Old 07-22-2009, 02:20 AM   #101
felixk
Member#: 188019
2004 Audi S4
just did my ewg up install. that ****ing upipe can go to hell.
felixk is offline   Reply With Quote
Old 07-22-2009, 11:18 AM   #102
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
Originally Posted by paintbing View Post
^ 20 minute uppipe install???? You = Teh liarz!!!!
this^^^^^
Originally Posted by Jons_uurx View Post
So.... its not possible? I swear a lift is the way do do it. i also had 3 guys helping me though. I could imagine doing it in my drive F-that!
there is no way in hell you did that job....even with all of santa's elves helping, in 20 minutes
no
****ing
way
Old 07-22-2009, 11:51 AM   #103
enjoi926
Member#: 129057
Originally Posted by Uncle Scotty View Post
this^^^^^
no
****ing
way
it is possible, this install really isn't as hard as most people make it out to be, if you've worked on cars before, and have lots of mechanic ability, its a piece of cake. Took me about 45min the first time I've done it, takes about 30 min now (still doing this without a lift).
enjoi926 is offline   Reply With Quote
Old 07-22-2009, 12:22 PM   #104
spulbi
Member#: 190378
2008 Dinan 335i
It took me about two hours and a half, and that is with gutting it, also. It wasn't easy, or pleasant, but it wasn't that bad either.
spulbi is offline   Reply With Quote
Old 07-22-2009, 01:00 PM   #105
Ryan314
Member#: 82989
Hybrid EJ257
I just installed an ERZ uppipe/downpipe in my 02 WRX last week. We had a bit of trouble getting it out after it was all un-bolted. The funniest part of all is that we ended up removing BOTH motor mounts, jacking up the engine, but still removed the stock uppipe through the top WITH the turbo still in place don't ask. After doing this install, I honestly cannot believe that people were able to remove the stock uppipe without jacking the engine (unless you removed the turbo that is). There is absolutely no wiggle room without doing it. Everything bolted up fine, except for a couple uppipe studs that were too long, but it was no biggie as we just cut them down to size. It took us about 8 hours total to do the uppipe and downpipe, as we ran into small problems along the way with other things...
Ryan314 is offline   Reply With Quote
Old 07-22-2009, 01:33 PM   #106
wrxracer519
Member#: 149890
09 Forester
Green
Just did my up-pipe last friday and took 4 hrs start to finish. Wasn't bad at all, took my time eating pizza, drinking a few beers, helping a friend with his amplifier, etc...
The biggest pain was trimming the heatshield around the 02 in the header collector.
wrxracer519 is offline   Reply With Quote
Old 07-22-2009, 01:37 PM   #107
felixk
Member#: 188019
2004 Audi S4
Im calling BS on that 20 minutes, i dont care if you build subarus for a living, no ****ing way it took 20 mins. Just to loosen all those bolts, and tighten them back down, would take more than 20 mins all together. Youre either taking out the motor, or the turbo. The turbo to remove takes about 20 mins(Remove IC, all hoses, all bolts). so yeah, my ass you finished in 20 minutes
Old 07-22-2009, 05:25 PM   #108
GundamFan
Member#: 212204
My tuner can install a set of coilovers on a 92-00 Honda Civic in 15minutes and a few seconds, most would call BS On that, i am not saying this guy is telling the truth but you never know, there are people that have just done it so many times they just have it down...
GundamFan is offline   Reply With Quote
Old 07-22-2009, 06:55 PM   #109
alenk37
Member#: 211850
03 WRX
Midnight Black Pearl
it said the record was like an hour and some change for some dude thats exchanged dozens of up-pipes according to nasioc. i call bs too! I had to take off the turbo and go from the top, and had my friend help and it was a pita.... granted my mechanic skills are somewhat newbius but all you do is follow a guide or instructions and hope for the best.... up-pipe and turbo inlet was the biggest pita to install in my opinion so far... have not done anything to the transmission or engine (internally) so maybe ill change my opinion then...
alenk37 is offline   Reply With Quote
Old 07-22-2009, 06:58 PM   #110
RealiTnh
Member#: 191452
2004 ej20 18g 303whp
@ 20psi Synaptic tuned
Originally Posted by TheMadScientist View Post
When working on a car you have to keep this in your head.
"This is just a piece of metal, I KNOW I am smarter"
My record for an uppipe install is 1.5hrs. On jackstands in my driveway.
TMS
AGREED!
RealiTnh is offline   Reply With Quote
Old 07-22-2009, 10:32 PM   #111
felixk
Member#: 188019
2004 Audi S4
I can almost believe that, coilovers were a breeze compared to the uppipe. but still, no way it was less than half hour for coilovers, taking time to lift the car and remove the wheels alone. not even considering all the rusted bolts.
Old 07-23-2009, 04:10 PM   #112
rkramer
Member#: 118209
2015 WRX Limitec
talk is cheap... an unedited 20 minute video is priceless
rkramer is offline   Reply With Quote
Old 07-23-2009, 04:37 PM   #113
Jons_uurx
Member#: 189180
04 wrx jbp stg dos
03 Infiniti G35s
has anyone else used a lift and four people?
