Old 08-13-2009, 10:20 PM   #1
b2sotm
Member#: 73315
2000 OBS
Default rubber inner wheel well trim repair 2000 OBS
The rear wheel wells on my 2000 OBS have a slit rubber weatherstrip (about 18-24 inches long) that fits over the inside metal edge of the fender and edge of the plastic well. I expect this is to keep out assorted snow/rain etc.
Anyway, the passenger side piece is coming off and dragging on the rear tire. It doesn't look like there are any fasteners so I am assuming the piece is just glued on?
Insights and repair suggestions welcomed!
b2sotm is offline   Reply With Quote
Old 08-13-2009, 10:54 PM   #2
StupidFastWagon
Member#: 157526
2014 335i xDrive
M Sport
Pull it off and be done with it
StupidFastWagon is offline   Reply With Quote
Old 08-14-2009, 02:37 AM   #3
b2sotm
Member#: 73315
2000 OBS
Thanks. This may be what I end up with but given the way the road salt used here during winters here eats sheet metal I like the idea of trying to keep the wheel well sealed.
Old 08-14-2009, 03:28 AM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
It has some metal in it that is supposed to help clamp it on the lip. The metal can fail causing the trim piece to start falling off.
I agree it may help slow the rusting process though.
I would get some Goop (brand name), remove the trim, wash the wheel well and fender lip, let dry, apply the Goop (it's basically a glue) to the edge of the fender and then shove the trim piece back on.
You may want to tape/clamp the trim in place while the Goop dries.
Old 08-14-2009, 10:26 AM   #5
b2sotm
Member#: 73315
2000 OBS
Appreciate the suggestion, and will give it a try.
wtb inner wheel well for 05 sti sexyrex02 Private 'Wanted' Classifieds 4 07-11-2008 02:44 PM
Note on the Inner Wheel Well Plastics for the 08s Bucky92 Impreza Forum 4 03-30-2008 03:57 AM
rear rubber wheel well trim rickr01 Interior & Exterior Modification 3 12-07-2007 10:53 AM
Inner wheel well liner is gone... wat do i do?? intpostman23 Interior & Exterior Modification 17 08-16-2007 10:23 AM
02 front inner wheel well plastics ASAP!!!! skate enjoi Private 'Wanted' Classifieds 4 07-25-2006 11:20 PM
