08-18-2009, 02:33 PM | #226 | |
Member#: 60685
SCIC
Vehicle:2005 WRB STi 371whp/368ft-lb on 91 |
PASSED 2003 WRX 70,xxx miles Titek Catless UP Prodrive catted DP Stromung/Prodrive catback (no resonator) Resistor Mod Cobb AP Stage 2 ALOHA SMOG FTW. Sam is the nicest guy, and you get a FREE air freshener!
08-21-2009, 12:33 PM | #227 |
Member#: 96618
Passed
Had to get a smog because I am selling the car soon. 2005 STI 53,000 miles Tomei Headers/Up pipe Maddad V2 Catted Downpipe HKS Carbon-TI Walbro Fuel Pump One Step Colder Plugs Harman Motive Protuned Stage 2 Base Map Car initially failed the first test, so the technician did a mandatory preconditioning to test the car again. Which instills holding the car at 2500 RPM for 190 seconds, I'm assuming to warm up the cat. After that it passed with flying colors. Idle test HC (PPM) Max allowable: 100 Measured: 49 CO (%) Max allowable: 1.00 Measured: 0.11 2500 RPM HC (PPM) Max allowable: 130 Measured: 27 CO (%) Max allowable: 1.00 Measured: 0.10 Car passed the OBD II reading test from the computer with no issues (meaning the reader didn't detect that the CEL Defeats for 02 and Cat were turned on in the map). I was scared that the OBD II could detect the CEL defeats. As far as visual, tech was concerned whether any of the engine was stock (the red manifold and STI intercooler). To which I assured him it was, honestly though he didn't visually check to see that there were cats in the exhaust system. |
08-23-2009, 07:11 PM | #228 |
Member#: 49624
Vehicle:04 AW WRX 13 SWP STi |
2004 Subaru WRX
stock UP and DP Apex World Sport Catback Cobb AP v1 Stg 1 resistor CEL fix (from previous turbo back) It should have no problem passing smog right? Mainly concerned about the Stg 1 and CEL fix. If I do decide to "Revert to Stock" on the Cobb AP, should I reset my ECU? Or this not necessary? |
08-27-2009, 05:51 PM | #229 |
Member#: 49624
Anyone? haha
08-28-2009, 11:12 PM | #230 |
Member#: 60685
SCIC
If you've noticed what everyone else has passed with, you should be fine
09-03-2009, 05:08 PM | #231 | |
Member#: 96618
09-09-2009, 03:10 PM | #232 |
Member#: 24409
SCIC
Vehicle:'03 Comatose WRX Wagon. Parked. |
PASSED
2003 WRX 114,000 miles PNP/Coated Headers w/ crosspipe Samco Inlet Gutted Up Crucial shorty DW DP Stock 3rd cat Easily passed emissions. Visual was sketchy. Dude was poking around the engine bay and looked under with his mirror and still passed me. I can finally can stop stressin! |
10-16-2009, 02:31 PM | #233 |
Member#: 113873
BAIC
PASSED!!
2003 WRX 128,000 miles Bosal UP with CEL resistor fix Open source tune @ Yimi Sport 1 Step Colder plugs Afta-Maf Snorkus Delete ...Sti axle back I removed the Crucial shorty DP and used the stock one. Idle Test 729rpm %CO2: MEAS 15.1 %O2: MEAS 0 HC(ppm) MAX allowable: 100 Measured: 4 CO(%) Max allowable: 1.00 Measured: 0 2500RPM @2390RPM %CO2: MEAS 15.0 %O2: MEAS 0 HC(ppm) MAX allowable: 130 Measured: 2 CO(%) Max allowable: 1.00 Measured: 0 Tech there said it ran like a brand new car |
11-04-2009, 02:51 PM | #234 |
Member#: 200834
SCIC
hey guys, i know it's a little late to be asking this....i just a bought '07 forester xt that has AZ plates. should i be worried about not passing the smog test here in CA?
