Old 09-20-2008, 08:27 PM   #1
BonesDT
Member#: 189646
Default DIY Aux Input Kit for $1.99
I have pictures! Will a supported member help me post them please?
This is a How-To make your own Aux Input jack kit like the OEM part no. H6210FG000 for a 2007-2008 Impreza without Premium sound. I do not know what else it will work for, but if the 8-pin port in the back of the stock headunit looks like the one in the pictures, then it should work.
The MSRP for the OEM kit is $75 (you can find it easily for $62). This includes a module housing a 3.5mm TRS female connector for a headphone-style jack and a specialty cable that connects the module to the back of the factory headunit. It is of note that this $75 kit does not include the necessary TRS cable needed to play any audio device such as an MP3 player.
H6210FG000 Installation Instructions
I don't think I'm alone on this when I say this is a GIANT rip-off. This thread is a little F-you to Subaru.
I spent $9.50 at Radioshack for the 2 parts, and since one would have to buy the $7.50 cable anyway, I duplicated the OEM kit for $1.99. The car is leased, so the setup is super easy to remove and does not leave a trace of tamperage.
Refer to the "Real" Aux Input on 2007 OEM Radios section of
Stock head unit information -- pin-outs, aux inputs, and more
I have confirmed the pin assignments are identical for the 2008; Pin-1 is left stereo, Pin-2 is right stereo, Pin-5 is audio ground, and Pin-6 is a special Aux enable switch.
When looking at the back of your headunit, with the 8-pin connection port clip recess pointing upwards, the top row, left to right goes Pin-4, 3, 2, 1. The second row, left to right goes Pin-8, 7, 6, 5.
You will notice that when you press the CD/Aux button on your radio as it is, it will not go into the Aux mode. There is a +5-volt source at Pin-6 and when you ground it, it enables you to enter the Aux mode. I'm assuming the OEM kit has a switch in the female jack that senses when you plug a wire in and then enables the Aux mode. Since disabling the Aux mode is practically a useless feature, I will permanently enable the Aux mode by grounding Pin-6.
1) The hardest part is finding suitable connectors to attach intermediate wires to the pins. The connectors need to have an internal diameter small enough to fit snugly on the tiny pins, have an external diameter small enough so you can fit all four connectors on all four adjacent pins, and need to be completely insulated all around.
I found these tiny connectors "Telephone Butt Connectors" at Radioshack for $1.99. If you have scrap wire laying around, then you have successfully saved at least $60. Celebrate. I cut the extra plastic off one end of these connectors so that the internal metal sleeves would slide all the way onto the headunit pins. The inside of the connectors were still too loose for the skinny pins, so I hooked the intermediate wires under the bottom of the connectors so the wire and the pin would both fit very snugly inside the metal sleeve.
2) I used a 6-foot cable that had a 3.5mm TRS connector (standard headphone jack) on each end. I lopped off one of the jacks to expose the 3 wires. The uninsulated wire is the audio ground. I don't think there is a standard with the wire coloring (red, black, sometimes white), I've seen them reversed on cables, so it's best to use a ohm-meter to determine which is left stereo and which is right stereo. The tip of the jack is left stereo, the ring (middle section) is right audio, and the sleeve is ground.
http://en.wikipedia.org/wiki/Jack_plug
3) Now that you have a solid connection with the pins and 4 intermediate wires are sticking out of the back of your headunit, you can connect the stripped end of the TRS cable to the appropriate terminals. Attach the 4th Enable wire to one of the Phillips screws on the headunit brackets, similar to the instructions for the OEM kit.
4) Test everything before you start putting things back, then route the cable under the console just as the OEM kit instructions have you do. Plug in your MP3 player, laugh at the fools who bought the OEM version, and celebrate again.
BonesDT is offline   Reply With Quote
Old 02-26-2009, 04:06 AM   #2
subySerb
Member#: 155411
does this work for the sinlge din CD player found in 2.5i and TR?
subySerb is offline   Reply With Quote
Old 02-26-2009, 10:42 AM   #3
djosbun
Member#: 202176
2004 WRX wgn P1RANHA
'07 Tribeca
Damn, I wished this would work on an '04 so I can hook up my Sirius SatRad. Well, that has no 'aux' button on the radio, anyway.
djosbun is offline   Reply With Quote
Old 02-26-2009, 10:46 AM   #4
Mechie3
Member#: 120152
Host your pictures on www.photobucket.com and then post the [img] tag url here.
