#1 |
Member#: 149001
TXIC
Vehicle:09 Caliber ex 07 WRX |
My stocker is on the fritz and I am thinking of picking up a new/used one and going this route:
http://www.blouchturbo.com/turbos/WR...essor_Upgrade/ Has anyone had and experience with this? Trying to do some research and the good ole search button isnt helping much. If it helps, current power mods: STi TMIC SPT Intake Flying Performance BCS TurboXS Catless TBE Grimmspeed uppipe with Tial 38mm EWG Note- I will get retuned (even if I just get a OEM replacement)
#2 |
Trust me, I'm a scientist
Moderator Member#: 150794
SCIC
Vehicle:Qcab dakota 4x4 LT1 Formula Firebird |
If you're not going to get a re-tune for it, stick with an OEM TD04.
#3 |
Member#: 149001
TXIC
#4 |
SCIC
Ok, as long as you've got that covered you should be good. I don't have any personal experience with that turbo, but it would be a cool experiment! Good luck.
#5 |
Member#: 173241
TXIC
Vehicle:2002 s256 twinscroll now with one more gear |
hey i have really been looking into this, i talked to a guy and bought a turbo that i thought was a 19t wheel , ended up being a 16g wheel but what i found out, it that the TD04 wheel is to small, and you loose power over the whole power band, a better set up would be basicly what i have, its a TD04 exhaust housing bored to fit a TD04HL wheel, which is basicly a TD05, and then sticking the 19t or a 16g wheel on there , i believe the 19t is a 31lbs/hr wheel and the 16g is a 32.5lbs/hr wheel, with the 16g and TD04HL wheel i hit full boost by 2650, and at 12psi, im pushing more power that with the stock at 20psi, if you want, you can pm me and i can send you some of the links, and alot of the info i have found. forced performace sells the exhaust wheel for 237.50 , its the only place i could find it, but either way it will be a nice set up that has lots of power and the amount of spool up time of a reg TD04
also i will have a stock TD04 with like no play in it, in about a week and a half or so, and im in the houston area |
#6 |
Member#: 70981
South East
Vehicle:2005 WRX WRBlue 01 Outback/5mt |
Thought I would bump this tread back up with my results of the Blouch TD04-19T on my 05 WRX. This thread was helpful awhile back and it felt appropriate to add some info...
Mod List Stock 2.0l TD04-19T ported and clipped Ver 8 JDM TMIC Stock air box with Subaru AA080 filter GM EBCS APS turbo inlet Pink Injectors STi up-pipe Stock mid-pipe to Prodrive Axle back with a Invidia down-pipe This graph was not the finished product, the final graph is alot smother... but it shows the difference between my stage 2 setup over the TD04-19t aftermath. spools fast as hell on the street I'm seeing 19-20psi at 2700rpm and ended up with 277hp and 277ft-lbs ![]() and here's the difference between a VF39 (dotted line) and the Blouch TD04-19t (Solid line) ![]() VF-39 WRX Stock 2.0l VF-39 e-bay TMIC APS 65mm cold air Pink Injectors catless up-pipe full 3" turbo back I like to see how this turbo blows the socks off the VF-39 even with the stock air box and basically a stock cat back ![]() Steve Last edited by Surfer Steve; 07-28-2009 at 10:18 PM. Reason: update to mods |
#7 |
Member#: 158313
Vehicle:2003 WRX PSM |
Plans to track it? Trap speed would be very interesting.
#8 |
Member#: 105814
NWIC
Vehicle:two V8's.. 'murica |
Impressive.
Im considering this over my vf34. I miss stage 2 spool. ![]() |
#9 |
Member#: 184949
Vehicle:2005 Outback XT Lmtd Silver 5mt |
Wow. That is so nice to see. I have putting off the turbo upgrade for a while and think I might pull the plug on this. That is actually a lttle more power than I want but great spool characteristics!. Thanks for posting this up.
#10 |
Member#: 152775
MWSOC
Vehicle:2004 Wrx Java Black Pearl |
Damn! that is awesome! so full boost by 2700 rpms?!! that would be awesome! and it pulls almost all the way to redline! This i like. This i like a lot. where exactly can i purchase the turbo from? forced performance? or blousch?
#11 |
Member#: 59097
SCIC
Vehicle:04 WRX Java Black |
thanks for that info. how does it feel on the street/freeway around 6k? does it pull nicely up in the higher rpms?
#12 |
Member#: 212171
NESIC
Vehicle:08 SSM WRX MSPT Tuned: 254whp/343wtq |
#13 |
Member#: 28291
RMIC
Vehicle:2005 STi Tuning Subarus in RMIC |
#14 | |||
Member#: 105814
NWIC
![]() Last edited by GDB FAN; 07-28-2009 at 04:45 PM. |
#15 |
Member#: 126441
SCIC
Vehicle:03 bugeye |
+1 for interesting turbo that noone ever posts info about.
#16 |
Member#: 197677
SCIC
Vehicle:2.5L bugeye wagon 342whp/317wtq on 91 |
i've been messing around with 19t turbos for a couple years now and i love them...awesome thread
#17 |
Member#: 166830
South East
Vehicle:2003 WRX WRB |
i'm REALLY interested in this, there's no way i can send my stock turbo in for this? or do i buy the one off the site?
#18 |
Member#: 163884
South East
Vehicle:1999 Cobra |
this is amazing. would really like to see some track times on this
#19 |
Member#: 119764
Vehicle:2006 STi WRB |
The 19T is overlooked by many 2.0L customers that upgrade to a VF
#20 |
Member#: 59238
SWIC
this will be my next turbo of choie for my 2.0
#21 | ||
Member#: 70981
South East
I have no complaints ![]() also, I'm using a GM EBCS... Quote:
it tapers to about 17 to 18psi to redline... I'm not really into drag to much , so I'm not sure if I'll have that info anytime soon... but who knows, I might take a trip out there one day with some of the local t3h Fast-Rarrrrrr Scoobys I do plan on doing some open track days and I always love auto-xing... FP here I come ![]() Steve |
#22 |
Member#: 70981
South East
#23 | |
Member#: 166830
South East
![]() i was going vf43, but this is wayyyy better and more efficient! thanks for the info man! |
#24 |
Member#: 152775
MWSOC
Wow this is awesome! almost 280 whp on a TDO4. That is great! And full boost at 2700 rpms. Man screw the VF series i mean they are great turbos, dont get me wrong, but you cant get a VF series with that kind of spool and you make the same amount of power! and for 325 bucks, that is a lot of bang for your buck.
#25 |
Member#: 59097
SCIC
are pinks required for this? what were the duty cycles? great info. nice power. I love my 2.0 80k in and it runs strong. didn't want to upgrade turbos but this makes me want.
| Thread Tools | |
| Display Modes | |
| td04 19t blouch upgrade. | WhiteBgeye02 | Private 'Wanted' Classifieds | 1 | 06-23-2010 08:35 PM |
| WTB td04 for 19t upgrade | tanner127 | Private 'Wanted' Classifieds | 3 | 04-13-2010 08:04 PM |
| Blouch TD04 19T upgrade on 4EAT. Opinions | Brock31 | Transmission (AT/MT) & Driveline | 6 | 12-17-2009 10:35 AM |
| Blouch TD04 19T Upgrade | lackofhp | Factory 2.5L Turbo Powertrain | 8 | 10-31-2008 01:57 PM |
| TD04-19T questions. | ringe | Factory 2.5L Turbo Powertrain | 6 | 06-07-2008 07:19 PM |
