#51 |
Member#: 184753
Vehicle:me wantz all black 11' sti sedan |
^^ at the same time i still would like to get nearly 25-28mpg.
#52 |
Member#: 184753
another question to add.....i read somewhere (i think it was youtube lmao) that 04-05 rex's have thicker teeth in the gears (RA thickness) so would an RA 1-3 or 1-4 be even a real upgrade? no matter what i have to keep my stock 5th for gas mileage (and some hope of top end lol).
*RA users chime in here anytime now* *Any LGT gear runners found the breaking point of their boxes yet?* |
#53 |
Member#: 183009
Vehicle:2004 Fozzy XT Cayenne Red |
Is the 97 Outback tranny a direct bolt in a 02/03 WRX? If not what mods need to be done? Are these trannys known to be stronger than the "glass box" trannys? Thanks,
Shawn. ![]() |
#54 |
Member#: 215210
Hey Guys...Im really stumped....I need 4.11 ring and pinion for the rear of my 1993 JDM WRX Type RA...any suggestions where to find one?
#55 |
Member#: 184753
^^ send a PM to any of the tranny vendors on here they may be able to help you
#56 |
Member#: 3687
Vehicle:MY99 GF4 JDM 6spd NF Performance |
I don't believe they are any stronger. However with the slightly shorter gearing compared to the WRX, it puts less strain on them. You need to change over the clutch setup to the NA tranny stuff, and change slave cylinder, and matching rear diff. The NEWEST you can put on with the speed sensor is an '04 Outback. '05+ run off the ABS sensors for vehicle speed, but you can still have it done.
#57 |
Member#: 163128
SCIC
Vehicle:2001 Impreza 2.5rs RED |
thnx this was helpful
#58 |
Member#: 60743
Vehicle:'95 Impreza L dirty and on jack stands |
where should i look to compare gear ratios from a 95 impreza 4EAT and a 95 Legacy 4EAT?
#59 |
Member#: 3687
i would call the dealer and ask for Service, then gear ratios for those two. Some dealers will help you, some will say that information isn't attainable. I can call my guys up on it.
#60 | |
Member#: 60743
mine has been pretty good. will pop in there tomorrow. was hoping to find something online so i dont wear out my welcome there. my 95 legacy wagon trans is going out and it needs a replacement. all i can find right now is a EAT from a 95 impreza. |
#61 |
Member#: 193383
South East
Vehicle:2004 WRX WRB 97 Impreza Wagon |
Looking for some help Fuji,
Running 2.5/2.0 hybrid swap in my 02 WRX. Looking for mostly reliability. JDM STI RA gear set or LGT trans? |
#62 |
Member#: 3687
both of those arent bad choices. Difference would be gear spacing between those two. The LGT's gear spacing is similar to say a '00 2.5RS. The difference is that your tranny is a 3.900FD and the 2.5RS is a 4.111FD. Speed in each gear will be a tad faster in your tranny than a 2.5RS. The STi RA gearset you'll notice a taller 1st gear, which you may find helpful because you can get a bit more speed before shifting into 2nd for daily driving. After 1st gears, spacing is much shorter making acceleration much better, but note that 5th gear is a .825 ratio on a 3.900FD, which will have higher revs than stock; my JDM 6spd is a .842 with a 3.900FD.
#63 |
Member#: 99887
Vehicle:2002 tbxs stg 3 wrx black |
Anyone know the gear ratio and final drive ratio on a 07 jdm ver 7 sti tranny? I could only find them up to 06. Also can someone explain to me the 3.9 final drive in the front and 3.54 fd on the rear of the 02 wrx? When you calculate speed/rpm which final drive do you use? Thanks
#64 |
Member#: 184753
^^ the mechanical FD will equate to 3.9 because of the center diff. between the THREE diffs the FD will calculate to 3.90:1
#65 | |
Member#: 3687
But ratios are the same and they still rev to 8000rpms 3.636 / 2.375 / 1.761 / 1.346 / 1.061 / 0.842 The USDM STi that runs the 3.545FD rear diff uses a step up gear transfer gear with a ratio of 1.1:1. You take this 1.1:1 multiply it by 3.545 and you come REALLY close to 3.900; which is 3.8995. The rear diff with the FD ratio of 3.545 DOES spin slower than the 3.900FD of the same wheel speed. Wonder if they did this to reduce bearing wear and less heat??? |
#66 |
Member#: 125304
Probably less noise
#67 |
Member#: 222569
Vehicle:89 SilEighty Primer Grey | Red |
Wow.. This thread has shed a lot of light on things about gearing that I really didn't understand. Thanks Fuji.
#68 |
Member#: 90539
South East
Vehicle:95 L with ej20k powa, Raven R6 |
-Is there a confirmed correct list of rear diff ratios somewhere that's easy to access?
Thanks for any help Last edited by 2slofouru; 10-02-2009 at 08:34 PM. Reason: Edited because apparently the rest of my questions were irrelevant |
#69 |
n00b Moderator
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
anyone have the sti 3.166 first gear with 4.11?
do you have 0.738 or 0.825 fifth? if so what is speed @ 3k? |
#70 |
Member#: 57989
Vehicle:2011 F150 EcoBoost flame blue |
assuming 225/45/17 tires, with 4.11 fd...
3k rpm with .738 5th = ~73mph 3k rpm with .825 5th = ~65mph |
#71 |
Member#: 184753
#72 |
Member#: 57989
It's really not that bad at all. I have .738 5th with 4.44 fd and 3k rpm = 68mph. That is the slight downside, the upside being that 5th gear actually feels like a driven gear rather than an overdrive.
#73 |
Member#: 184753
i gotcha. sometimes with the stock 5MT it feels like an extra 6th gear would be nice for OD.
#74 |
Member#: 90539
South East
So would it be correct that a 03 standard wrx for example would have a 3.9 front ring and pinion, 1.1:1 tail section and 3.454 rear diff? Just trying to learn about how the ratios work.
#75 |
Member#: 184753
| Thread Tools | |
| Display Modes | |
| This why you learn to do your own vehicle maintenance. | BacDoc | Off-Topic | 156 | 02-22-2008 09:58 PM |
| Sources for learning to Tune your Car? | plus plus plus | Newbies & FAQs | 7 | 06-19-2007 03:56 AM |
| How to choose your own spring rates (and get the spring frequencies correct) | stretchsje | Brakes, Steering & Suspension | 2 | 05-16-2007 01:55 PM |
| Learn To Open Your Doors | Dooley | Mid Atlantic Impreza Club -- MAIC | 25 | 10-04-2006 04:15 PM |
| For crying out loud people, learn to title your threads well! | Brady | Off-Topic | 12 | 05-15-2005 08:57 PM |
