Old 10-01-2009, 01:13 PM   #76
fast71
Member#: 123735
2002 WRX PSM /2.5
Turbo_mike built, PPG'D
Question to the Gurus,
I just finish my hybrid motor break-in.
While changing the oil I notice some oil residue around the bolts holding the oil pan (2.0 pan). I cleaned out the area. 2 days later I see the oil again.
I'm a little confused to either replacing the 2.0 pan or get a sti pan? also what parts would I need?
I never had any issues with the 2.0 pan. Please help me decide.
Thanks.
fast71 is offline   Reply With Quote
Old 10-01-2009, 02:44 PM   #77
Gixxer1K
Member#: 81631
STI pan + dipstick + pickup + baffle. Use WRX dipstick tube.
Gixxer1K is offline   Reply With Quote
Old 10-01-2009, 03:19 PM   #78
fast71
Member#: 123735
2002 WRX PSM /2.5
Originally Posted by Gixxer1K View Post
STI pan + dipstick + pickup. Use WRX dipstick tube.
Thanks for the quick reply.. could you tell me what year would be best?
Old 10-01-2009, 03:29 PM   #79
Gixxer1K
Member#: 81631
Oops
2007 STI pan (11109AA151) + dipstick (don't have this #) pickup (15049aa110) + baffle (10915aa010)
Old 10-01-2009, 03:34 PM   #80
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
STi pan is better for performance driving. For track you may want to consider an aftermarket solution
06+ is a little bit better than the 05-05 STi Pan
KillerBMotorsport is online now   Reply With Quote
Old 10-01-2009, 03:37 PM   #81
fast71
Member#: 123735
2002 WRX PSM /2.5
Oops
Great, Thanks Gix!
Old 10-01-2009, 04:58 PM   #82
fast71
Member#: 123735
2002 WRX PSM /2.5
Thanks again!
Old 10-12-2009, 09:59 AM   #83
Shylight
Member#: 209812
Platinum Silver Metalic
KillerB please advise for WRX 2.0L is this complete set for installing STi oil pan or I missed something?
06-07 EJ25 STi oil pan 11109AA151
06-07 EJ25 STi dipstick 11140AA150
pickup 15049aa110
baffle 10915aa010
PS. I'll be using JDM EL exhaust manifold.
Thanks in advance!
Shylight is offline   Reply With Quote
Old 10-12-2009, 11:17 AM   #84
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Part numbers look right but you'll need a dipstick tube too, and not a a bad idea to replace the dipstick tube o-rings. The local hardware store should have these much cheaper than the factory pieces and they work just as well
Oh, and if you're going to keep the car for more than 30K miles after replacing the OEM pick up tube please beware of the failures that occur with this part. As you can imagine the results from such a failure are nearly always catostrophic. SEE PICS HERE.
Old 10-13-2009, 04:52 AM   #85
Shylight
Member#: 209812
I see. Could you tell me where can I get such ultimate pick up like in your album (for an STi EJ25 06-07 oil pan?
And by the way maybe you also know dipstick tube PN for STi oil pan?
Old 10-13-2009, 07:38 AM   #86
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Seems like you've found where to find it before I could answer
Not sure on the part number for the dipstick tube, but any dealer should be able to find that out for you.
Old 10-13-2009, 02:22 PM   #87
Gixxer1K
Member#: 81631
The STI dipstick tube doesn't fit on the WRX though, and the dipstick actually reads the exact same level regardless of which tube you use. Am I missing something?
Old 10-13-2009, 08:05 PM   #88
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Are you certain? I have both setups and they seem to fit on the EJ25 longblock no problem.
There is a thread around here somewhere that has pictures of the different dipsticks and dipstick tubes.
Old 10-13-2009, 09:46 PM   #89
Gixxer1K
Member#: 81631
I should have specified 2.0 WRX
Old 10-13-2009, 10:36 PM   #90
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I meant that too. The EJ20 setup I have (older 2.0 WRX) fits my EJ25 longblock.
The bracket is slightly different and the length from the bracket to the top end (where the dipstick goes in) is different. From the bracket down, they are identical. Maybe there was a part change mid year that I'm unaware of?
Old 11-09-2009, 11:33 PM   #91
RedWagon_04
Member#: 229530
2004 WRX
Red
So after spinning a rod bearing on a 2.5 hybrid setup (after spirited curvy road driving, aka Tail of the Dragon) I'll be replacing my oil pan with an 06+ STI oil pan... I'm also planning on the Cosworth baffle plate to ensure that doesn't happen again!
Are you aware of any fitment issues with using your pickup, an STi pan and the Cosworth baffle?
RedWagon_04 is offline   Reply With Quote
Old 11-10-2009, 12:19 AM   #92
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
PM'd you a couple options.
Old 12-02-2009, 07:42 PM   #93
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Great thread!
I'm getting ready to change the oil pan on my 03 WRX so I can run ELH.
Do you have a part # on the 06+ dip stick tube?
I would totally buy a Killerbmotorsport pickup if it was around $100 (which is still 4-5x higher then factory), but at $200 it's a tough buy.
Old 12-02-2009, 08:04 PM   #94
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by Fierysun View Post
Great thread!
This should be the part number for 06+ dipstick: 15144AA011
If you think $200 is a tough buy then you'd definitly not be happy about having to replace the shortblock (and more). It's cheap insurance if you look at it that way, and something you NEVER have to worry about again. I wish I could sell them for less, but it's a VERY robust design with features no one else offers and I wouldn't make any money selling them for $100. Pictures don't do the part justice. Hold one in your hands and it becomes immediately undestood that you can tow you car with this part.
