Old 08-26-2009, 11:10 PM   #1
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Default Inexpensive 5x100 wheels for 255/40/17 tires?
I'm looking for some 5x100 wheels to fit 255/40/17 Ecsta XS' on. Nothing fancy, just need the wheel to do its job. It doesn't look like I can get away with 8" wide, and I can't find very many inexpensive 17x8.5 and 17x9 offerings. Anybody have suggestions?
I found these 5zigen's in 8.5:
http://www.1010tires.com/wheel.asp?w...r+GN%2B+Silver
Then from Wheeldude, Rota D2 in 8.5 and DPT, Torque in 9:
http://www.wheeldude.com/catalog/ind...=90_217_96_135
Currently I've got the Rota Grid (Volk te37 copies) which I really like for its simple design, so I'm really looking for the options out there...
verc is offline   Reply With Quote
Old 08-26-2009, 11:54 PM   #2
Crawdads
Member#: 30907
SWP GDB-G
Sportmax 050...Thats what I used a few years ago for a similar purpose. They are discontinued, but you might be able to pick up a set of used ones.
They are 17x9 and 38ish offset IIRC.
Crawdads is offline   Reply With Quote
Old 08-27-2009, 12:37 AM   #3
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
Rota DPT in 17x9 +42, only way to go!
Swing by the WheelDude BBQ this coming Wednesday and check them out in person!
dan avoN7 is offline   Reply With Quote
Old 08-27-2009, 10:18 AM   #4
mosc
Member#: 177401
2015 STi White
If you want to fit 255 under your fenders without doing serious work, offset is KEY! +48 is about ideal. I run 17x8.5" +48 with 255/40/17 and I'm just a couple mm from the strut and I still have slight rubbing on bumps on the rear fender lip. You can do +42 if you want, you'll just have 6mm more fender work to do. Camber helps but that requires special parts to get a decent amount.
There are 17x8.5" +48 5x100 choices out there, you just got to dig.
mosc is offline   Reply With Quote
Old 08-27-2009, 11:14 AM   #5
van_dutch
Member#: 198633
2004 WRX
What is your definition of inexpensive? How much are you looking to spend?
van_dutch is offline   Reply With Quote
Old 08-27-2009, 12:17 PM   #6
Mr. Sociable
Member#: 176200
1997 Toyota Tacoma
Was white once...
Drag DR-31 come in 17x9 +38 I think. Search Discount Tire Direct by size, they should be ~$130/wheel.
Mr. Sociable is offline   Reply With Quote
Old 08-27-2009, 12:28 PM   #7
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
I agree. DPT 17x9 +42
I wish they made it in +52-ish. Once I put the STi track under my wagon, the +42's will not work so well.
UFOpilot is offline   Reply With Quote
Old 08-27-2009, 02:04 PM   #8
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Thanks I'll look for those wheels. google'd up these Rota slipstreams that I didn't see on Wheeldude http://www.racinglab.com/rowhsl1751.html
I've got adjustable lateral links, so I was thinking the camber thing would be ok. I also have rolled and pulled fenders and I'm willing to straight cut them if needed (shouldn't need to based on searching threads)
Old 08-27-2009, 02:07 PM   #9
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Nice find! Wow these are cheap! http://www.nyxracing.com/drag-dr31-1...e-p-69310.html
Old 08-27-2009, 02:10 PM   #10
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Yup, I will - Sept 2nd right? I sent you guys an inquiry about if more 17x9 sizes would be available
WTB: 235/45/17, 245/40/17 or 255/40/17 tires BLACKWRX03 NWIC Private Classifieds 1 04-05-2009 07:11 AM
FS SOCAL: Yokohama Neova 255/40/17 tires (x2) Nimbus Wheels/Tires 0 01-18-2008 04:19 PM
Falken RT-615 255/40/17 Tires!! Spun Autosports Wheels/Tires 4 12-21-2007 08:51 AM
Yokohama ADVAN A032R 255/40/17 Tires sheizen Private 'For Sale' Classifieds 0 12-12-2005 04:51 PM
WTB: Used/New 245/40/17 or 255/40/17 tires joenationwide Private 'Wanted' Classifieds 2 12-01-2005 02:40 AM