Old 02-26-2009, 04:28 PM   #5
soob ftw
Member#: 174210
2007 Impreza WRX
i would also like to know if this works for the TR
and pictures would be amazing too
thank you!
soob ftw is offline   Reply With Quote
Old 02-28-2009, 01:34 PM   #6
BonesDT
Member#: 189646
http://s29.photobucket.com/albums/c2...Impreza%20Aux/
I don't know what a TR is. I don't know what else it will work for. Check out the Stock Head Unit Information link I posted. If Subie makes a simple Aux Input kit like the model number above, then you can get this to work. They are just selling you the wire.
Old 02-28-2009, 06:23 PM   #7
subySerb
Member#: 155411
thank you!
it seems that pics are for the double din unit and i don't think that we have Aux button on our players.
Old 03-05-2009, 09:21 PM   #8
fprinz
Member#: 204852
great tip!
fprinz is offline   Reply With Quote
Old 07-01-2009, 01:59 AM   #9
chimps46
Member#: 215755
is there a way to use the satellite hookup for an additional line in?
chimps46 is offline   Reply With Quote
Old 07-01-2009, 05:57 PM   #10
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Yes, but not for $1.99 unfortunately... link (post #169 in that thread).
Oh, and please don't cross-post the same message in multiple threads.
Old 07-02-2009, 02:35 PM   #11
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
There is a kit you can buy that uses your CD changer interface, to allow you to install an aux input. I don't know where to find it, but i know its out there.
skingfreak is offline   Reply With Quote
Old 07-25-2009, 12:56 PM   #12
Deeez
Member#: 174908
2008 2.5i 5-door
This sounds great, but I have a question for the OP:
Permanently enabling the aux input, does that affect the CD player's functionality?
Thanks for your ingenuity, OP.
Deeez is offline   Reply With Quote
Old 07-25-2009, 01:04 PM   #13
MF-DIF
Member#: 62197
2002 WRX, 2004 GTO
2000 SV650N
Subscribed for when pics come up.
MF-DIF is offline   Reply With Quote
Old 07-26-2009, 01:22 AM   #14
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Not at all. The two audio sources go into separate inputs. The only thing the aux enable line does is permit you to select the aux input. It's just software in the radio's microprocessor ("does the CD/AUX button just do CD or does it toggle between CD and AUX").
Old 08-01-2009, 03:49 AM   #15
j-scott
Member#: 213328
2006 2.5i wagon
aspen white
Default Many thanks
Just wanted to thank the OP for this DIY. Hooked up my radio yesterday and no more having to deal with a crappy fm modulator for sirius or burning cd's just to listen to mp3's.
Many Thanks!
j-scott is offline   Reply With Quote
Old 08-01-2009, 04:55 AM   #16
Terrible Juan
Member#: 208296
2012 Chrysler 300
2015 Jeep Grand Cherokee
Originally Posted by BonesDT View Post
This thread is a little F-you to Subaru...
...laugh at the fools who bought the OEM version...
Or laugh at the ones who leased a car.
You're sure showing them!
Terrible Juan is offline   Reply With Quote
Old 08-10-2009, 08:28 AM   #17
Organic_MK
Member#: 190464
1998 ej205 coupe
obp
is there anyway to get this to work on a tr?
Organic_MK is offline   Reply With Quote
Old 10-11-2009, 08:40 PM   #18
epistax
Member#: 224197
2015 435ix GC
Imperial Blue
Thank you very much. I just did this and I must say it even looks professional. I took the plastic piece from the center console, used a dremel to remove the extra plastic from the back side, drilled a hole and mounted a plug.
