Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 10-05-2009, 02:55 AM   #1
Timon_479
Member#: 212007
MBP
Question Clutch/Timing Work
Well I'm pretty sure I'm going to need it done here pretty soon. I've only had the clutch slip on me 3 times, twice when starting off from a dead stop and the other when giving it about 30% throttle passing someone on the freeway.
The car has 86k on it, so it'd probably be a good idea even if it isn't happening constantly yet. I'm wondering if it's worth trying to do it myself in my drive way with hand tools (yes it sounds like a dumb idea to me too), or if anyone knows someone that can do it pretty cheap (like a side job of some sort). I can stand to have the car out of commission if needed, so it doesn't have to be done all in one day since I have a second vehicle.
Also with the mileage that is on it, would it be worthwhile to have the timing belt done at the same time (would it possibly save me any money on labor in the long run) ?
Anyway if anyone has some ideas let me know.
Timon_479 is offline   Reply With Quote
Old 10-05-2009, 03:06 AM   #2
EsubaruJ
Member#: 200008
03 wrx
TE72 wagon, Legacy wagon
PM Stoner hes good at this kind of stuff
EsubaruJ is offline   Reply With Quote
Old 10-05-2009, 08:13 AM   #3
stoner
Member#: 52863
2007 B7 A4
Thanks Buddy
Pm Sent
stoner is offline   Reply With Quote
Old 10-05-2009, 09:05 AM   #4
Jncominco2
Member#: 170212
i wouldnt be doing your timing that early...
Jncominco2 is offline   Reply With Quote
Old 10-05-2009, 11:25 AM   #5
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
If you pull the motor to do a clutch then a timing belt would be easy. But it doesnt need to be done until 103,000 miles.
bhhamblin is offline   Reply With Quote
Old 10-05-2009, 12:17 PM   #6
tabrad
Member#: 157229
02 WRX
If you have any mechanical ability at all, then you should just do it yourself. Its really not that hard at all.
I did mine about 2k miles ago in my driveway, I was expecting it to be super complicated, but what it came down to was loosening and tightening bolts (a lot of them)
tabrad is offline   Reply With Quote
Old 10-05-2009, 03:20 PM   #7
gilg2533
Member#: 35332
I wouldnt pull the motor to do a clutch, much easier to pull tranny.
gilg2533 is offline   Reply With Quote
Old 10-05-2009, 03:54 PM   #8
tabrad
Member#: 157229
02 WRX
Agreed
Old 10-05-2009, 06:06 PM   #9
David2004WRX
Member#: 125334
2004 Impreza WRX
Any one know if the timing for the o4 sti is the same for the 04 impreza wrx and how do you stop the cams from spinning when you remove the belt.
David2004WRX is offline   Reply With Quote
Old 10-05-2009, 07:55 PM   #10
Timon_479
Member#: 212007
MBP
The clutch I'm sure with enough time I could do as I've assisted in two others, but the timing is something I'm kind of iffy about simply because if it isn't done right then pop goes my valves if ya know what I mean. I've had a few recommendations from a lot of you, thanks. I'll be in contact with them. If anyone else has any suggestions I'm open to ideas.
Old 10-05-2009, 07:59 PM   #11
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
what clutch are you going with?
Old 10-06-2009, 07:16 PM   #12
subtech02
Member#: 215613
Default timming belt/clutch
factory parts or aftermarket all discounted if you get the parts 400.00 labor for everything belt and clutch.
Ralph @U3 motorsports
subtech02 is offline   Reply With Quote
Old 10-06-2009, 09:58 PM   #13
wetwilly1169
Member#: 122990
2004 WRX
JBP Wagon
If you go with a clutch Look at South Bend Clutch, very solid quality and outstanding price.
I just replaced my clutch in my 04 WRX wagon and it was... interesting.
Don't look to the guides on NASIOC, I found around four of them together were very helpful, but alone just confused me or skipped steps.
You don't have to pull the motor, it helps ALOT when freeing the transmission from the motor itself but its a lot of work to get it out. Plus its a tight squeeze with it in there.
The hardest part of the install was getting the transmission to break free, after 75K of wyoming winters and road debris it was a challenge but nothing a giant pry bar at a slow steady pace couldn't fix
If you have the money, have someone do it for you. If you can't imagine your baby in the hands of someone else (my case) its not that bad, a 4 out of 5 in difficulty though.
wetwilly1169 is offline   Reply With Quote
OT: Have down time @ work ? ? well here's a great way to kill time!! THE-95-STi Mid Atlantic Impreza Club -- MAIC 38 01-07-2008 02:55 AM
new clutch time? cordizzle Transmission (AT/MT) & Driveline 0 08-07-2004 06:20 PM
New clutch time... comments? SJwrx Transmission (AT/MT) & Driveline 2 08-06-2004 12:45 AM
It's clutch time! nunyo South East Region Forum 0 07-16-2004 10:08 PM
It's feeling like maybe new clutch time. Bob O Mid Atlantic Impreza Club -- MAIC 5 08-27-2002 04:15 PM
