Old 01-12-2009, 10:49 AM   #26
smurfwrx
Member#: 151928
09 Triumph S3
Originally Posted by 4wdrift View Post
Ya gonna paint the alternator shroud?
That's what I was thinking. THat would look sharp.
smurfwrx is offline   Reply With Quote
Old 01-12-2009, 11:03 AM   #27
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Here's what it looks like a year later (except it's charcoal flake metallic)
Bad Noodle is offline   Reply With Quote
Old 02-20-2009, 03:33 AM   #28
JohnnyC
Member#: 186190
00 White LGT
09 F 2.5X Prem TGM
I definitely like the charcoal better. Nice job.
JohnnyC is offline   Reply With Quote
Old 02-20-2009, 09:29 AM   #29
litowrx
Member#: 132418
2004 EJ207
one question...
what that think you put on the right side fm pipe? next to the battery.. i was thinking of doing something similtar...once i almost electrecuted myself when taking out the baterry haha
and, i also did a radiator shroud maybe a year ago... i found that to have the bend done right, i had to make just a litle trace with a razor, and just did a few passes on where the bend is suposed to be. it looks like a more finished piece...maybe i'll post pics later..i recently took it out for paint
litowrx is offline   Reply With Quote
Old 02-20-2009, 12:12 PM   #30
DC16A2
Member#: 174357
2002 OBS
So, what's the benefit of having a "radiator shroud/cooling plate?" Does it separate flow or something? How well does it work with a funnel intake (like on a WRX)?
DC16A2 is offline   Reply With Quote
Old 02-20-2009, 12:36 PM   #31
Kiel
Member#: 133439
2003 WRX
Sonic Yellow - Stage Taxi
It forces airflow through the radiator rather than over top of it through the gap.
Kiel is offline   Reply With Quote
Old 02-20-2009, 12:54 PM   #32
DC16A2
Member#: 174357
2002 OBS
^Hmmm, thought so. Thanks!
Anyone have the documented difference in say coolant temperature with it on/off? I wonder if I should left a slot/gap on the passenger-side for the intake funnel...
Old 04-14-2009, 06:06 PM   #33
hoffmanEstates
Member#: 122043
04 wagonier
psm
do these cooling plates work. or do we like to think "they work"
hoffmanEstates is offline   Reply With Quote
Old 04-14-2009, 07:28 PM   #34
Carlito2002WGN
Member#: 18914
2006 WRX
Black with some stuff
IF these plates actually make a difference, I don't think that it would be in lower coolant temps, but rather in more efficiently lowering the coolant temp down to where it would be anyway due to the thermostat, from high temps that could result from high ambient temps and high load.
Did that make any sense? I know it did in my head.
Carlos
Carlito2002WGN is offline   Reply With Quote
Old 04-14-2009, 07:34 PM   #35
DeathSStar
Member#: 202982
It doesn't make the coolant in the radiator cooler, per se. It directs more airflow directly into the radiator, so there is more airflow through the radiator. I guess it may help coolant temps at lower speeds but on the highway I don't think you'd notice a difference.
Regardless, it looks good and it does help air flow through the radiator better.
DeathSStar is offline   Reply With Quote
Old 04-14-2009, 09:16 PM   #36
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTORŪ
nice work!
AlxSti is offline   Reply With Quote
Old 04-15-2009, 03:44 AM   #37
trueno16v
Member#: 175170
2005 WRX Wagon
owl + bungee cord= my a$$
Nice, some of you guys are frickin geniuses!
trueno16v is offline   Reply With Quote
Old 04-15-2009, 05:16 AM   #38
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
For street driving, one of these almost certainly will never be necessary. They do look nice, and I'm all about efficiency, particularly when it can be done cheaply.
If you are subjecting the engine to prolonged high loads (in other words, track days), you'll need to optimize the cooling system. Even with my N/A EJ25 the coolant temp stabilizes about 25degF above the thermostat when I do track events, and that's with an undertray and radiator shroud that both helped control temps. On my track-prepped Mustang I have the radiator almost fully boxed in so that air has no path to escape around the sides. It really starts to make a difference when you're flogging the car hard for 20 or 30min at a time.
