Old 07-21-2009, 09:22 PM   #1
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Default New MFactory Plated LSD for R160 (99+ Impreza/Forrester/Legacy)
Hi everyone. I recently stepped up and did a 6spd swap. Up until recently, when doing a swap you only had two choices when dealing with the rear end:
1. Upgrade to the stronger r180
2. stick with the weaker r160
The r160 diff allows you to keep everything as it is (axles, hubs, brakes, wheels, etc.) but is now the weak link in your drivetrain.
The r180 upgrade meant you needed to go with one of the following set-ups:
A. keep you 5x100 hubs (allowing you to kep your brakes and wheels) and have the drive shaft shop make custom axles to mate up to the r180.
B. swap out the entire read end, including STI rear axles, STI hubs (5x114.5) and new wheels, and Brembo brakes.
Those of us on a budget will naturally pick the r160 and a prayer nothing happens to the diff when pushing the ponies.
I personally didn't upgrade the rear diff to the r180 because I love my wheels and tires (5x100) and have $3k worth of brake upgrades. Going with the r180 would mean having to get new wheels/tires, brakes, hubs, and the whole sha-bing, totally upwards of $4k when all is said and done.
Well, we have a new option available... the new MFactory Plated LSD for R160.
- The plated units will be a direct drop in unit for all R160's from 99'+
- These are fully rebuildable and feature forged casings.
- Fits 99+ Imprezas, Forresters, and Legacys
- 1/1.5 way differential
- Options to replace the cam with a 1.0/1.5 or 1.5/2.0 (both fixed ramp angles).
- Pre-load springs are part of the design to smooth the transition of torque and eliminate chatter. This gives a far more precise feel and much easier to control.
- Lock % can be adjusted by re-stacking the plates (60-100%)
In case you do not know what 1/1.5/2 way means...
1 way L.S.D.- Specially suited for front wheel drive cars and 4WD car front axles. Activates under acceleration, and acts as a true LSD when the throttle is off.
1.5 way LSD- Activates under acceleration while the understeer is less than on the 2 way LSD. Recommended for drivers having difficulty with 2 way LSD understeer and one way LSD braking.
Two way LSD- Activates on both acceleration and deceleration.
Check out this thread... there is a group buy going on right now if you are interested. I for one hopped on. Only a few more spots.
http://forums.nasioc.com/forums/show....php?t=1753618
chrisarella is offline   Reply With Quote
Old 07-21-2009, 09:36 PM   #2
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I though the weak link in the r160 was the smaller ring and pinion... wouldn't a LSD put more pressure on them?
Bad Noodle is offline   Reply With Quote
Old 07-21-2009, 09:49 PM   #3
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
As far as I know it was the spider assembly, but I could be wrong.
Feel free to ask Dylan at DS1 Motorsports or MFactory directly. <--- click to send them a PM
Old 08-23-2009, 06:49 PM   #4
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
bumpity bump bump.
Old 08-24-2009, 01:32 AM   #5
byroll01
Member#: 611
'05 E55 AMG
GetADomTune.com
need pics to satisfy my cravings!!!
I just installed a one way cusco that I got used today...yeah, took me all day, it was my first time. My axles aren't right and I'm running with no circlips. I guess from what I can find I need old JDM axles...
The buy in price on this LSD is barely more than I paid for the used cusco!
byroll01 is offline   Reply With Quote
Old 08-24-2009, 06:16 PM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
You could have just stuck with '04 STI bits and not have to worry about swapping wheels and tires.
I just don't see how a new differential itself is really going to make that big a difference in the strength of the R160. The fact remains that it's a smaller diff using smaller gears that are more highly stressed than those in the R180.
Pat Olsen
Old 08-24-2009, 06:54 PM   #7
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
^^^ the 04 STI axles are still different than my WRX axles and would require custom ones made by the Driveshaft Shop.
Old 08-25-2009, 06:53 AM   #8
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I'd really like to hear what DS1 or MFactory have to say about the weak points of the r160...
Old 08-25-2009, 07:30 AM   #9
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
The weak points are the spider gears. The R160 has 2 side gears, and 2 spider gears. If we had 4 spider gears, that would have been a different story. If you ever taken apart the rear diff, you'll know what I mean. Those spider gears are tiny. I've broke my fair share. I weld them up and I have a lot more fun doing donuts and such.
After putting in a good LSD, if it holds up, your pinion/ring gear are next to go out. If not that, then it'll be your little R160 axles. Overtime with and LSD you do look at bearing wear on the pinion gear if the LSD has a strong initial bite/lockup.
Old 08-25-2009, 07:38 AM   #10
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
^ that's some good info
I was considering the lsd, but didn't know if it would put more stress on the ring and pinion and cause an earlier failure. The r160 I have now is an open diff, so the rear wheels break free much quicker since torque gets delivered to the wheel with the least resistance.
