Old 06-30-2009, 12:05 PM   #26
SteveTC
Member#: 118552
2010 JuSTI
Originally Posted by camaroz1985 View Post
Steve what final drive does your car have? I was touching the rev limiter in 4th right before "Oh ****"
I'll try to get some video up soon too.
Not sure what ratios are in there. What kind of speed does that come in at? Maybe putting videos side by side may give a fell for how fast I was going. I need to do some work on figuring it out when I change the clutch, it is pretty well smoked after my last run. I was about half throttle in 4th, but it was fast enough for the first time on the mountain. Were you running the blue RS? I think I have awefully high gears in transaxle. I am thinking about building one with lower final drive and closer ratios since I have a 5MT (I think) in there, just not AWD. Also, want to add a limited slip or locker of some sort.
SteveTC is offline   Reply With Quote
Old 06-30-2009, 05:24 PM   #27
camaroz1985
Member#: 155906
1998 Impreza 2.5RS
Rally Blue
Yeah I had the blue RS. I have factory 4.11 gearing though, and with my tires it comes out to about 103 at redline in 4th. What is your transmission out of?
camaroz1985 is offline   Reply With Quote
Old 06-30-2009, 07:13 PM   #28
Storm
Member#: 5218
96L Most Over-
Developed Beater
Being a 5spd, I think you should be able to use the gearset from a 2.5RS. The RS uses close ratio gears and a 4.11:1 final drive. Even if you can't, the front diff shouldn't be any different than an AWD trans. If that is the case, you can get an OBX helical LSD for less than $500, or step up to an old skool JDM suretrac front LSD. Phantom grip should have an application as well....though I can't really recommend it.
Jay
Old 07-03-2009, 10:04 AM   #29
scoobsnack
Member#: 85130
01 GC
04 FXT
If you want an easy way to know your speed just throw a handheld gps in there
looks like a fun project!
scoobsnack is offline   Reply With Quote
Old 07-04-2009, 07:50 AM   #30
SteveTC
Member#: 118552
2010 JuSTI
Not sure if it would work with the tree cover as a few guys have gPS based systems like Trackmate and they do not work. Also, I am not sure if I want to take my eyes off the road long enough to look. Maybe I can get one within view of the camera. Thanks,
Steve
Old 07-04-2009, 12:46 PM   #31
Subie22
Member#: 133355
'06 WRX Limited
'15 Tacoma SR5
Sick project. Where are you at in NEPA? I'm in Moscow about 10 mins. outside of Scranton.
Subie22 is offline   Reply With Quote
Old 07-05-2009, 09:27 AM   #32
SteveTC
Member#: 118552
2010 JuSTI
Just southwest of Wilkes-Barre headed toward Rickett's Glen State Park.
Giant's Despair Hill Climb is next weekend in Wilkes-BArre, and I will be racing it there if you want to stop by. Hoping my clutch will be here in time.
Old 07-06-2009, 01:52 PM   #33
OddBallRacing
Member#: 136429
1996 ImprezaBrighton
Gawdawful Green
Awesome! I'd love to know/see more on how you make the tranny work in a mid-engine setting, which one you used, etc. How long is the package from the front of the motor to the back of the tranny? -or- What is the shortest length space that package would fit in? I've tons of questions!
Enjoy!
Karl
OddBallRacing is offline   Reply With Quote
Old 07-07-2009, 08:04 AM   #34
SteveTC
Member#: 118552
2010 JuSTI
Enjoy!
Karl
From front of engine to back of shifter rod it is 46-3/8". It just moves straight back with the same orientation as in a front wheel drive. Trans is from a FWD legacy 5MT. The tough part is the transmission shifter linkage as it is one long rod from shifter a universal, and then a 30 degree bend and into the standard location like the formula vees run.
Old 07-07-2009, 09:19 AM   #35
tuellma
Member#: 42291
1997 GF8 STi
Light Silver
that is amazing
can't wait to get back to land where I can watch the videos.
tuellma is offline   Reply With Quote
Old 07-07-2009, 10:16 AM   #36
Storm
Member#: 5218
96L Most Over-
Developed Beater
Steve, did the chassis start as a vee? Is it completely one-off?
I don't recall what the front uprights are from.....Subaru? FVee?
Jay
Old 07-08-2009, 07:38 AM   #37
SteveTC
Member#: 118552
2010 JuSTI
Jay
Hand designed and built chassis. Front Camaro spindles, rear are from an SVX. All tied together with race car components to reduce cost and weight. Not a VDUb part to be found on it.