Pat Olsen
Patrick Olsen is online now   Reply With Quote
Old 06-17-2009, 03:39 AM   #39
nbiesold
Member#: 204285
2007 WRX Wagon
Just did mine. pretty easy actually and i used a scrap piece i had lying around. way better than paying $60 for one and gave me something to do for the night.
nbiesold is offline   Reply With Quote
Old 06-17-2009, 10:08 AM   #40
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
I made mine this past weekend also. Fun little project! I didn't like how the expensive ones still left the gap between the grill bezel and the radiator support.
2point0 is offline   Reply With Quote
Old 06-17-2009, 10:28 AM   #41
FloridaGatorsJWett
Member#: 211150
04 STi - sold
looks good!
could you post a template of your shroud?
FloridaGatorsJWett is offline   Reply With Quote
Old 06-17-2009, 11:40 AM   #42
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
Umm...lol my template was a Sony DVD player box. I held it up to the radiator and made some marks, then measured for the sake of nice even numbers. After that, I just transferred those measurements to the sheet metal. Much of it was eye-balling and fine-tuning.
Old 06-24-2009, 02:30 AM   #43
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
good job! clean, looks like you bought it
feint05 is offline   Reply With Quote
Old 09-24-2009, 07:01 AM   #44
impreza2.0
Member#: 196374
Am I looking at a really stealthy FMIC in those pics, or is that an NA setup with tons of intake ramming going on? I don't know much about our internals yet, so what is going on outside is still somewhat new to me as well. I only know my own engine and what is done to it. Yours looks stock at first. Creepy.
impreza2.0 is offline   Reply With Quote
Old 09-24-2009, 08:33 AM   #45
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
"Creepy"?
Old 09-24-2009, 10:09 AM   #46
hoffmanEstates
Member#: 122043
04 wagonier
psm
i was going to make one, but found a $10 GTSpec for sale. cheaper then buying the sheet metal.
Old 09-30-2009, 01:55 PM   #47
peteh82
Member#: 146878
1996 Impreza Outback
Looks like your edges are round. How did you do it and what did you use? I want to make the edges round to prevent cutting myself while opening my hood in future.
peteh82 is offline   Reply With Quote
Old 09-30-2009, 04:05 PM   #48
klorti
Member#: 149231
2003 WRX
http://www.importtuner.com/tech/impp...els/index.html
Here's a recent document I came across. Not related to the Scooby community, but same concept.
klorti is offline   Reply With Quote
Old 09-30-2009, 04:20 PM   #49
juno09866
Member#: 212331
07 impreza
klorti beat me to it, but yes i read that article standing in target one day, very interesting, but the cf one on that nissan owns the aluminum one in design so i would expect that one to perform better.
juno09866 is offline   Reply With Quote
Old 09-30-2009, 11:34 PM   #50
RoxyTheImpreza
Member#: 205171
2004 Forester XT
Cayenne Red Pearl
use a dremel to sand down the edges
RoxyTheImpreza is offline   Reply With Quote
FS: SoCal --> APR WRX STI Carbon Fiber Radiator Shroud Cooling Plate silvergrey05 Exterior/Styling 6 03-13-2009 10:27 AM
****FOR SALE --> (08-09) WRX/STI - Beatrush Radiator Shroud/Cooling Plate *BRAND NEW BlueBoxer7 SCIC Private Classifieds 4 11-16-2008 11:49 PM
****FOR SALE --> (08-09) WRX/STI - Beatrush Radiator Shroud/Cooling Plate *BRAND NEW BlueBoxer7 Engine/Power/Exhaust 3 10-26-2008 11:05 PM
FS: 02-05 WRX/STi Kakumei radiator shroud, cooling plate. rexman2002 Engine/Power/Exhaust 1 07-16-2008 11:34 PM
Radiator shroud/cooling plate question FromEvoToRS37 Newbies & FAQs 4 10-10-2006 11:18 PM
