! This is the ultimate suspension package for the street or the track. It includes:
-RaceComp Engineering T2 Clubsport Coilovers
-Whiteline Steering Rack Bushings
-Whiteline Rear Camber Adjustment Kit
-Kartboy Pitch Stop Mount
-Cusco Front Lower Brace Type-2
-Cusco Front Strut Tower Brace Type-OS
$3495 Shipped
Call to inquire about adding parts to this package, such as swaybars or custom spring rates!
Ohlins Sportline DFV Coilovers
Ohlins has announced their new DFV Sportline Height Adjustable coilover suspension for the 2008 STI.
Long known for their excellent racing and street dampers, Ohlins is now able to offer a street/track solution for the new 2008 Subaru Impreza.
Highly flexible damping range allows for comfortable street ride and excellent track performance. New DFV (Dual Flow Valve) technology allows for more advanced valving on both the rebound and compression side, resulting in even better ride quality and performance. A first for Ohlins Sportline on a Subaru, these coilovers are dual height adjustable, allowing separate preload and ride height adjustments.
Combined with the 2008 Impreza's redesigned rear suspension, Ohlins is able to take the tenacious grip offered by the new STI one giant step forward, while allowing the user to fine tune the balance and handling of the car.
*Includes front camber plates and rear pillowball top mounts
*Separate ride height and preload adjustment
*Spring rates are 500 lbs/in front and 400 lbs/in rear
*Custom spring rates and valving are available
$3250 Shipped
$389 Shipped ( intro special)
RCE Parts in Development
At RCE/GTWorx, we are constantly working to expand our line of performance products. We have some exciting new products for the GR chassis STi/WRX on the horizon, building upon our already successful catalog. You can expect to see these products released very soon, but for now here’s a preview of what’s to come!
RCE Swaybars
(GD swaybars pictured)
Using the knowledge we have gained in the process of developing our GD swaybars, as well as extensive testing of the GR chassis, we are in the final development stages for our GR swaybars! Made from heat treated and cold finished 4142 Chrome Moly with ends hot forged on a 125 ton press, the bars are then powdercoated black for a durable, rust-free finish. They feature washer tabs on the front and rear to prevent walking, and include polyurethane bushings and lube. More details and a full press release coming soon!
RCE Kool Brake Kit
This kit was designed to cool and vent the braking system, thus reducing rotor temperatures. Initial testing at Summit Point Raceway showed up to a 200° F drop in rotor temperature on a GD STi when using aggressive pads. Testing was done with Pagid Blue RS-42, Pagid Yellow RS-19 and the new RS-29 brake pads. Designed to work with both stock STi rotors and any aftermarket 2 piece rotor.
The RaceComp Engineering Kool Brake Kit is now exclusively offered in dry carbon fiber to improve unsprung weight savings. The spindle ducts are considerably lighter then the OEM dust shields that are replaced during installation. The GR Kool Brake Kits are in production, look for a press release soon!
__________________
410-846-5407
Old 07-01-2009, 06:08 PM   #4
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
09 Impreza WRX
You 09 WRX guys and gals are in luck....Myles recently took delivery of his very own 09 WRX. Since he can't really leave the car alone, it can only mean one thing: 09 WRX specific suspension parts are COMING!
Details here: http://forums.nasioc.com/forums/show....php?t=1798548
First step - BRAKES
Endless SSS pads front and rear
SS Lines front and rear
$569 shipped
add Motul 600 brake fluid for 20 bucks
or
ATE Super Blue for 15 bucks
Swaybars:
Whiteline 22mm front adjustable swaybar - $175 shipped
Whiteline 20mm or 22mm rear adjustable swaybar - $197 shipped
Bushings:
Whiteline Anti-lift kit - $120
- adds caster
- firmer bushing, less deflection and dynamic alignment changes
- removes anti-lift
Whiteline Rear Camber bushings -
$137
- allows rear camber adjustment
Whiteline Rear Trailing Arm Bushing
- $80
Whiteline Front Control Arm Bushings - $40
Whiteline steering Rack Bushings -
$63
- reduces some of the stock sloppiness, less deflection, improves steering feel. all around makes your car just feel a lot better.
OR get our Whiteline bushing package. Give us a call.
GTWorx Camber Plates by Racecomp Engineering for Subaru Impreza
Key features of these new front camber plates include:
  • very low stack height, which means that these top mounts are non-raising at most camber settings.
  • +.8 degrees of caster are built in to the camber plate, which helps minimize dynamic camber loss in a turn for the camber challenged Legacy chassis.
  • high quality pillowball bearing for smooth, long lasting, and quiet operation. each bearing is rated at 37,000 lbs radial and 7,730 lbs axial force.
  • Hardware is zinc coated stainless steel.
Below as shown with KW 60mm perches.
$389 shipped
__________________
410-846-5407
Old 07-01-2009, 06:08 PM   #5
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Racecomp Engineering Tarmac II for 08 and 09 WRX
$1799 shipped
Racecomp Engineering has a long history working side by side with KW Suspensions on many projects to serve and meet the demands of the Subaru enthusiast driven market. KW Suspension has continually impressed with their high quality construction, excellent valving, and ease of use. Racecomp Engineering is excited to work with KW Suspensions yet again to offer an excellent double adjustable coilover at an affordable price to 2008 and 2009 Subaru Impreza WRX owners.
