Old 08-20-2009, 12:13 PM   #1
alwu
Member#: 73776
Default uppipe and tgv CELs
i had some mods done to my subie recently which included a catless uppipe and tgv deletes, so i'm getting the CELs associated with those mods.
what's the correct way to get rid of these CELs with romraider? do i use the CEL fixes, delete the codes, or both?
alwu is offline   Reply With Quote
Old 08-20-2009, 12:56 PM   #2
D-NaSty
Member#: 156456
2005 92x aero
turn off the codes in romraider, I think its under the emissons folder
D-NaSty is offline   Reply With Quote
Old 08-26-2009, 09:29 AM   #3
mateospeed
Member#: 116317
2002 WRX...sold:-(
second. That's the "right" way to do it. Don't bother with CEL fixes, just disable the codes in RomRaider/ EcuFlash. www.romraider.com
mateospeed is offline   Reply With Quote
Old 08-26-2009, 09:54 AM   #4
Tea cups
Member#: 103136
disable the CELs and also enable the TGV fix (16-bit ECU).
Old 08-27-2009, 05:18 PM   #5
alwu
Member#: 73776
thanks. that's what i did. i was getting the P2004, P2005, P2016, and P2021 CELs. i disabled those CELs and enabled the tgv fixes that included those CELs. but i left the other tgv related fixes and CELs alone, so i haven't enabled all the tgv fixes nor have i disabled all the tgv CELs. should i go ahead and enable/disable those even if those CELs haven't been thrown?
also, should i clear the CELs first with a scan tool before disabling them? or does that not matter?
Old 08-27-2009, 05:23 PM   #6
Tea cups
Member#: 103136
no, you do not need to clear the codes with scantool. Just disable and flash (you can always reset the ECU in RR's logger if you like although a flash has the same effect with most ECUs).
If you aren't getting the CELs pertaining to a fix, then you don't have to enable the fix. Won't hurt anything if you do anyway.
Gutted uppipe and no CEL 94'325is Factory 2.0L Turbo Powertrain 22 01-06-2008 05:05 PM
Odd power-making problem. TGV CEL-related? jblaine Factory 2.0L Turbo Powertrain 6 07-07-2005 08:27 PM
helix uppipe and downpipe no CEL? VideoGameWrx Factory 2.0L Turbo Powertrain 4 12-02-2004 09:31 PM
TGV CEL feature request from Ecutek janchiko Factory 2.0L Turbo Powertrain 3 10-30-2004 02:53 PM
Godspeed uppipe and downpipe, still a CEL Oo DaRk StAr oO Factory 2.0L Turbo Powertrain 5 04-21-2003 06:35 PM
Message Board Statistics All times are GMT -4. The time now is 12:43 PM.
