Welcome to the North American Subaru Impreza Owners Club Tuesday June 2, 2015
Old 08-26-2009, 07:43 AM   #51
AWDbawl
Member#: 201727
Chapter/Region: HIIC
03 WRX
I have been wanting to run EL headers but every oil pan thread i find has conflicting views on what needs to be purchased when going from the 2.0L to the 2.5L pan. It's either you just need a pan, or the pan and pick up or some other crazy combination. Can I get a little help on what all i should be getting pre-swap?
AWDbawl is offline   Reply With Quote
Old 08-26-2009, 08:00 AM   #52
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Have you decided on a header manufacturer yet? Once that is decided we can move forward regarding the selection of a pan/pickup if need be.
I can tell you this... If you go from a WRX 2.0 pan to an STi (or 06+ WRX, Legacy GT, Forester XT) oil pan you WILL need to change the pickup too. The baffling is different, the angle of the pickup is different and the depth the pickup goes into the pan is different.
So let us know what header you decide on and we'll go the next step
Old 08-26-2009, 08:22 AM   #53
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
I was able to use my stock 2.0L pickup on my 2.5L oil pan. However I had to whack the pickup a few times to get it where it needed to be. I wouldn't recommend doing it but it worked for me and has been for a year now. I'll be removing it all soon.....Killerb pan and pickup going in with a new motor
CoolRex is offline   Reply With Quote
Old 08-26-2009, 01:11 PM   #54
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^^ You've got to be a little careful when doing this because the EJ20 pickup is 1/2" shorter (if memory serves me correctly) than the EJ25 pickups. If you use an 04-05 EJ25 version it's not as bad as the 06+ EJ25 versions because the 06+ version pans are a little deeper still.
Old 08-26-2009, 06:49 PM   #55
charliew
Member#: 125304
I would never wack a oil pickup. You will never know if it has developed a fracture after being wacked. Maybe heated with a torch and gently formed. We add a sheetmetal extra brace to the pickups we use to try a prevent any vibrations from causing a fracture in the pickup.
I like big pans with extra wings and swinging gates and I know the ones I use will not fail.
charliew is offline   Reply With Quote
Old 08-26-2009, 07:09 PM   #56
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
I didn't say to do it....lol
Old 08-26-2009, 10:36 PM   #57
garboplateNY88
Member#: 134113
05 LEGACYGT
247hp 300tq retuned STM
never buy a moroso oil pan I have nothing but leaking oil everywhere
garboplateNY88 is offline   Reply With Quote
Old 08-26-2009, 10:45 PM   #58
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
LOL, don't listen to me, I'm biased, but there's a reason the pans I make have no moving parts
Old 08-27-2009, 08:14 AM   #59
silver-duck
Member#: 130710
I have my 'KB' pan and pick-up; they are a 'WORK of ART'[not installed yet]
silver-duck is offline   Reply With Quote
Old 08-27-2009, 08:50 AM   #60
AWDbawl
Member#: 201727
03 WRX
I wanna run the Perrin EL headers so i'm guessing new pan, pickup and baffle? will i need a new dipstick, or oil pump?
Old 08-27-2009, 11:56 AM   #61
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks for the kind words!
Yes. Pan, pickup, & baffle (oil control tray). Some get by without the dipstick and dipstick tube just by knowing how much to put in at oil changes and where 'full' is on the hybrid setup. If you want it to read just like OEM, you'll need a new dipstick and dipstick tube. You do not need to change the oil pump.
Old 08-27-2009, 05:05 PM   #62
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Hmm I did not know the different pans gave different readings on the dipstick I was going to replace my Ej22E pan from one from a 03 WRX so that means I'd need a new dipstick too right?
SubaruImpreza_power is offline   Reply With Quote
Old 08-28-2009, 12:52 AM   #63
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
From what I hear, some are interchangable, but I don't know all the combinations.
Old 08-28-2009, 03:18 AM   #64
silver-duck
Member#: 130710
Will my WRX dipstick work well with your pan?
