Old 06-22-2009, 12:39 AM   #51
GDAryder
Member#: 184753
2005 WRX
^^ at the same time i still would like to get nearly 25-28mpg.
GDAryder is offline   Reply With Quote
Old 06-22-2009, 11:34 AM   #52
GDAryder
Member#: 184753
2005 WRX
another question to add.....i read somewhere (i think it was youtube lmao) that 04-05 rex's have thicker teeth in the gears (RA thickness) so would an RA 1-3 or 1-4 be even a real upgrade? no matter what i have to keep my stock 5th for gas mileage (and some hope of top end lol).
*RA users chime in here anytime now*
*Any LGT gear runners found the breaking point of their boxes yet?*
Old 06-24-2009, 11:50 PM   #53
bogey1
Member#: 183009
2004 Fozzy XT
Storm Trooper White
Is the 97 Outback tranny a direct bolt in a 02/03 WRX? If not what mods need to be done? Are these trannys known to be stronger than the "glass box" trannys? Thanks,
Shawn.
bogey1 is offline   Reply With Quote
Old 06-26-2009, 02:49 PM   #54
scottdaniels13
Member#: 215210
Hey Guys...Im really stumped....I need 4.11 ring and pinion for the rear of my 1993 JDM WRX Type RA...any suggestions where to find one?
scottdaniels13 is offline   Reply With Quote
Old 06-26-2009, 03:00 PM   #55
GDAryder
Member#: 184753
2005 WRX
^^ send a PM to any of the tranny vendors on here they may be able to help you
Old 06-29-2009, 09:33 AM   #56
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Shawn.
I don't believe they are any stronger. However with the slightly shorter gearing compared to the WRX, it puts less strain on them. You need to change over the clutch setup to the NA tranny stuff, and change slave cylinder, and matching rear diff. The NEWEST you can put on with the speed sensor is an '04 Outback. '05+ run off the ABS sensors for vehicle speed, but you can still have it done.
FuJi K is online now   Reply With Quote
Old 07-25-2009, 05:07 PM   #57
Rallypro7
Member#: 163128
2001 Impreza 2.5rs
RED
thnx this was helpful
Rallypro7 is offline   Reply With Quote
Old 08-06-2009, 11:56 PM   #58
greg donovan
Member#: 60743
'95 Impreza L
dirty and on jack stands
where should i look to compare gear ratios from a 95 impreza 4EAT and a 95 Legacy 4EAT?
greg donovan is offline   Reply With Quote
Old 08-07-2009, 12:04 AM   #59
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
i would call the dealer and ask for Service, then gear ratios for those two. Some dealers will help you, some will say that information isn't attainable. I can call my guys up on it.
Old 08-07-2009, 12:30 AM   #60
greg donovan
Member#: 60743
'95 Impreza L
thanks
mine has been pretty good. will pop in there tomorrow.
was hoping to find something online so i dont wear out my welcome there.
my 95 legacy wagon trans is going out and it needs a replacement. all i can find right now is a EAT from a 95 impreza.
Old 08-07-2009, 10:57 AM   #61
compressro
Member#: 193383
2004 WRX WRB
97 Impreza Wagon
Looking for some help Fuji,
Running 2.5/2.0 hybrid swap in my 02 WRX. Looking for mostly reliability. JDM STI RA gear set or LGT trans?
compressro is offline   Reply With Quote
Old 08-08-2009, 10:34 AM   #62
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
both of those arent bad choices. Difference would be gear spacing between those two. The LGT's gear spacing is similar to say a '00 2.5RS. The difference is that your tranny is a 3.900FD and the 2.5RS is a 4.111FD. Speed in each gear will be a tad faster in your tranny than a 2.5RS. The STi RA gearset you'll notice a taller 1st gear, which you may find helpful because you can get a bit more speed before shifting into 2nd for daily driving. After 1st gears, spacing is much shorter making acceleration much better, but note that 5th gear is a .825 ratio on a 3.900FD, which will have higher revs than stock; my JDM 6spd is a .842 with a 3.900FD.