In stock and ready for delivery now!!!
Give us a call at 410-579-1501! We love to talk suspension...so if you need any help or advice, we can provide insight backed up by years of on track experience!
FREE KW Polo Shirt or T-Shirt with purchase of RCE or KW coilovers! For a limited time only.
Bushigns for GR STi
Bushings:
- adds caster
- removes anti-lift
$137
- $80
$63
Each of these reduces some of the stock sloppiness, less deflection, improves steering feel. All around makes your car just feel a lot better. The front control arm bushings are AWESOME.
__________________
410-846-5407
Old 07-02-2009, 01:32 AM   #6
McDougal
Member Sales Rating: (6)
Member#: 97576
2006 Evolution
Any wagon springs in this deal?
McDougal is offline
Old 07-02-2009, 06:55 AM   #7
TheNailman
Member Sales Rating: (46)
Member#: 133676
2005 WRX
DOH! guess i shoulda taken ya up on your offer!
TheNailman is offline
Old 07-02-2009, 03:04 PM   #8
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Nope. We need more interest in the wagon springs to make another batch. If we get 20 orders we can do it.
Myles
__________________
410-846-5407
Old 07-06-2009, 05:30 AM   #9
Fierysun
Member Sales Rating: (103)
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Free Bump.
Will your RCE front 25.5/28.5 sway bar work on a 03 Wagon?
Fierysun is offline
Old 07-06-2009, 11:24 AM   #10
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Originally Posted by Fierysun View Post
Free Bump.
While WE have never tested it several wagon owners have bought it and love it.
Myles
__________________
410-846-5407
Old 07-06-2009, 04:23 PM   #11
jigga
Member Sales Rating: (16)
Member#: 9960
2002 Impreza WRX
WRBlue Perl
how long is this sale going on for?
jigga is offline
Old 07-06-2009, 04:37 PM   #12
STiLLawd
Member#: 213227
dang where was this sale 3 weeks ago...
STiLLawd is offline
Old 07-06-2009, 04:47 PM   #13
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
dont know, but these deals wont last.
Do it NOW !!
lol
Myles
__________________
410-846-5407
Old 07-06-2009, 06:03 PM   #14
Fierysun
Member#: 82745
2005 Subaru STI
Myles
What do i need to do to make it work?
Fierysun is offline
Old 07-06-2009, 06:18 PM   #15
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Nothing based on the feedback we have from other wagon owners....but again...we never tested it here. We have 6-7 wagons out there with these on them, most have the STI rear lateral arms and sti links.
Myles
__________________
410-846-5407
Old 07-06-2009, 08:09 PM   #16
Fierysun
Member#: 82745
2005 Subaru STI
Myles
Actually, I was thinking about your front bar and not the rear.
Fierysun is offline
Old 07-07-2009, 02:27 PM   #17
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Front works fine based on the feedback from other owners.
Myles
__________________
410-846-5407
Old 07-13-2009, 03:47 PM   #18
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Bump it up!
__________________
410-846-5407
Old 07-16-2009, 01:41 PM   #19
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
To the Top!
__________________
410-846-5407
Old 07-18-2009, 06:59 AM   #20
sauuce
Member Sales Rating: (11)
Member#: 109253
2006 STi
SGM
going nuts trying to come up with spare money for the T2's. please let this sale last until i have enough free bump for great people
sauuce is offline
Old 07-20-2009, 02:46 PM   #21
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
best bet is to stay in touch with me directly.
racecompengineer@aol.com
Myles
__________________
410-846-5407
Old 07-22-2009, 03:16 PM   #22
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Bump for awesome Nasioc peeps!
__________________
410-846-5407
Old 07-30-2009, 04:50 PM   #23
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Bump for: Sweet STi Suspension Specialties Summer Sale!
__________________
410-846-5407
Old 07-30-2009, 05:37 PM   #24
Rodwrx23
Member Sales Rating: (76)
Member#: 170948
I'm interested in your Front sway bar for my 2003 WRX. Does the price listed above include shipping and the bushings?
Rodwrx23 is offline
Old 07-30-2009, 06:16 PM   #25
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Keep in mind we have guys with WRX's who bought these and say they work fine, but the fitment is 04-07 STi and each car can be different. With that said I see no reason why it wouldnt work.
209 shipped, not many left so call soon.
mw
__________________
410-846-5407
Closed Thread
Racecomp rolls the clock back with 2007 prices!! 2nd Annual RCE Summer Sale !! RaceComp Engineering Suspension/Brakes/Handling 31 09-14-2009 11:43 AM
RCE Summer sale - TiC will be price matching!!!! Turn in Concepts Suspension/Brakes/Handling 1 08-03-2009 02:19 PM
RCE Summer sale - TiC will be price matching!!!! Turn in Concepts Vendor 'General Sale' Forum 0 07-08-2009 06:41 PM
Racecomp's Annual Big SUMMER Sale! RaceComp Engineering Suspension/Brakes/Handling 110 10-03-2008 12:19 PM
2nd Annual Biggest Exhaust Sale Ever, 30+ Espelir Systems and TurboXS Sytems rdy 2 go WorldOne Engine/Power/Exhaust 27 05-14-2004 03:36 PM