Old 08-28-2009, 08:15 AM   #65
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
I got a 2.5L pan and ordered a STi dipstick. 5 qts oil in the car and it won't even register on the dipstick
Old 08-28-2009, 10:09 AM   #66
jays05
Member#: 78165
05 STI 35r + e85
Mine did that too, there was a plug above the oil dipstick tube that Moroso didn't use any thread sealer on.
jays05 is offline   Reply With Quote
Old 08-28-2009, 10:11 AM   #67
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
If it's the pan I make, you may not be full yet. When I put the first prototype on my car it was a hair over +1 quart (~5.4 quarts). The other prototypes that are installed out there needed even more to register full (~5.5 quarts) and since the prototypes, I made a few design tweaks that would push that capacity up a bit more so I wouldn't be suprised if you could add another .5-.8 quarts to register full.
The other thing here is that Subarus are notorious for reading all over the map as far as how much oil it takes to show 'full'. There are many threads on this, and many theories on how best to check your oil (hot, cold, warm, in the dark under a full moon, etc.). I followed the OEM design to avoid the issues that other aftermarket pans have with thier dipstick adapters or universal dipstick kits.
When I do an oil change I typically check the oil a bunch of times for about a week after the change and average out the readings. When I installed this pan I started with it not showing and just kept adding until it was where I wanted. Now I know what it takes for every oil change to come.
Old 08-31-2009, 03:01 AM   #68
garboplateNY88
Member#: 134113
05 LEGACYGT
Can it be fixed without taking the oil pan off. Thats where my is leaking now? Can it be fixed in 1 day? I don't want to drop it off again just had the drain plug helicoiled.
Old 09-12-2009, 10:58 PM   #69
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I know where you can get a leak free oil pan
Old 09-13-2009, 10:48 AM   #70
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
killerB, do you guys make a oil pickup for a wrx pan yet?
D Money is offline   Reply With Quote
Old 09-13-2009, 12:59 PM   #71
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I do. I sell it primarily to people running the Cosworth pan (since the Coswroth pan is just a reworked OEM one).
I still highly recommend if you do any aggressive driving you upgrade to an STi (or any 06+ EJ25 pan). It's cheap insurance against oil starvation that often happens with the flat bottom OEM pans.
Old 09-13-2009, 01:36 PM   #72
jays05
Member#: 78165
05 STI 35r + e85
Mine was fixed very quickly with the car up on a lift. All you need to do is drain the oil, pull that plug out, replace the plug with some thread sealer, and put oil back in. I had a very slight leak right up until I vented my crawford AOS to atmosphere... with it vented to atmosphere the leak got a lot worse.
Old 09-13-2009, 02:59 PM   #73
Gixxer1K
Member#: 81631
Note that you re-use the old dipstick tube with the STI dipstick.
Gixxer1K is offline   Reply With Quote
Old 09-14-2009, 10:00 PM   #74
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Yes, in fact I include new o-rings too
I'm curious, what was the outcome here?
Old 10-01-2009, 01:12 PM   #75
fast71
Member#: 123735
2002 WRX PSM /2.5
Turbo_mike built, PPG'D
Question to the Gurus,
I just finish my hybrid motor break-in.
While changing the oil I notice some oil residue around the bolts holding the oil pan (2.0 pan). I cleaned out the area. 2 days later I see the oil again.
I'm a little confused to either replacing the 2.0 pan or get a sti pan? also what parts would I need?
I never had any issues with the 2.0 pan. Please help me decide.
Thanks.
fast71 is offline   Reply With Quote
2.0 vs sti oil pump needawrx13 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-20-2009 09:19 PM
oem wrx shift kit vs. sti/wrx quick shift kit choiboi Transmission (AT/MT) & Driveline 1 09-21-2008 06:27 PM
anyone change a wrx oil pan to sti oil pan? 1WRX2NV Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-30-2007 09:32 PM
WRX US OEM vs STi/SPT sedan spring rates ... again ANZAC_1915 Brakes, Steering & Suspension 6 12-13-2001 12:52 PM
WRX Wagon Stock vs STi v5 struts/springs svxtrem Brakes, Steering & Suspension 0 06-08-2001 11:01 AM