And if cost is THAT much of an issue (you're not the only one that's cheap on here) I'll tell you what I tell them. Replace the OEM pickup every 26K miles and you'll be set. I have no documented failures before then and at ~$20 a pickup you can do it many times over the life of the car and spend less than the cost of my ultimate pickup.
Old 12-02-2009, 08:25 PM   #95
richy_21
Member#: 58670
2005 got muuuuu?
I think the dipstick tube is the same. Remember chris we measure both and there the same distance...
richy_21 is offline   Reply With Quote
Old 12-02-2009, 08:51 PM   #96
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
True, but you also have that wierdo JDM motor in there LOL
Old 12-03-2009, 01:55 AM   #97
richy_21
Member#: 58670
2005 got muuuuu?
...hater lol
Old 12-19-2009, 12:42 PM   #98
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
OK guys I could go on for pages and pages on why the STi pans are better, but I'll try to keep the rambling to a minimum.
Here are the 3 pans. OK, 4 pans, had to give myself a shameless plug
Obviously the WRX pan is flat bottomed and not as deep, vs the STi pans that form a closer fitting 'tub around the pickup. This gives the oil less pleces to slosh around to, and keeps the oil level higher on the pickup during operation.
Top Left: Killer B Motorsport Oil Pan
Top Right: OEM 2002-2005 EJ20 WRX Oil Pan Subaru number 11109AA053
Bottom Right: OEM 06+ EJ25 Impreza WRX/STi (STi, Legacy GT & Forester XT) Subaru number 11109AA151
Bottom Left: OEM 04-05 EJ25 Impreza STi (Legacy GT & Forester XT) Subaru number 11109AA131
As most of us know, the STi pan can be used mith many more header setups do to the kicked-in feature.
The dipstick location and angle, shape, length etc. is the same on all pans. This is the little tube ON the pan. The only difference is the length of the tube that the dipstick sits in. It's different on the EJ20 vs EJ25. That's why if you just change the dipstick when swapping to an STi pan your readings are off. I'm not entirely certain if the brackets on the dipstick tubes are the same (I'd think they would be), but swapping dipstick AND pan should give proper readings.
On to the baffling... You can see the WRX baffles have fewer passages and 2 levels of baffles. The STi pan has a much more clear flow path. Keep in mind one of the achilies to the Suby lubrication system isn't oil control IN the pan, it's GETTIN the oil to the pan quickly as it flows back from the heads. It doesn't do you much good to have good oil control in the bottom of the pan if the oil isn't getting there.
A lot of the perimiter of the WRX top baffle is sealed to the sides. On the STi pan almost the whole perimiter of the top baffle has a flow through gap. Also tough to see in this picture is that the lip around the baffles (upper and lower) pickup hole is curled up. This forces the oil to one of the hols in the baffle instead of going right down the middle.
Here's another shot of the EJ20 double level baffle. It's tough to tell by this picture but it's mostly sealed around the edges. The flow through path takes many direction. I'd be willing to bet, because most of the sides are sealed on the lower level, that under hard accel, decel, & corners that you can pool oil in some locations between the 2 baffles.
In case anyone cares, the weights go something like this: EJ20-heaviest, 04-05 EJ25 next, 06+ EJ25 a little lighter and the killer B Oil pan a little lighter than the 06+. This picture shows the 04-05 & 06+ EJ25 pans. IMO the 06+ is a better choice, because it leaves half as much oil in the pan when you do an oil change, it's lighter, and the baffling is slightly better (although I'm probably splitting hairs here). Just an FYI on the 04-05 pan there is 1/4 quart that doesn't come out during an oil change and a baffle around the inside of the drain plug so you can't pump it out.
Something else to note is that the baffle tray (sheetmetal piece that bolts to the bottom fo the block) should also be changed when doing an oil pan swap. They are cheap, and specifically designed to work with each pan.
Hope this helps
Just to add a footnote here. For those of you running JDM setups anything goes as far as what pan/dipstick tube/dipstick you've got in there. Safe bet is if you're going to a STi (or 06+ EJ25) pan is get the other stuff too.
Old 03-02-2010, 09:35 PM   #99
LeoNYC
Member#: 106583
1999 2.5RSTi
I've got a JDM 2.0 STi with an EJ257 block + pan but 2.0 dipstick + tube. I knew something was off after the first oil change. Car reads full after only 4 qts. I've just been adding 4.5qt on changes and then adding another half qt anytime the reading drops close to the F mark.
I just received my new dipstick+tube. Can I change the tube with the pan full or should I wait until the next oil change? I noticed the tube hole on the pan sits fairly high. I guess I'll just wait until the next change. In the meantime I'll try just the dipstick and see how that changes readings.
LeoNYC is offline   Reply With Quote
Old 03-04-2010, 03:06 PM   #100
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Not to get off topic, but has anyone looked at the oil pan on the 2010 legacy?
rexworx is offline   Reply With Quote
2.0 vs sti oil pump needawrx13 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-20-2009 09:19 PM
oem wrx shift kit vs. sti/wrx quick shift kit choiboi Transmission (AT/MT) & Driveline 1 09-21-2008 06:27 PM
anyone change a wrx oil pan to sti oil pan? 1WRX2NV Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-30-2007 09:32 PM
WRX US OEM vs STi/SPT sedan spring rates ... again ANZAC_1915 Brakes, Steering & Suspension 6 12-13-2001 12:52 PM
WRX Wagon Stock vs STi v5 struts/springs svxtrem Brakes, Steering & Suspension 0 06-08-2001 11:01 AM