Old 08-11-2009, 05:55 AM   #63
wrx0001
Member#: 99887
2002 tbxs stg 3 wrx
black
Anyone know the gear ratio and final drive ratio on a 07 jdm ver 7 sti tranny? I could only find them up to 06. Also can someone explain to me the 3.9 final drive in the front and 3.54 fd on the rear of the 02 wrx? When you calculate speed/rpm which final drive do you use? Thanks
wrx0001 is offline   Reply With Quote
Old 08-11-2009, 10:39 AM   #64
GDAryder
Member#: 184753
2005 WRX
^^ the mechanical FD will equate to 3.9 because of the center diff. between the THREE diffs the FD will calculate to 3.90:1
Old 08-29-2009, 09:55 PM   #65
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I'm not sure if the JDM STi changed to a 3.545FD for the rear diff like what the USDM did for the '07 JDM STi's.
But ratios are the same and they still rev to 8000rpms
3.636 / 2.375 / 1.761 / 1.346 / 1.061 / 0.842
The USDM STi that runs the 3.545FD rear diff uses a step up gear transfer gear with a ratio of 1.1:1. You take this 1.1:1 multiply it by 3.545 and you come REALLY close to 3.900; which is 3.8995.
The rear diff with the FD ratio of 3.545 DOES spin slower than the 3.900FD of the same wheel speed. Wonder if they did this to reduce bearing wear and less heat???
Old 08-30-2009, 05:46 PM   #66
charliew
Member#: 125304
Probably less noise
charliew is offline   Reply With Quote
Old 09-03-2009, 10:19 PM   #67
ROUGE180
Member#: 222569
89 SilEighty
Primer Grey | Red
Wow.. This thread has shed a lot of light on things about gearing that I really didn't understand. Thanks Fuji.
ROUGE180 is offline   Reply With Quote
Old 09-30-2009, 10:05 PM   #68
2slofouru
Member#: 90539
95 340whp impreza
05 Raven R6, 07 2.5i
-Is there a confirmed correct list of rear diff ratios somewhere that's easy to access?
Thanks for any help
Last edited by 2slofouru; 10-02-2009 at 08:34 PM. Reason: Edited because apparently the rest of my questions were irrelevant
2slofouru is offline   Reply With Quote
Old 10-01-2009, 12:30 AM   #69
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
anyone have the sti 3.166 first gear with 4.11?
do you have 0.738 or 0.825 fifth? if so what is speed @ 3k?
Old 10-01-2009, 09:59 AM   #70
Trevor723
Member#: 57989
2016 .:R
LGM
assuming 225/45/17 tires, with 4.11 fd...
3k rpm with .738 5th = ~73mph
3k rpm with .825 5th = ~65mph
Trevor723 is offline   Reply With Quote
Old 10-01-2009, 01:24 PM   #71
GDAryder
Member#: 184753
2005 WRX
that doesnt sound too bad i guess. hell with the stock 3.90 FD i can cruise at around 80mph at around 2800-3k rpm (w/225/40/18's)
Old 10-01-2009, 02:50 PM   #72
Trevor723
Member#: 57989
2016 .:R
LGM
It's really not that bad at all. I have .738 5th with 4.44 fd and 3k rpm = 68mph. That is the slight downside, the upside being that 5th gear actually feels like a driven gear rather than an overdrive.
Old 10-01-2009, 04:27 PM   #73
GDAryder
Member#: 184753
2005 WRX
i gotcha. sometimes with the stock 5MT it feels like an extra 6th gear would be nice for OD.
Old 10-02-2009, 08:33 PM   #74
2slofouru
Member#: 90539
95 340whp impreza
So would it be correct that a 03 standard wrx for example would have a 3.9 front ring and pinion, 1.1:1 tail section and 3.454 rear diff? Just trying to learn about how the ratios work.
Old 10-03-2009, 10:37 PM   #75
GDAryder
Member#: 184753
2005 WRX
Originally Posted by 2slofouru View Post
So would it be correct that a 03 standard wrx for example would have a 3.9 front ring and pinion, 1.1:1 tail section and 3.54 rear diff? Just trying to learn about how the ratios work.
Fixed. and correct.
This why you learn to do your own vehicle maintenance. BacDoc Off-Topic 156 02-22-2008 09:58 PM
Sources for learning to Tune your Car? plus plus plus Newbies & FAQs 7 06-19-2007 03:56 AM
How to choose your own spring rates (and get the spring frequencies correct) stretchsje Brakes, Steering & Suspension 2 05-16-2007 01:55 PM
Learn To Open Your Doors Dooley Mid Atlantic Impreza Club -- MAIC 25 10-04-2006 04:15 PM
For crying out loud people, learn to title your threads well! Brady Off-Topic 12 05-15-2005 08:57 PM
