| View Poll Results: How often do you clean your MAF sensor? | |||
| Once a month or more |
21 | 3.55% |
| When i change my oil |
79 | 13.37% |
| When it needs it, I can tell by my EM or my butt dyno |
142 | 24.03% |
| NevAR |
352 | 59.56% |
| Multiple Choice Poll. Voters: 591. You may not vote on this poll | |||
#76 | |
Member#: 41754
Vehicle:03 wrx gt35r, 2.5L, meth |
You know that's not the actual MAF sensor you're taking a picture of, right?
#77 | |
Member#: 170512
MAIC
Vehicle:2012 WRX Ice Silver |
Pictures of IAT probe are there to compare before and after cleaning, and to show that something gets cleaner ![]() So far I don't think I can feel any difference... Last edited by mostasz; 01-16-2009 at 10:40 PM. Reason: I called IAT a heater probe, so had to fix it... |
#78 |
Member#: 143391
MWSOC
Vehicle:2007 WRX TR R.I.P Colin! :( |
Mine was not bad at all. I did not see any change in how the car drove after I cleaned it.
#79 |
Member#: 137631
Vehicle:2006 WRX Red |
is this ok to use?
http://www.voltronic-germany.com/Uni...leaner-M60.htm states that its approved to use for air mass sensor. And able to clean multi surfaces including rubber. I suppose its safe? wanna be safe |
#80 |
Member#: 137631
deleted
#81 |
Member#: 102367
Vehicle:06 Forester STi Crystal Grey |
#82 |
Member#: 145642
Tri-State
Vehicle:2007 WRX Ltd Cuz Chicks Dig The Wagon |
I almost forgot entirely the importance of cleaning the MAF on a turbo engine..for some strange reason, the butt dyno notices the most gains immediately after the cleaning.. but actual numbers take days of ECU stabilization and relearn...
#83 |
Member#: 177898
Vehicle:2005 WRX STi Crystal Metallic Grey |
Just wanted to say that today I cleaned my MAF (Mass Air-Flow Sensor), and the idle is wayyyyyyyy smoother, shifting from neutral into first-gear used to sometimes seem to come dangerously close to stalling, but this is no longer a problem! These effects were immediate. Hopefully my gas mileage will improve, we'll just have to wait and see.. oh and FWIW, the screws holding the sensor in place looked like they'd never been touched. My 05 sti has like 72K miles and this service might never have been performed...on my car. Scary.
Some advice I would give from my experience- I don't think you really need to buy the maff cleaner. Q-tips and isopropylene (rubbing alcohol) would have worked just as well. From now on I'll be doing this with every oil change. Takes just a couple of minutes and it can make quite a difference! |
#84 |
Member#: 206319
NWIC
Vehicle:2002 Outback Sport Green...mostly |
where do I get at this pos at from?? any pics??
#85 | |
Member#: 38469
NESIC
Vehicle:07 LGT spec-b Crystal Grey Metallic |
#86 | |
Member#: 207118
NWIC
Vehicle:2003 Wrx Wagon |
Yep. Just did this today after finding this thread. I have 60k, never cleaned it, and found this board trying to figure out why my car felt like crap. Couldn't feel the turbo kick in. First I discovered the air filter box wasn't seated properly (also reset the ecu) that helped a bit over a week later - I cleaned the MAF in some rubbing alcohol. Immediately felt the turbo kick in again! Can feel a much stronger pull from it. Please make this thread a sticky in the FAQ's! ![]() Thanks for posting this! |
#87 |
Member#: 160279
NWIC
Vehicle:2004 STi Crawford Performance |
meh.. need to do mine at the end of this week im thinking
#88 |
Member#: 42478
South East
Vehicle:2004 WRX STi White/Gold |
What other o-rings can be used? I have one that is nicked and needs to be replaced. Don't want to buy a new MAF if I don't have to.
#89 |
Member#: 42478
South East
I went to my local True Value hardware store and found these...
#90 |
Member#: 117214
South East
Vehicle:2003 WRX Wag'n Wagon You can have. |
I was skeptical. I was afraid to touch the 300 dollar maf sensor. Its delicate and I know plenty of people who have broken them on Nissans.... I've never touched the MAF on this car, and its got 60k of my mileage, and 120k of total mileage. I thought my boost was lackluster and I felt the car was slower or I had just gotten used to driving it. I had studdery acceleration, gas mileage bad, and thought that my Clark Turner etune was not much better than the COBB OTS Stage II...
I cleaned the maf this morning. Right before I left on my 34 mile drive to work. I sprayed it down with CRC electronics cleaner. I did NOT reset the ECU or change the air filter. I dont know if its placebo because I'm paying attention, but I can SWEAR that the accel is much smoother, the car pulls stronger at 2000 rpm and I notice that the Lamco boost gauge needle jumps up to full boostness way faster than it has in the past. Its the cheapest 10 minute maintenance work I've done that been most satisfactory. |
#91 |
Member#: 133597
SCIC
I have 85k and have never done this. :facepalm:
#92 |
Member#: 126441
SCIC
Vehicle:03 bugeye |
^^please do...speaking of which. Its time for me to do mine again too.
gonna pick up some o rings and hex allen bolts to replace stock. |
#93 |
Member#: 203034
MAIC
Vehicle:2004 Impreza WRX STI WRB |
I just cleaned mine after reading this thread!
#94 | |
Member#: 133597
SCIC
#95 |
Member#: 215017
NWIC
Vehicle:97OB 2004 civic :-) |
Do NA engines like the EJ22 also require the MAF to be cleaned often?
#96 |
Member#: 202140
RMIC
Vehicle:1998 2.5 RS RBP |
Hmmm. I'd like to know if WD40 is an acceptable cleaner.
#97 |
Member#: 110771
Vehicle:2006 WRX black |
#98 |
Member#: 187358
South East
Vehicle:08 BMW 328 |
#99 | |
Member#: 226391
SCIC
Vehicle:01 Silverado |
noob question: what are the heater wire and the hallow? |
#100 |
Member#: 203034
MAIC
The hollow of the MAF is the open inside of the tube going up from the bottom (farthest into the intake when it's installed) to the top with the plug. The heater wires are very hard to see, but they're up inside the hollow tube. When it says indirectly spray it means not straight up into the tube, but angled so the spray hits the walls of the tube before it hits the heater wires.
| Thread Tools | |
| Display Modes | |
| How often do you change your synth oil in your wrx | D-I-Z-Z-L-E | Factory 2.0L Turbo Powertrain | 58 | 12-03-2012 08:30 PM |
| How often do you wash your hair (if you have any)? | HoRo1 | Off-Topic | 33 | 12-02-2003 03:22 PM |
| How often do you clean your K&N/reusable air filter??? | megatron | Factory 2.0L Turbo Powertrain | 1 | 10-18-2002 11:05 AM |
| how often do you wash your car? | inpreza kid | Canada Region Forum | 12 | 02-24-2001 05:07 PM |
| How often do you clean your rims? | John2.5RS | General Forum Archive | 12 | 05-22-2000 08:02 AM |
