Welcome to the North American Subaru Impreza Owners Club Sunday September 5, 2010
Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 07-14-2009, 09:53 AM   #1
JamesHenry
Member#: 137819
2005 Subaru WRX
1987 Subaru BRAT
Default 1987 Subaru BRAT
I picked up a 1987 Subaru BRAT. The Subaru BRAT had one crucial design flaw that made them go to the junk yard well before they had to – rear strut mount welds. The rear struts mounts are welded onto an L shaped bracket that sadly allowed water/salt to sit behind the welds. This in turn rotted the fender wells in the bed. My BRAT is no different. I consider it the most damaged part on the vehicle.
However, that isn’t all the rust. The driver side door has been completely rusted out on the lower corner. A new door is a must. There is also a little frame rot that needs to be replaced. It’s just something that with time and hard work, it can be fixed.
After running into a little bit of a fiasco with the title, I managed to track down the original owner and get the title signed. He told me some history about the truck. It’s been across the U.S. four times, lived most of its life in Mississippi, had the rear chrome piece broke off by kids on Halloween, leaks some oil and just had a new exhaust, catalytic convertor, rotor/distributor and wires put on it before he sold it. The one fender is darker than the rest and he said that’s how he purchased it from the dealer – he guesses it was damaged prior to him getting it.
Sadly, the project has been on hold for the last 6-7 months. I just got married and moved into a house so I now have a place to store and work on the BRAT – under a carport. The first thing I did was checkout the rust and underneath the vehicle – I was surprised that it wasn’t worse. I also dropped a battery in it to check for leaks. After letting it idle for a good 20-30 minutes, I looked under the car – NOTHING. Not as so much as a little drop. I then drove the car back and forth in the parking lot – in and out of 4WD and everything went smoothly. It runs/idle’s great for being a year and a half old gas.
I also wanted to take notice of the oil pressure, RPM’s at idle, and engine temperature before ripping the engine out. While it was running, I rinsed out the engine bay. It had a ton of pine needles, leaves, etc – great for allowing rust to start eating away at the metal. I washed it, but the clear coat is so far gone its beyond help. It will get repainted the original color it was from factory.
Another reason it sat for so long was because I was debating what I wanted to do with it. Drop a WRX drivetrain in it? Lift it and create an off-road beast? After a long 6-7 months thinking about – I decided to pretty much keep it how it was from factory. For one, it’s the cheapest. Two, it’s the easiest. Three, it’s much more badass. It’s not often you see you a BRAT and when you do, it’s usually lifted or it has a STi drivetrain in it so I decided to keep it as it is since 4WD lo and hi works and the engine runs fantastic.
I don’t plan on restoring this to show-room quality but I also don’t plan on driving it every day. If there is a truck show in the area, I’ll enter it to represent Subaru. If there is a Subaru show in the area, I’ll enter it just because I’m sure I’d be the only one and I’m sure a lot of people would ask questions about it.
Typical rust in the bed.
Little bit of rust on the passenger side.
There shouldn't be a hole there...
Shouldn't be a hole here either...
Door cancer.
I'd say something about the seat, but every time I think about it I can just taste cigarettes from the original owner.
Oil pressure is around 25-28psi. It runs on the warmer side, though.
5 Speed Manual with Dual Range (hi/low) transfercase for 4WD-sweetness.
Is there anymore more American than a Subaru Brat, a Subaru Impreza WRX, and an American flag? I think not.
Here is the short list for getting it back up to speed. It doesn't include new hoses/new fluids/metal for repairing rust.
Axle & Driveshaft
C.V. Joint Boot Kit
Belts
Timing Belt
Brake Components & Wheels
Front Brake Disc
Rear Brake Hose
Rear Brake Shoe Set
Rear Brake Hose
Clutch Components
Clutch Kit
Release Bearing
Cooling Components
Radiator Cap
Lower Radiator Hose
Thermostat
Thermostat Gasket
Water Pump
Electrical
Alternator Belt
Spark Plug
Engine
Air Filter
Intake Manifold Gasket
Complete Engine Gasket Set
Cylinder Head Gasket Set
JamesHenry is offline   Reply With Quote
Old 07-14-2009, 09:54 AM   #2
JamesHenry
Member#: 137819
2005 Subaru WRX
1987 Subaru BRAT
On a side note: if anyone knows of a door (GL wagon doors fit) or the rear chrome piece, let me know!