the dmv website was referring to manufacters making cars that meet the federal standard and CA standards.... thanks in advance |
11-04-2009, 08:20 PM | #235 |
Member#: 3924
SCIC
Vehicle:I owned a Subaru once |
PASSED
2003 WRX 168,xxx miles (New Motor) Catless UP, no 02 sensor Stock catted DP Cobb v2 cat back Modded injectors TGV Less Samco hoses Drop in Foam Flter 89 Octane Turbo Timer Cusco Heatshield Vishnu stage "monkey" tune I think that is all, have to look the car over still. |
11-05-2009, 04:18 PM | #236 | |
Member#: 96618
11-16-2009, 07:16 PM | #237 |
Member#: 210777
SCIC
Vehicle:.. Don't worry bout' it Brah |
How would an Invidia divorced hfc downpipe affect smog? on a stage 2 06 wrx?
11-16-2009, 08:22 PM | #238 |
Member#: 52769
SCIC
Vehicle:09 WRX WRB |
Won't pass visuals but will pass the sniffer as far as I know.
11-17-2009, 12:05 AM | #239 |
Member#: 209087
SCIC
will a catless dp pass?
11-17-2009, 11:21 AM | #240 |
Member#: 45574
SCIC
Vehicle:2004 CRP SG5 FXT 1998 Bright blue GM4 |
A catless dp will pass emissions as long as the idle is tuned. I checked my car at work and I actually passed the 2500rpm test catless, but its a gross polluter at idle.
11-17-2009, 12:17 PM | #241 |
Member#: 59993
International
Vehicle:Ass, grass or cash no one rides for free!! |
11-17-2009, 06:04 PM | #242 |
Member#: 45574
SCIC
11-18-2009, 12:37 AM | #243 |
Member#: 59993
International
aaaahhh no worries.
12-04-2009, 02:03 PM | #244 |
Member#: 190153
SCIC
Vehicle:2006 WRX Rest In Pieces:/ |
I have a perrin catted single piece dp along with perrin cat-back on a 2006wrx. Once i have to...will i pass smog with this setup? in so-cal that is
12-04-2009, 04:18 PM | #245 |
Member#: 52769
SCIC
It will pass the sniffer, but not the visuals.
12-11-2009, 07:57 PM | #246 |
Member#: 230329
SCIC
Vehicle:2004 WRX Black |
Passed the Gas!
04 WRX
Harman Motive Protune Stage 2 Stock DP and exhaust And a long prayer! Took me forever to swap the exhaust and dp with just a jack and jackstands, but it was well worth it. I'm SOOOOO Relieved! |
01-08-2010, 01:43 AM | #247 |
Member#: 57548
Vehicle:2004 STi |
For my 04 STI, I only have a catted Helix DP and a custom ECUTEK tune. If I fail smog is there a fine? Can I just put my stock DP on after I fail without any penalties?
01-11-2010, 09:39 PM | #248 |
Member#: 15672
Vehicle:2002 wrx wr blue |
no worries
there is no fine.
just put your stock dp back on and it should pass. |
01-20-2010, 04:18 PM | #249 |
Member#: 197677
SCIC
Vehicle:62 i gotta miata |
nevermind, found it
01-26-2010, 07:35 PM | #250 |
Member#: 129414
SCIC
Vehicle:05 wrx |
i need a friendly smog shop to help me pass my old subaru. its having problems passing. im in the orange county area. my pm box is empty
Similar Threads | ||||
P0171 CEL Thread - Everything you ever wanted to know? | CirrusWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 646 | 08-11-2022 02:26 PM |
Everything you ever wanted to know about anything ever made......ever | Hester Prynne | Off-Topic | 12 | 11-05-2008 05:57 PM |
Everything you ever wanted to know about exaust systems | Back Road Runner | Normally Aspirated Powertrain | 9 | 10-24-2006 09:59 PM |
('93-'01) Everything you ever wanted to know about Subarus... | Porsche914boxer4 | Impreza Forum | 15 | 07-23-2001 09:17 PM |
Everything you ever wanted to know about WRX exhauasts (old model) --> | rao | Normally Aspirated Powertrain | 5 | 02-12-2001 08:56 PM |