With and LSD, this wouldn't happen since the locking would distribute the torque to the other wheel as well minimizing wheel slipping and thus putting more stress on the r&p
Old 08-25-2009, 08:28 AM   #11
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
The upside is you have a good performing vehicle. I will take the potential side-effects to have good diffs in the car.
As some one who's chewed up spiders in stock rears. I'll take my chances with the putting more load through the bigger R&P, then suffer the horrible performance of stock wrx diffs.
my .02 and good price on the plated diff. I run the m-factory helical in the front and I would say it's been stellar, quality wise, thus far.
mccanixx is offline   Reply With Quote
Old 08-25-2009, 09:15 AM   #12
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
We cracked the root of every tooth on an R160 pinion gear, at even a moderate power level.
We actually kept it at R160 though, but I worked some magic on the R&P and it has been working quite well ever since.
Old 08-25-2009, 02:56 PM   #13
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Correct me if I am wrong, but I believe Cusco and a couple other manufacturers have been making R160 diffs for a while.
Old 08-25-2009, 09:31 PM   #14
byroll01
Member#: 611
'05 E55 AMG
GetADomTune.com
they're more than 675 (the the normal price of 800) though...
Old 08-25-2009, 09:38 PM   #15
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
~ 1200.00 for the cusco 1.5
Old 08-26-2009, 04:33 PM   #16
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
But they are proven...
...and when I was researching a 6 speed with an R160, I priced a 1.5 way for about $950 shipped.
Old 09-20-2009, 01:53 AM   #17
CPC
Member#: 123085
2006 WRX
chrisarella,
The group buy thread for these died a couple of weeks ago. Are these things available to buy or were they waiting on numbers from the group buy before they started to make them? Thanks.
Chris.
CPC is offline   Reply With Quote
Old 09-23-2009, 09:35 PM   #18
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
I believe these were going to be made regardless, but want to generate some initial interest and momentum to get some of the up-front costs covered.
Old 09-25-2009, 02:23 AM   #19
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
I would probably go this route if there was a QUALITY set of axle's available for the R160(I see them as the weak point along with the R160).
I have a spare R160 in the garage for when I break mine.
RonJitsu is offline   Reply With Quote
Old 09-25-2009, 08:56 AM   #20
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
The driveshaft shop makes axles and hubs for our cars rated from 750-1000hp, 5-spd or 6-spd, r160 or r180 applications. They are REAL pricey though, but if you feel you need axles they're the ones to go with.
http://www.driveshaftshop.com
Old 09-25-2009, 12:45 PM   #21
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
Yea I know about the DSS ones. Thats why I mentioned "quality". The DSS axles are strong, but are reportedly clunky and fitment leaves alot to be desired.
DS1 has mentioned that they'd like to offer a quality set of axles, but I havent heard anything as of yet...
Old 09-25-2009, 12:54 PM   #22
jstalford
Member#: 175819
2006 Rav4
Are we allowed details? Is that something that would ever be available to customers?
jstalford is offline   Reply With Quote
Old 09-26-2009, 11:13 AM   #23
jonpark
Member#: 141449
2007 EvoIII16g WRX
UGM EJ257+05/6speed
So what exactly did you do on that R&P to make it stronger? Can you let us know please?
jonpark is offline   Reply With Quote
Old 10-22-2009, 06:43 AM   #24
CPC
Member#: 123085
2006 WRX
Again, does anyone know if these things exist yet? There is nothing on their website about them being available.
Also, TiC please tell us about this magic on the R&P you guys did
Chris.
Old 10-22-2009, 09:18 PM   #25
ljaviation
Member#: 42270
2003 A&P IA
ww.flyingleafaviation.com
I run a 03 WRX with the 5x100. and ran the Cusco 2 wayMZ. Loved the diff. Unfortunately, I have tore ring and pinion teeth out of 2 R160's since last Oct at VIR. 430 WHP, 18 PSI.
Bought a stock R180. I had DSS axles in the car, called them and told them I was upgrading to the R180, and they "hybrided" (if that's a word) my axles to the R180, and keep all my existing hubs, brakes, ect.
I talked to Lee, and it was a $500 upgrade. I have too much invested in the 5x100 setup and will stick with it.
I do hate te factory rear diff and will be getting another aftermarket.
Posted for relation of axle possibilities.
L J
ljaviation is offline   Reply With Quote
MFactory Plated LSD for R160 Group Buy DS1 Vendor 'Group Buy' Classifieds 99 09-16-2009 11:06 PM
Need Aftermarket Lsd For R160!! cquirki Private 'Wanted' Classifieds 0 06-08-2008 08:47 PM
NIB Cusco 1.5 RS LSD for R160 raamaudio Drivetrain 6 08-04-2007 10:47 AM
Strongest aftermarket LSD for R160? WRXINTX Transmission (AT/MT) & Driveline 9 10-07-2005 10:16 PM