Jons_uurx is offline   Reply With Quote
Old 07-23-2009, 05:32 PM   #114
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
fastest Sparks & I did up-pipe install with hand tools & drive ramps
was ~45 minutes..
includes dropping down pipe, tmic removal, heat shield removal & modification
and of course installing new up-pipe & gaskets.
20 minutes?..hand tools or air tools?..lift?...could be done.. but everything would have
to just right..no frozen or stripped bolts/nuts..
Old 07-23-2009, 06:04 PM   #115
Jons_uurx
Member#: 189180
04 wrx jbp stg dos
03 Infiniti G35s
was ~45 minutes..
i didnt have to remove the mount, heat shield, or mod anything.
Old 07-23-2009, 07:06 PM   #116
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
Quotes for total lies. There is no way in hell you're able to remove the uppipe without removing the heat sheild on the exhaust manifold... I also want to know how you removed the uppipe to turbo flange stud/nut that sits directly below the downpipe without 1) removing the heat shield, 2) removing the dang downpipe.
Tell me what magic tool you used, cause in 20 minutes, you would need to be chuck norris to get the car to cooperate the way you want it to AND be able to manuver said tool below the downpipe and BEHIND the (DP) heat sheild!
paintbing is offline   Reply With Quote
Old 07-23-2009, 09:33 PM   #117
burtonrider3889
Member#: 163519
2006 Cayman S
Hahaha yea BS. Even if Chuck Norris, Superman, and Jack Bauer got together they couldn't change an uppipe in 20 minutes. The only way this would be possible is if the engine wasn't in the car, and even then you'd have to be quick.
burtonrider3889 is offline   Reply With Quote
Old 07-23-2009, 09:39 PM   #118
Uncle Scotty
OK buy Nates beans
s000000000000
what ya sayin is that ya didnt remove the tmic
didnt have to remove the heatshields....they were already gone????
or mod anything
and you still did an UP swap in 20 minutes......
I wanna see that video
Old 07-23-2009, 10:02 PM   #119
r.i.pm3
Member#: 114958
Chapter/Region: PRSIC
2005 WRX
BLACK
Maybe with the Help of Michael Phelps!
r.i.pm3 is offline   Reply With Quote
Old 07-23-2009, 10:05 PM   #120
r.i.pm3
Member#: 114958
2005 WRX
BLACK
Maybe he is telling the truth and we are all retards.
It took me [Insertlaughs] 4.5+ hours [/Insertlaughs]
Old 07-23-2009, 10:25 PM   #121
jasonspeed
Member#: 187971
03 Grocery Getter
subyshop.com
It took me a long time because I broke my socket wrench, broke the springy exhaust bolts, and drank a lot of beer and took breaks all the time. Without all the trips to the hardware store, autozone, and breaks I think we spent maybe 4 hours actually working. We took the turbo off because I hate messing with motor mounts.
jasonspeed is offline   Reply With Quote
Old 07-23-2009, 11:31 PM   #122
drifmtaster04
Member#: 166919
03 WRX
WRB stage 2 goodness :)
interesting.... i changed my up-pipe all 3 motor mounts with groupe N's, intercooler y pipe silicone hoses, downpipe, step colder plugs, gmbcs, and reflashed all in just under 2 hours, oh and also took the upipe out through the top without removing the turbo....... maybe i did it wrong?
drifmtaster04 is offline   Reply With Quote
Old 07-23-2009, 11:43 PM   #123
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
This maybe a dumb question...
Uppipe - exhaust manifold bolts are supposed to be tightened ~28ft. lbs. Has anyone had leaky gasket due to over-tightening? Secondly, how much torque is approximately 28ft/lbs? Thanks.
txl146 is offline   Reply With Quote
Old 07-24-2009, 12:00 AM   #124
lumberchicken
Member#: 125575
1947 Woody
28ft/lbs is measurement of Torque - are you looking for a conversion to another unit of measurement?
lumberchicken is offline   Reply With Quote
Old 07-24-2009, 12:02 AM   #125
gopsu
Member#: 96448
02 WRX VF34
anyone using impact gun to tightened these bolts?
gopsu is offline   Reply With Quote
for the sake of man, and mans best friend. please help seventhsign North West Impreza Club Forum -- NWIC 75 06-25-2009 06:15 PM
Pa. 07 sti uppipe and 02 wrx uppipe project x Engine/Power/Exhaust 4 05-05-2007 08:50 AM
f/s 2004 wrx stock turboback exhaust and stock wrx uppipe Scooby_Wong SCIC Private Classifieds 14 03-05-2007 09:08 PM
FS: TurboXS Uppipe and OEM WRX Uppipe. paper_tiger Private 'For Sale' Classifieds 13 11-04-2005 02:27 PM
What's the update on the "Battle of the Turbos"? Jonathan Kent General Forum Archive 5 08-29-2000 09:29 AM
