Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 07-22-2009, 10:08 AM   #251
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
Originally Posted by hilary0110 View Post
Where would I be able to obtain one of these tools?
Home depot, lowes.
You can also get a digital level, now a days. I'm just a cheap ass and haven't picked on up.
Here's a good thread. Post #11 shows what I'm talking about
mccanixx is offline   Reply With Quote
Old 07-22-2009, 10:15 AM   #252
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
Originally Posted by mccanixx View Post
Home depot, lowes.
Thanks Greg, Price doesn't seem too bad either.. I might have to go pick one of those up. I was taught how do it with out an alignment lift but I never made the connection to do it in my own garage
hilary0110 is offline   Reply With Quote
Old 07-23-2009, 09:31 PM   #253
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
Greg... How would I go about alighning the camber on my car at home.
Old 07-24-2009, 02:46 PM   #254
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
I use my iphone to do my alignments... Never tried to measure the caster... hmmm
xcdhridr is offline   Reply With Quote
Old 07-27-2009, 09:30 PM   #255
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
yer I-phone You kids and your wacky technology
Anywho...The Toledo pro came and went. I managed to squeak out a win even though sunday when I pulled in to the staging lanes for my first run the brake pedal went right to the floor.
The car was all over the place and sometimes the brakes would work, the rest of the time they'd just lock up due to the abs going in and out. Sometimes you'd turn in, the car would buck and do what it wanted.
Turns out at the last event, I'm pretty sure, I broke the cage on the left front wheel bearing. There had been a loud pop from the left front. Even though I inspected everything on the left front it wasn't found until Sunday morning prior to Billy's runs in SM. I think the hard 24 runs it got saturday accelerated it's demise.
I pulled it apart tonight.
The wheel movement is slightly exagerated because I did pull some of the inner bearings out at the event site yesterday.
Once I pulled the housing I could begin to see the damage. Rollers had shifted on the inner.
And the outer bearing
I had stopped to pick up a bearing on the way home but it turns out the hub itself has 6 hairline cracks in it. The outer portion has also been destoryed.
The housing is fine since it carries a pressed in race. I'm on the hunt for some spare assemblies now. As I have nothing to reassemble at this point.
It also damaged the caliper bracket, the caliper itself and I should get a new ring for the rotor$$$$$$$$$$$$$$$$$
Old 07-27-2009, 09:46 PM   #256
Rasmusson14
Member#: 77658
2004 ej207, ppg dogs
3" green, ITS ALL 4 SALE!
Sorry to hear that Greg Thats really crappy that it got into your caliper and rotor hardware too. You pressed for time before the next event?
Rasmusson14 is offline   Reply With Quote
Old 07-27-2009, 09:52 PM   #257
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
That's a real bummer Greg =( I hope you can get it done before Alex products! Good luck with it! You did great this weekend keep up the good work.
And I think we can safely say this wasn't my fault this time ;-) although I was driving it at the event we heard the pop. JK.
Old 07-28-2009, 12:07 AM   #258
Chiketkd
Member#: 71634
In hibernation...
Holy smokes. That's a lot of play!!! Looks like even a toddler could rock that wheel back-n-forth with ease.
Sorry to hear Greg. Hope to see her good as new soon.
Chiketkd is offline   Reply With Quote
Old 07-28-2009, 12:07 AM   #259
Chiketkd
Member#: 71634
In hibernation...
Double post...
Old 07-28-2009, 08:19 PM   #260
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
I get what you did there "pressed"
Not so much. I got a new bearing, hub, seals, and I'm waiting on a pound of neo synthetic grease. I should have it together and the passenger side checked out / repacked by the weekend.
Old 07-28-2009, 09:08 PM   #261
rexluthor
Member#: 218364
2004 WRX
Very informative, Thanks.
rexluthor is offline   Reply With Quote
Old 07-28-2009, 09:16 PM   #262
turbocat
Member#: 120151
13 BRZ, 07 WRX
Wagon, 94 Land Cruiser
how many miles did that bearing live through? Did it have synthetic/motorsport grade grease in it?
turbocat is offline   Reply With Quote
Old 07-28-2009, 11:20 PM   #263
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
Gonna make it to the challenge? I'm gonna be driving Sean's MR2.