The hardest part was removing the paneling without using excessive force, simultaneously wanted to get it off and not wanting to harm my less than 1 month old car
epistax is offline   Reply With Quote
Old 02-07-2010, 04:38 PM   #19
p2adan
Member#: 176574
2008 2.5i
Good work, works flawlessly! Thank you for the write-up.
p2adan is offline   Reply With Quote
Old 05-26-2011, 04:17 PM   #20
mickfo
Member#: 283932
Thank You!
This worked perfectly. I couldn't be happier with the result. The dealer wanted $500 to install the aux wire and best buy wanted $200, but instead I got it working perfectly for like $10 total. Thanks again!
mickfo is offline   Reply With Quote
Old 06-15-2011, 02:14 PM   #21
n_bart
Member#: 285711
2011 Impreza 2.5i
Default Great Post
Just wanted to let anyone who was wondering know that this DIY also works on the 2011 Impreza base head units. I just installed mine last night and it works perfectly. Thanks again for this post!
n_bart is offline   Reply With Quote
Old 12-08-2011, 02:43 PM   #22
cleardaze
Member#: 294142
2011 Impreza
Thanks for giving the pin assignments. I've looked everywhere for them and this is the first time I found them. Hell Cartoys tried to charge me $180 for the cable. yuck. It works great but I'm a fan of the aux in the glove box, plus it's so much easier to route the wire. Just a quick handoff. I also used a wire crimper and a 26-22 guage telephone butt so it just fit like a glove onto the pins. I would have used aircraft cannon plug pins but don't have a crimper for them. Thanks again for the thread. I know it's three years old but it worked on my 2011
cleardaze is offline   Reply With Quote
Old 02-08-2012, 12:30 AM   #23
rafael_rahme
Member#: 309485
Default Alternative Way
That was great man, many thanks!
I wanted to do something like that for a while now, but I didn't know what to to with the the "ENABLE" cable,
I did something similar, but instead of using butt connectors, I soldered the cables straight to the main board, the result was good.
Soon I will post a step-by-step with lots of pictures!
Thanks Again man!
rafael_rahme is offline   Reply With Quote
Old 02-08-2012, 01:22 AM   #24
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
I'd be interested to see pictures of the blank that you get instead of the aux pod. Is it just a plate like the one shown here? (translated)
Old 02-08-2012, 05:31 PM   #25
rafael_rahme
Member#: 309485
Hello friends, first off, Im from brazil so excuse me my english
As I promised, here goes a step-by-step, guide to you if you want to do what I did, It isn't hard, Im not a pro nor anything like that, Im just an engineering student, you will have to know how to solder to get it done right, that was the only hard part for me, because I am not very good with solders
The original Idea was to drill a hole on the back plate of the stereo and pass a female TRS connector through that hole, I bought that connector to the equivalent to USD $0.25
That way the stereo would be still really compact in case I decide to remove it to sell and get one of those multimedia things, but I don't have a drill right now, I couldn't wait to get my hands working so I left the drill for a possible other time.
In this step-by-step tutorial I only routed the AUX input to under the dash, on that place with the 12V output, someday I will route it to the central console too and have a selector switch, so I have two inputs, and a switch to select which one is being used to avoid crossed signals, and MAYBE, let the ladies in the back choose what they want to listen to lol.
Unfortunately the order of the pics got inverted, so start with the pic number 79 (the last pic is the first)
so here it goes folks:
http://s925.photobucket.com/albums/a...DIO/?start=all
Please let me know what you think about it : )
Any inputs or questions are welcome.
PS.: My Stereo is the regular one, not the 6 CD changer, but I'm pretty positive it can be done with the 6 CD changer as well.
08 Aux Input Kit, 07 WRX Stock Radio Maner Interior/Dressup/Audio & Security 48 04-25-2012 02:33 PM
FS: Aux Input Kit 08-09 9-2 wrx Interior/Dressup/Audio & Security 2 11-11-2009 04:33 AM
Decks with AUX input and XM ready? White01 Car Audio, Video & Security 4 05-31-2003 07:54 AM
Aux input and Creative Nomad brainofjjj Car Audio, Video & Security 14 09-10-2002 03:36 PM
Enabling AUX Input on my Sony ES Deck parid Car Audio, Video & Security 5 06-01-2002 05:08 PM
