Old 07-19-2009, 01:51 PM   #1
cruizer
Member#: 213323
Default FP 68HTA 2.0 bugeye
I normally don't post up here but since this turbo is fairly new I decided I would help some people to make their decision on buying one. My previous setup was with a FP 16g and side by side the two turbos look exactly the same except for the wheel size. Stock block, tranny, and clutch 02 wrx on 93 pump with 90 degree temps outside. 20 psi.
Mods:
FP 68HTA
DW 750's
walbro 255
perrin fuel rails
ultimate racing uppipe
tial 38mm EWG
TXS turbo back
TXS front mount
perrin inlet
GT spec unequal headers
HOA 3 port BCS
ported TGV's
NGK one step colder plugs
320whp 300wtq
cruizer is offline   Reply With Quote
Old 07-19-2009, 03:07 PM   #2
Str8Gone
Member#: 147972
2004 wrx hybrid 18g
[email protected] dd
the topend looks great
Str8Gone is offline   Reply With Quote
Old 07-19-2009, 03:54 PM   #3
focusfuri75
Member#: 142011
nice numbers, must be fun to drive
focusfuri75 is offline   Reply With Quote
Old 07-19-2009, 04:26 PM   #4
cireturbo
Member#: 119777
2013 BRZ
Was the only difference in these tunes the turbo, or were other supporting mods added?
cireturbo is offline   Reply With Quote
Old 07-19-2009, 04:37 PM   #5
MConte05
Member#: 158579
2005 Lotus Elise SC
94 Legacy Rally Car
Do you have a previous dyno plot of your 16G? Which would you say spool's quicker?
MConte05 is offline   Reply With Quote
Old 07-19-2009, 04:39 PM   #6
cruizer
Member#: 213323
The graph is just the 68HTA. I don't have numbers for the 16g. The lower numbers were around 14 psi.
Old 07-19-2009, 04:40 PM   #7
cruizer
Member#: 213323
The 16g spooled a bit quicker.
Old 07-19-2009, 05:53 PM   #8
Foska Oats
Member#: 144081
Yep, I made up my mind on this turbo a few weeks ago
Foska Oats is offline   Reply With Quote
Old 07-19-2009, 05:58 PM   #9
claycron
Member#: 181941
2004 Forester XT
AW
Thanks for the results, I think this turbo really wakes up with the addition of EWG and ELH
claycron is offline   Reply With Quote
Old 07-19-2009, 05:59 PM   #10
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Spool doesn't tell the whole story. This turbo flows more so should make more power at the same boost. What's important is if it makes as much power as quickly .
Not to be rude, but showing us a graph is all good and great, but you haven't really told us what you thought in comparison to the FP16G. And which 16G was it that you had before?
Audiosavvy is offline   Reply With Quote
Old 07-19-2009, 06:02 PM   #11
rubinm
Member#: 63483
2005 STi HTA68'd+e85
nice results!
should be a blast to drive
rubinm is offline   Reply With Quote
Old 07-19-2009, 06:11 PM   #12
06-wrx-tr
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
so can this turbo hold 18 psi to redline at 4600 ft asl?
06-wrx-tr is offline   Reply With Quote
Old 07-19-2009, 07:22 PM   #13
cruizer
Member#: 213323
The car feels like it has a lot more top end than the 16g. Also when this thing spools up it really takes off. Power comes on just like the 16g but more violently. Full spool is maybe a couple hundred rpms later.
Old 07-20-2009, 08:02 AM   #14
ramair18954
Member#: 28308
03 td-06 wrx ra-c
Platinum
not bad i made 320/320 on their 18g. seems its making the same results. Nice!
ramair18954 is offline   Reply With Quote
Old 08-17-2009, 08:58 PM   #15
ICanRunLikeanSTI
Member#: 84729
05 WRX STI
how do you like your injectors? (dw 750) i got the same ones... but compared to what others are running im thinking they might get close to max-ing out... what do you think?
ICanRunLikeanSTI is offline   Reply With Quote
Old 08-18-2009, 12:29 AM   #16
cruizer
Member#: 213323
750's are probably the smallest you should go. Check out this chart.
http://www.jscspeed.com/wrx/turbo/injector_sizing.htm
Old 09-16-2009, 10:45 AM   #17
cleanrex05
Member#: 197535
2005 Wrx
FP HTA68 powered
hey cruzier, how is the car doing? I have 2005 WRX and planning on getting the same turbo. Just wondering if you have had any problems since the last post. Thanks.
cleanrex05 is offline   Reply With Quote
Old 09-16-2009, 02:36 PM   #18
Highway Drifter
Member#: 81013
Yea I'd definitly like a follow up on this turbo too, been a couple of months now since you got it installed.
Highway Drifter is offline   Reply With Quote
Old 09-17-2009, 03:50 AM   #19
ramair18954
Member#: 28308
03 td-06 wrx ra-c
Platinum
hmm im at 70% duty cycle on dw740's and running 25psi?!
Old 09-17-2009, 01:20 PM   #20
Ammata
Member#: 155819
2004 Impreza WRX
Where are you seeing full boost at?
Ammata is offline   Reply With Quote
Old 10-13-2011, 04:21 PM   #21
Foska Oats
Member#: 144081
I have this turbo on my 03 WRX and it halls a$$ from just before 4k RPM all the way to read line. It kicks my gate remote out of the din under the radio, straight to the back seat when the boost kicks. I have it at 27psi on piss 90 pump gas with Meth/water 50/50. I havent dyno as yet, but I will as soon as I change the dead clutch.
LOL
Old 10-14-2011, 11:16 AM   #22
Dr. octagon
Member#: 171127
2015 Subaru
LOL
You are EJ207, correct?
Dr. octagon is offline   Reply With Quote
Old 10-14-2011, 09:34 PM   #23
ullrichv2
Member#: 211247
OP how many miles on your subie?
ullrichv2 is offline   Reply With Quote
Old 01-01-2012, 12:51 AM   #24
05grosrygettr
Member#: 301993
2005 WRX Wagon
was this the 7cm or 8cm exhaust housing? im going to be running almost the same mods as you only different brands and i just ordered all my parts today so im excited to see how it turns out when i get home from this deployment!
05grosrygettr is offline   Reply With Quote
Old 01-01-2012, 10:44 AM   #25
roof_rack
Member#: 257866
idk if its just me, but why does so much of the power look like its so far to the right? that small of a turbo i would think boost comes on a bit earlier?
roof_rack is offline   Reply With Quote
2.2 heads on a 2.0 block chong74 Subaru Conversions 24 06-06-2010 03:41 AM
fp green 2.0 users smileyou Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-07-2008 01:47 PM
18g 2.0 bugeye at 70000 miles - tuned by jesus! arrowscooby Proven Power Bragging 67 10-30-2008 11:57 AM
fp green/2.0...round 2 rallyrab Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-15-2007 01:04 PM