Old 07-28-2009, 11:39 PM   #264
dodwrx
Member#: 130823
1997 Miata
Holy cow that's a lot of play. Too bad it failed before the weekend was over and decided to mess up your brakes as well.
dodwrx is offline   Reply With Quote
Old 07-29-2009, 07:40 AM   #265
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
I can't say. I'd guess a butt load of auto-x and ~ 6000 miles. I did all the bearings ~ 3 winters ago and I used neo 800 in them.
I suspect what happened is: I recently installed the aluminum lca's. Perhaps, even though I tq'd and peened the nut, the nut backed off a bit. Allowing enough movenment to snap the cage. IDK. That's my thought.
I'm going to pull apart the right side as well to inspect/grease. We can take a look at it's condition then.
I'm thinking about. I'll have to ask the boss.
It's really too bad we didn't find it Saturday. In the afternoon we inspected for a lumping (left front) we had noticed. Turned out to be the left side caliper was loose. We tightened it and all agreed that it went away. We even shook the wheels when we swapped around tires Saturday. Even Sunday I should've made the decision to pull the assembly and run home to through a new bearing in. Looking back I would've had time before the challenge. woulda/coulda/shoulda
Old 07-29-2009, 09:17 AM   #266
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
Greg tell the boss there's autox to be had! This is cruicial Greg. You gotta pull your weight LOL i'm doing my job i'm driving a Nora car, and you know my track record with borrowed cars ;-)
Old 07-29-2009, 10:44 AM   #267
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
I would have made a parts run for ya Greg :shrug: at that point I really wasn't doing anything.
Old 07-29-2009, 06:16 PM   #268
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
I had gotten home early enough today to do the bearing. Since the grease won't be here till tomorrow I thought I'd see if I had enough to do one side.
I did, just enough.
I had already gotten the old race out of the housing. I had kept one the last time I did this so I used it to slid the new one into place.
Then you need to install the large C clip. A set of internal/extrenal pliers is handy for that.
After I had cleaned the packaging grease off
I proceeded to pack the bearings with new grease. I find it easier to just put a blob in my left hand and roll, pack, squeeze the grease into the bearing with my right. It's fairly quick and effective.
Ahh more stock studs I don't need I guess I'll use the press since the hub is dismounted.
10 minutes later.
Now that I have everything together I can assemble. Put the bearing in the outside and install the oil shield. Then press the hub into the bearing.
After that flip it over and push the bearing onto the hub.
Old 07-29-2009, 06:17 PM   #269
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
Install the inner grease shield and your done.
Around an hour later I have a complete assembly that I can install at my leisure. The whole thing took about an hour.
Now I do want to check to make sure the caliper braket is nice and square still and check the run-out on the rotor to see if it survived.
Old 07-29-2009, 06:29 PM   #270
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE
& 2006 IAG WRX (ForSale!)
Wow. That was one destroyed bearing and hub! Of course, the work needed to fix it makes me appreciate the one piece nature of the fourth gen Camaro front hubs.... though they are quite pricey, the convenience (and no need for packing bearings) is pretty much worth it.
CamaroFS34 is offline   Reply With Quote
Old 07-29-2009, 09:45 PM   #271
Rasmusson14
Member#: 77658
Nice write up Greg. You got a PM.
Old 07-30-2009, 06:26 AM   #272
PDLTURBO
Member#: 73129
2004 WRX #50ESP
San Remo Red
Very nice thread Greg!
Are you guys speaking of the Smackdown event at Northfield Park this weekend? If so, I'll see you guys there. I'll be #50 SM in an 08 STi. My 39k WRX decided to spin a rod bearing, so no STX for me.
I was talking with a local ESP driver about taking my WRX to ESP next year(he came in 2nd to you in Toledo) and he said he is leading the charge to get the WRX moved to BSP , where evo's seem to rule. He is also making stickers of Calvin peeing on the WRX or Subaru logo.