Old 07-14-2009, 11:46 AM   #3
IETVTS2
Member#: 186775
2007 LTD STI - 00 RS
SWP / BRP
Your patronage and your selection of cars are the same as mine.
2 Subis and a American Flag...LOL
It doesn't get any better than this...
IETVTS2 is online now   Reply With Quote
Old 07-14-2009, 07:52 PM   #4
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
View Member's Myspace Profile
are you SURE its a 5 speed.... its probably a 4 speed unless someone put in one of "Jerry's" kits
Flowmastered87GL is offline   Reply With Quote
Old 07-15-2009, 12:00 AM   #5
TurboneX
Member#: 21676
I wouldnt worry about the timing belt either.........it doesnt have one
But considering where the Brat is from, that rust isnt really bad and with some work can be repaired.
A good source of parts and info is over at http://www.ultimatesubaru.org/forum/...isplay.php?f=2
IETVTS2 - Your patronage and your selection of cars are the same as mine.
Try 4 at the house and 4 more at a friends
TurboneX is offline   Reply With Quote
Old 07-15-2009, 09:19 AM   #6
rexspeedworthy
Member#: 26965
2008 STi/09 Leggy
Silver/Grey
Nice, you're describing my Brat to a tee. I have an 85. Make sure you adjust the hill-holder properly, and you will really like it. My fender rot is worse than yours You also may wanna make sure the heat shield is on the exhaust by the passenger driver axle, or you'll replacing that inner boot more than you want. If you're fully warmed up, that does seem a little hot for it to be running. How's the rad? Mine is missing many fins, and runs that hot when fully loaded with 4 people trying to go up a hill. yeah and 4spd for sure. I guess the stock shift knobs sucked, because I have a 5 spd knob on mine, but it's only a 4 spd tranny. Good luck with it, keep us posted.
BTW, i still have many of these parts for sale
Not so much the bed rails
http://forums.nasioc.com/forums/show....php?t=1615160
rexspeedworthy is offline   Reply With Quote
Old 07-15-2009, 12:52 PM   #7
JamesHenry
Member#: 137819
2005 Subaru WRX
1987 Subaru BRAT
Haha that explains that. I'm still learning a lot about cars so this is somewhat of a learning vehicle to work on... heh.
I don't have the slidest idea what the hill-holder is... lol. I'll have to google it. The passenger inner boot is torn .
I'm sure the rad is full of crap for being 22 years old and sitting for the last few years lol. I new radiator isn't out of the question, but not moving idling for a good 20-30 minutes it didn't jump any higher than that.
Its def. a four speed lol. I've only ever gone in first and reverse so I checked and there is no fifth gear .
I'll post more on my website about the work.
Old 07-15-2009, 03:01 PM   #8
rexspeedworthy
Member#: 26965
2008 STi/09 Leggy
Silver/Grey
I have an awesome PDF file for you. It explains these older Subies great.
PM me your e-mail address, and I'll send to ya when I get home. I't like a chilton or what ever manual, but better, and with comedic interjections.
Ken
Old 07-15-2009, 03:19 PM   #9
TurboneX
Member#: 21676
Ken
Its called "How to Keep Your Subaru Alive" and is a great manual for the Old School Subaru's.
Old 07-15-2009, 03:34 PM   #10
rexspeedworthy
Member#: 26965
2008 STi/09 Leggy
Silver/Grey
That's the one. It explains the hill-holder good.
Old 07-15-2009, 06:20 PM   #11
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
hill holder in a nutshell
Come to a stop facing uphill.
Press clutch and brake. Make sure you push brake all the way.
Let go of brake
if adjusted properly, the hill holder will maintain brake pressure so the car wont roll back until the clutch engages. It can be tricky to adjust it the first time.
Old 07-15-2009, 07:42 PM   #12
JamesHenry
Member#: 137819
2005 Subaru WRX
1987 Subaru BRAT
Let go of brake
Ha, I think I may have encountered this today! I had the car up on ramps and as I was backing down I had the clutch and the brake pressed in. Then, whenever I tried to go, it was like instantaneous brakes. I was confused but it went away.
