Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 07-15-2009, 02:38 PM   #1
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Default Element Tuning's Hydra Nemesis 2.6 Tuning Tips
I want to help you guys with any specific questions you may have in regards to tuning the Hydra 2.6 (only) so please ask your questions here. What I may do is start the tuning guide with which ever questions you ask first.
Here are some basics:
The first step in using your Hydra 2.6 is to connect to your Hydra so you can see the base map we've installed for you. Open the 2.6 software to tools/system tools/preferences:
Here is how I like to set up my tuning software. What's critical is that you assign the correct COM port so the software can connect to your Hydra. Only use a RS232 Serial Port or a RS232 Serial Card (please don't bother asking me how to get your USB adaptor to work because they are just too problematic). You can copy exactly how I have my software setup if you like.
Enabling the VE Substrings "AFR Error" is really great as it will tell you what percentage your fuel map is off by in the cruise areas. For instance if one of the load cells says 1.535 and you highlight that cell and click "Q" the Hydra will apply the 1.535% correction to that cell. The correction is based on what you have in your "Target AFR Table." Click "Save and Exit" to make these changes permanent.
At this point you can start editing your map to calibrate your WB 02 sensor and the throttle.
I will reserve some spots to continue with these tips.
Thanks,
Phil
Element Tuning.com
Element Tuning is offline   Reply With Quote
Old 07-15-2009, 02:39 PM   #2
Element Tuning
Member#: 54918
673 WHP Element
I'm going to jump ahead a little farther than I want to get some basic tuning information out there. The key to editing the maps quickly is to know what the shortcut keys are.
One of the most important items in my opinion is the mass edit keys. use the "arrow" keys and then the "ctrl" key to highlight a section of fuel or timing cells for instance. Now all you have to do is hit "V (divide), M(multiply), A(add), or S(subtract) )" type in a value, say 1 and then hit "enter" and that values will be added, subtracted, etc to that group of highlighted cells. Editing one cell at a time is sometimes neccessary but often you will be working with an RPM range for instance that needs to be leaned out and these keys will be the fastest way to get to your target AFR for instance.
I also always use the extrapolation keys, X and Y to smooth the maps or even to anticipate what the fuel map should be at 30 psi when I've only tuned the car to 15 psi so far. When tuning in injector pulse width the fuel map will look very linear from 0 psi all the way to 30 psi so using the "Y" extrapolation for load can really speeds tuning up. Let's say your fuel map is tuned up to 15 psi and you want to rough in the map all the way to 30 psi. Estimate what the 30 psi load cells will look like (copy the shape of the 15 psi cells but increase the fueling).
Simply highlight the 0 rpm to 8300 rpm cells at 15 psi, then all the way to 30 psi.
Select "Y" and a screen will pop up with how the changes will look.
If you like what you see hit the "OK" button to make the changes permanent.
More to come.
Thanks,
Phil
Element
Old 07-15-2009, 02:39 PM   #3
Element Tuning
Member#: 54918
673 WHP Element
Reserved for continued tips 3
Old 07-17-2009, 08:56 AM   #4
n2oiroc
Member#: 141952
15 legacy 16 wrx
you have been a great help so far, but i think tuning boost and the starting maps would be something to start with. its what i have been having the most trouble with and i imagine im not the only one. also any tips on hotkeys would be great!
n2oiroc is online now   Reply With Quote
Old 07-17-2009, 11:58 AM   #5
RealStreet
Member#: 205916
2003 Subaru WRX
in the 10's and the bends
How about a list of all the known quirks. I know it's very time consuming trying getting around some of these issues you may spend hours trying to fix only to be told "that's just the way it is".
RealStreet is offline   Reply With Quote
Old 07-17-2009, 02:04 PM   #6
Element Tuning
Member#: 54918
673 WHP Element
Tuning boost is the most difficult and least intuitive to tune. I consider this advanced tuning so I'm not going to cover this first but I will cover this for sure. Hopefully Hydra EMS will implement the changes I want for hte boost control system which will make it much easier an intuitive to tune.
I've just posted some editing and hot key tips.
Thanks,
Phil
Old 07-17-2009, 02:06 PM   #7
Element Tuning
Member#: 54918
673 WHP Element
Since I know the software so well I don't know of any quirks as I may have just worked around them. Give me three things you find are "quirks" and I'll post tips or solutions to them.
Thanks,
Phil
Element
Old 07-25-2009, 08:59 AM   #8
n2oiroc
Member#: 141952
15 legacy 16 wrx
how about cold starting. when its 80 out it starts great, when its 60ish and colder it chugs along at 1,200 rpm or so (target is 1,500) and vacuum is 12" or so compared to 20" normally. i tried adding and subtracting fuel and it makes no difference. after a couple minutes it just snaps right out of it and runs normal.
Old 07-30-2009, 02:55 PM   #9
tolishel
Member#: 199605
98 04 Sti legacy
Black/White
How to setup Anti-lag?
tolishel is offline   Reply With Quote
Old 08-03-2009, 11:19 AM   #10
Element Tuning
Member#: 54918
673 WHP Element
Ok the couple minutes and it's fine is a key sign. Typically when the car is excessively rich at start (low idle and vacuum is a sign of this) but cleans out after 1-2 minutes it's due to the "Post Start Enrichment" and "Post Start Enrichment Decay." Basically you need to reduce your post start at the colder coolant temps and possibly the decay time also. First start by reducing the "Post Start Enrichment" only at the coolant areas where you are having issues.
Post Start Enrichment: This is used to increase fueling right after the engine starts to help stabalize the idle. This settings varies quite a bit if you have an engine with cams, TGV deletes, porting, etc vs. a standard engine.
Post Start Enrichment Decay: This how long you want the Post Start Enrichment to remain active the engine starts. Typically this is set to 60-120 seconds but decays the fuel enrichment over time.
Thanks,
Phil Grabow
Element
Old 01-25-2010, 09:20 PM   #11
AdamBOMB_STi
Member#: 103419
04.7 STi
LA Sleeved 2.5,35R,Hydra
bump for more tips!
AdamBOMB_STi is offline   Reply With Quote
Old 06-05-2011, 12:42 AM   #12
Spurs442
Member#: 119876
2008 LGT
Phil,
I'm having some idle issues with a 2.5 hybrid in an 03 wrx. I am having issues getting my O2 sensor to work properly so i'm using an Innovate and have closed loop turned off. if I get the car to idle around 14.7 with the fans off, when the fans turn on it goes super lean. if I get the idle @ 14.7 with the fans on it drops to 12.5 to 13 when the fans turn off. what am I missing?
Spurs442 is offline   Reply With Quote
Hydra Nemesis 2.6 and DashDaq anubis328 Other Engine Management 0 10-01-2008 01:45 PM
Element Hydra Nemesis 2.6 Sneak Preview Element Tuning Other Engine Management 101 07-23-2008 12:17 PM
New Element Tuning Hydra Nemesis 2.6 Release Details Element Tuning Other Engine Management 26 06-11-2008 06:19 PM
New Hydra Nemesis 2.6 Awesome New Features Element Tuning Other Engine Management 113 04-18-2008 01:06 AM
04 STi Element Tuning Hydra Nemesis 2.5 berserksti Engine/Power/Exhaust 11 10-10-2007 11:54 PM