Do you guys think that will happen? The WRX moving to BSP would suck, for me at least.
PDLTURBO is offline   Reply With Quote
Old 07-30-2009, 06:50 AM   #273
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE
It would suck for a lot of us.
Frankly, the WRX has been in ESP since 2002. No one had a problem with it until this year, when Greg and I started building ours to the limit. Drew Little did run his at Nationals last year and finished 4th in ESP (but a few seconds behind the class winner).
I would just monitor Fastrack updates (if you're an SCCA member), and make sure you write in ASAP if there is a request for member comment regarding a move. The soonest it could happen would be 2011, since by the time any member comment would be requested, submitted and then acted on, the cars couldn't be moved for 2010.
The '08+ WRX, however, is on the books to be moved, only because of the turbo available on the '09. While the powers-that-be say that it's not a foregone conclusion, the fact that the 2009 Impreza 2.5GT was classed in BSP (and it's a lesser car in stock trim) to me indicates that there is very little chance the '08+ cars won't be moved. But, we can fight any other change in WRX classing tooth and nail; just make sure you bring the facts about why it shouldn't be moved (ie., how it is not the same as an STi, as too many non-Subaru people think; how similar cars remain in the class, like the AWD turbo DSMs, etc.).
Now, back to your regularly scheduled hellastupid build thread.
Karen
Old 07-30-2009, 07:54 AM   #274
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
Thanks.....
Yep were are speaking of the nora challenge event. I may be there but seeing as the city has the entire end of my driveway tore up getting the trailer out Sunday may be difficult if it's not done by then. Sorry bout your wrx.
Ah yes the same gentleman who insulted Karen and I on another forum. I really don't care what he does. I met him, I understand his position. Doing the calvin sticker is a perfect example of being stuck in 1989.
In regards to the move. That's really, ultimately, up to the membership and the SEB. If it is put out for letters I would be the first to encourage every card carrying subaru driver to write a letter. Just look at the tremedous resource we have right here. Karen has the timeframe for moving right on.
In regards to personal opinions and car classing. I think that esp should get faster. I don't know why a class should live in a time capsule-------eternally crankng out the Blue Oyster Cult. It will come down to numbers and they will more than likely have them. Which is where were at today. It's true the car's been there since 2002 and in my feeble mind here's what I see:
2002, 2003 car's too new no one is hacking it up for ESP
2004 2005 STi's/Evo's are out, they're quicker than the wrx, they're built, win and moved.
2006-2008 Why waste the money/time you're just going to be moved.
2009 I say f it I'm wasting the money/time I'll at least have a couple seasons before I have to do a turbo swap.
The car's are getting long in the tooth so they are becoming more prevelant in *SP
Old 07-30-2009, 08:06 AM   #275
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE
Not to derail the building part of the build thread too much more, but...
Still, in 2003, the cars are being built for STX. While there isn't as much "hacking up" in ST* as in SP, according to the "experts," it doesn't require much more than an ST* build for the WRX to be competitive in ESP. Of course, I guess it depends on the definition of "competitive" -- do you mean "can trophy" or "can win"?
This is true.
Close to my reasoning, except mine ends with "before I finish building the green Camaro" instead of a turbo swap.
Karen
CT: 2002 WRX, Project car, everything you need included! bdr2488 Private Vehicle 'For Sale' Classifieds 1 01-10-2010 10:05 PM
What are the differences between the 2002 WRX and the 2003 WRX? Red Rexx Newbies & FAQs 43 04-18-2008 07:02 PM
FS: Oakland CA 2002 WRX Project car ratboy Private Vehicle 'For Sale' Classifieds 2 04-04-2008 01:16 AM
feeler: 2002 wrx project car bWRX MAIC Private Classifieds 1 03-28-2008 02:53 PM
2002 WRX Project Car for sale. Scoob Private Vehicle 'For Sale' Classifieds 7 07-22-2007 12:43 AM