Old 07-15-2009, 08:23 PM   #13
JamesHenry
Member#: 137819
2005 Subaru WRX
1987 Subaru BRAT
Old 07-15-2009, 09:37 PM   #14
rexspeedworthy
Member#: 26965
2008 STi/09 Leggy
Silver/Grey
YouTube - 1987 Subaru BRAT Video of it running
Runs smooth. That belt sure is straight too. Now, if you gonna go through all that trouble, at least give us a good walk-around the car. You got the seats in the back?
Old 07-15-2009, 09:38 PM   #15
rexspeedworthy
Member#: 26965
2008 STi/09 Leggy
Silver/Grey
crap, Hotmail won't send a file bigger than what I'm trying to e-mail you. Any ideas?
Old 07-16-2009, 09:11 AM   #16
JamesHenry
Member#: 137819
2005 Subaru WRX
1987 Subaru BRAT
I can give you temp guest access to my FTP so you can upload it to my server . It'll have to wait until I get out of work, though.
LOL. Sorry, something shiny or a rubber band got my attention. I took more pictures of it yesterday after I was done doing a rust inspection . I'll try to post them up tonight.
Old 07-17-2009, 08:05 AM   #17
rexspeedworthy
Member#: 26965
2008 STi/09 Leggy
Silver/Grey
It' Friday, I gotta remember to bring it to work monday (it's on an sd card)
I'm sure I can send it from my work address. What you suggested went over my head.
Old 08-10-2009, 03:24 PM   #18
JamesHenry
Member#: 137819
2005 Subaru WRX
1987 Subaru BRAT
I'll PM you my work email.
Old 08-20-2009, 09:59 PM   #19
RallyBlue
Member#: 69323
2004 WRX
82 BRAT
I got an 82 with the Cyclops eye! its a desert car so no rust in the usual places.
RallyBlue is offline   Reply With Quote
Old 08-21-2009, 07:00 AM   #20
rexspeedworthy
Member#: 26965
2008 STi/09 Leggy
Silver/Grey
Those cyclopseseses are great, I fabbed one into aa '79 DL
hey OP, you need to find one of these lights. They are a real attention getter...as if the Brat ain't already.
Old 08-21-2009, 12:12 PM   #21
JamesHenry
Member#: 137819
2005 Subaru WRX
1987 Subaru BRAT
Haha that sounds like a project. It does look funny as hell though LOL.
rexspeedworthy -- I never got the email
Old 08-25-2009, 05:09 PM   #22
STI-NKR
Member#: 176512
2006 STI, 2010 Prius
Wow, I wish my brat was that clean, but mine's been sitting in a junkyard for 8 months, clean title though and it drove off the trailer into my shop. I'll get some pictures up by tonight. Oh yeah, no rust.
I love my lil 81 and im pretty sure its gonna be badass, oh yeah, on the twin stick 4x4s, since my knob is gone what is the pattern for the 2wd and 4wd modes?
STI-NKR is offline   Reply With Quote
Old 09-21-2009, 05:00 PM   #23
ninefourteener
Member#: 104414
SUBY 06WRX 07TRIBECA
78BRAT 94SVX-LSi
Been working on my 78 for nearly a year now..... LOTS of work.... lots of rust... but it'll be worth it in the long run. Bodywork is almost done.
9 pages long last time I checked.... so give yourself a few minutes:
http://www.clubwrx.net/forums/engine...ss-thread.html
ninefourteener is offline   Reply With Quote
Old 09-22-2009, 09:21 AM   #24
TurboneX
Member#: 21676
If its a dual range, it should be 2wd/4wdLow/4wdHi
Old 09-28-2009, 02:05 PM   #25
deathwagon
Member#: 225124
1986 GL-10 Turbo
Brown
brats are awesome
deathwagon is offline   Reply With Quote
Bookmarks
WTT: 1987 Subaru DL/STI station wagon--- ultimate sleeper gqzboy Private Vehicle 'For Sale' Classifieds 25 03-12-2006 12:50 AM
FS: 1987 Subaru RX Subarutex NWIC Private Classifieds 9 01-07-2006 02:47 PM
1987 Subaru RX Turbo project help... Stime187 South East Region Forum 14 10-17-2003 03:59 PM
Subaru brat of all brats gongeuzler North West Impreza Club Forum -- NWIC 13 07-20-2002 04:24 PM
1987 Subaru wagon - any thoughts? efoo Technical Forum Archive 14 09-19-2000 11:36 PM
Message Board Statistics All times are GMT -4. The time now is 09:16 PM.