Steve
Old 07-08-2009, 08:44 AM   #38
Storm
Member#: 5218
96L Most Over-
Developed Beater
Steve
Thank god!!!!
All the more kudos for designing and building the chassis too!!!! That takes some serious talent.
Jay
Old 07-09-2009, 09:08 PM   #39
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
Whats the updated weather report for giant's despair and where are the front wing pics??
dm
dwmoss_68 is offline   Reply With Quote
Old 07-10-2009, 11:25 PM   #40
SteveTC
Member#: 118552
2010 JuSTI
dm
You just keep sipping your margaritas on the sand.
Here's your pic:
And another:
Chance of thundershowers tomorrow afternoon.
Ed, Mark Z, and Scott got axe today...
Old 07-10-2009, 11:32 PM   #41
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
If the FWD 5 speed is umodified you might consider at least changing its final drive to 3.9 if not 4.11. For the most part the FWD five speeds were 3.7:1 final IIRC!
ciper is offline   Reply With Quote
Old 07-10-2009, 11:51 PM   #42
SteveTC
Member#: 118552
2010 JuSTI
ON THE LIST OF WINTER ENHACEMENTS, ALONG WITH A POSITRACTION UNIT.
Old 07-11-2009, 03:01 PM   #43
Storm
Member#: 5218
96L Most Over-
Developed Beater
I can send you an AWD front diff (open type) to test fit and confirm compatability inside the FWD trans. That will open up a few choices for LSD's you can work with!!!
PM me an address.
The front wing looks strong!!!! You sir, have some incredible fabrication skills.
Jay Storm
Old 07-12-2009, 09:30 AM   #44
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
did i miss where you said you built from scratch the chassis?
or is it a hybrid chassis from some other class?
I would like to find one that allow usage of our awd drive train.
that way I can get a "high gas mileage" car..
Old 07-12-2009, 10:45 AM   #45
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
If I keep drinking my chambord margaritias waiting for your updates I'll be too loaded to read this thread!!
Here's a link I found from the times leader for day 1.
good luck today and the front wing looks good
dm
jaxscuby: he did build the chasis from scratch btw
Old 07-12-2009, 08:42 PM   #46
SteveTC
Member#: 118552
2010 JuSTI
Had some trouble Saturday, got to 57.0 and got under a minute which was my goal. Found out if you plug in both test connectors, it will bypass limp mode and run like a demon. My best was 51.56 and was next to my last run.
On my last run, I was hauling up until the last turn, so watch at 1:25 or so.
Also, frank videotaped one run from outside, which was not my best, but can be seen here:
86 cars, probably in the top 30 and missed a trophy by .3 seconds.
Old 07-12-2009, 10:56 PM   #47
Storm
Member#: 5218
96L Most Over-
Developed Beater
WOO HOO!!!!
That looks like a TON of fun! Nice job!!!!! Track down those little issues and up the boost!!! Might need a bit more downforce!
Jay
Old 07-12-2009, 11:52 PM   #48
ciper
Member#: 15543
90BJ Legacy LS ABS
I am 99.9% sure they are the same but I can't find the info.
Even if not he could use an AWD transmission with a welded center differential and plug on the tailshaft. Thats what the dune buggy guys do!
Old 07-13-2009, 12:11 AM   #49
Storm
Member#: 5218
96L Most Over-
Developed Beater
True......but the FWD trans has a couple other interesting destinations where a modded AWD trans wouldn't be practical (or allowed by pesky rules).
Maybe someone can run a crosscheck on part numbers.
Jay
Old 07-13-2009, 12:51 AM   #50
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I'd place money that the diffs are the same...however I know you can just weld the center diff in an awd setup and run that way.
I'd be QUITE interested to see your shift linkage setup at the rear of the trans.
What to do with an old, dead car? speedblind Off-Topic 10 06-08-2005 11:05 AM
What to do with an SVX? Khalil Alaskan Impreza Club Forum -- AKIC 21 04-12-2005 12:56 PM
What to do with an IP address? XXX.XXX.XXX.XXX Gravel Girl Off-Topic 11 11-18-2004 02:51 PM
Help - what to do with an injured bird? Sharkbait Off-Topic 26 09-02-2004 05:08 PM
what to do with an old laptop Fish Off-Topic 26 08-13-2004 02:42 PM
