Old 09-22-2009, 04:12 AM   #1
ejpowerguy
Member#: 175944
Default 4pot rotors same as wrx slider caliper rotors?
nevermind... found the answer finally after digging
ejpowerguy is offline   Reply With Quote
Old 09-22-2009, 08:11 PM   #2
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
maybe
the dba 4000 series says NO....most everybody else, YES
Old 09-23-2009, 02:59 AM   #3
CharT
Member#: 36117
2003 WRX Wagon
The way I understand it, DBA 5000 series has two versions with different aluminum hat designs but I think both use the same rotor. On the original 4-pot version, the hat interferes with the 2-pot sliding calipers or caliper bracket, don't remember which. The newer version designed for the 2-pots will also work with the 4-pots.
CharT is offline   Reply With Quote
Old 09-23-2009, 12:10 PM   #4
kumanchu
Member#: 146696
DBA makes their rotors a little thicker than factory spec, and causes clearance issues with the 4 pots.
A factory spec WRX front rotor will fit the 4-pot calipers.
kumanchu is offline   Reply With Quote
Old 09-23-2009, 03:49 PM   #5
Uncle Scotty
OK buy Nates beans
Originally Posted by CharT View Post
The way I understand it, DBA 4000 series has two versions with different aluminum hat designs
FULL STOP
THE DBA 4000 SERIES IS A CAST IRON ONE PIECE ROTOR AND HAS NO ALUMINUM OF ANY SORT IN ITS CONSTRUCTION
THEREFORE THE WHOLE POST IS JIBBERISH AND SHOULD BE EDITED TO DELETE MISINFORMATION
Old 09-23-2009, 03:52 PM   #6
Uncle Scotty
OK buy Nates beans
THERE ARE 3 PART NUMBERS ASSOCIATED WITH THE 4000 SERIES ROTORS THAT FIT EITHER THE SLIDING CALIPERS OR THE FIXED 4 POTS
BEWARE ORDERING THE CORRECT ONES
Old 09-23-2009, 04:23 PM   #7
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
DATA
DBA 1 piece:
Standard series - p/n 650 - fits 2 or 4 piston WRX w/294mm rotor
4000 series - p/n 4650 - Again fits all 2 or 4 piston 'WRX' applications. However - some street pads w/ shims on them may not fit w/ the shim as the rotor is intentionally a bit thicker to add heat mass. Take shims off - run a few weeks - if it gets noisy wait till they can fit.
p/n 4000 - Original 4000 series rotor w/ tapered HAT section to clear OUTBOARD ABS tone ring. This ABS system is all pre-2000 MY afaik.
5000 series:
p/n 5000 -the OG - fits 4 pot WRX (pre-USDM 2 pot)
p/n 5010 - fits 2 pot OR 4 pot front WRX calipers. This rotor was made when it was realized that the caliper bracket from the USDM WRX hit the rotor hardware on p/n 5000. Thus 5010 has a different design- the hardware is recessed for clearance.
KNS Brakes is offline   Reply With Quote
Old 09-23-2009, 05:01 PM   #8
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Thanks Ken, added to sticky.
jamal is online now   Reply With Quote
WTT WRX front rotors/brackets for RS rotors/brackets + WTB WRX rear caliper brackets Jard MAIC Private Classifieds 9 11-24-2009 09:38 AM
Are v3 4pots the same as 06-07 4-pots? morph1n3 Brakes, Steering & Suspension 11 12-11-2008 06:28 PM
2001 Legacy caliper same as WRX? sean.robb Brakes, Steering & Suspension 0 11-06-2008 11:11 PM
Are the Subaru 4pot discs the same as wrx? mattman_4444 Brakes, Steering & Suspension 1 04-25-2006 04:29 PM
Subaru 4 pots same as 300ZX TT calipers Chunky_Chicken Brakes, Steering & Suspension 45 09-19-2002 12:12 AM
