Old 07-17-2009, 09:57 PM   #1
Impreza541
Member#: 160822
2007 Forester XT
Beige
Default I need some insight on wheel bearings...
Searching on the subject I found some info, but not a whole lot, and not much on my year wrx.
Ive come to the conclusion of, well nothing really. I've found poeple saying its taken them from 45 minutes to 4 hours to complete, and also its not something a rookie should attempt...
My front driver side wheel is making a noise that sounds like a flat tire, but the tire is fine, which leads me to the assumption that it is most likely the wheel bearing, but like I said, I don't know alot about wheel bearings and diagnosing them. So now, I ask the guys at NASIOC for some advice.
2006 WRX TR Stage 2 w/ 63k miles...
Impreza541 is offline   Reply With Quote
Old 07-17-2009, 10:26 PM   #2
rotate tires....see if the noise moves
Old 07-17-2009, 11:22 PM   #3
Impreza541
Member#: 160822
2007 Forester XT
Beige
I will give that a shot..
Old 07-18-2009, 03:24 AM   #4
Horkus
Member#: 112667
2002 WRX wagon
sometimes even the tires will make that noise.
IF you have an other set of tires try do that too and see if it disappears.
Horkus is offline   Reply With Quote
Old 08-24-2009, 12:36 PM   #5
Impreza541
Member#: 160822
2007 Forester XT
Beige
So after rotating the tires the noise has moved to the rear, meaning that something is wrong with the wheel/tire? What should I do next?
Old 08-24-2009, 09:09 PM   #6
your alignment is bad
get the toe set to '0'
the noise is there to stay until you buy new tires....but it is alignment related and will only get worse until your alignment is fixed
Old 08-24-2009, 10:00 PM   #7
Impreza541
Member#: 160822
2007 Forester XT
Beige
Man that sucks, considering I bought my tires like 6 months ago.
Thanks scotty, Ill get my alignment set and go from there..
Old 09-15-2009, 01:18 PM   #8
gilg2533
Member#: 35332
Wow, youve been a tech since 1986 and have the stupidity to say this without seeing the car? Im glad you are not my tech, you must be one of the least educated, and most opinionated and often wrong people I have ever seen post on a forum. To the original poster, does the tire appear to have toe wear (gee scotty maybe you should have asked this first?) if not then take the car to where you purchased the tires and complain, if it does how bad is it?
gilg2533 is offline   Reply With Quote
Old 09-15-2009, 07:44 PM   #9
these kinds of issues are quite common with these vehicles and in most cases, when the noise moves when the tires are moved....it is a tire issue caused by an alignment issue and the most common issue that will cause this is toe
certainly, there are other possibilities....but, for the most part the irregular wear that a toe issue causes makes tires noisy even before it is visually apparent that there is a wear issue
and the information that is given and inferred, leads me to think that I'm right
and since joining in 2003 you have posted 15 times and one of these was to TRY to slam me
go troll some other board
Old 09-16-2009, 10:48 AM   #10
rick-l
Member#: 33868
2003 wrx
srp
My 2003 cups every brand of 17" tire I have tried. That may be your noise.
It is not alignment or struts on my car (changed checked).
rick-l is offline   Reply With Quote
Old 09-16-2009, 12:18 PM   #11
post your alignment sheet
and is it front or rear??
bet you have a mechanical issue that is causing this
Old 09-16-2009, 04:47 PM   #12
rick-l
Member#: 33868
2003 wrx
srp
This is the latest I can find. I didn't take your advice last time because you failed to explain how having -0.3 and -0.6 degrees of camber would cup the tires. It is all stock except for the wheels and tires (and struts). The front tires start roaring first after about 6,000 miles
...and.......
That alignment SUCKS....BAD.....ya want as much neg camber in front as you can get and mebbe get some camber bolts to take a bit of neg camber OUT of the back.
....and......lemme guess...ya put springs on it and didn't get an alignment after ya slammed it-----RIGHT????
Old 09-16-2009, 07:19 PM   #13
and that's that
Old 09-16-2009, 10:02 PM   #14
rick-l
Member#: 33868
2003 wrx
srp
and that's that
and what's what?
I need some insight on Intercoolers and some other thoughts. Nivekk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 08-24-2007 06:07 PM
Need some insight on road bikes wizzman Off-Topic 10 11-30-2005 04:27 PM
Need some Specs on Wheels for STi JDMTEG98 Tire & Wheel 5 09-17-2003 09:54 PM
Need some insights on several wheels S-WRX Brakes, Steering & Suspension 0 02-09-2002 06:23 AM
need some opinions on wheels skyhigh420 Interior & Exterior Modification 12 06-23-2001 02:58 PM
