#476 |
Member#: 193374
Vehicle:2002 wrx 2.5L Blue |
2002 wrx stock rims cheap tires with about 280whp first time to a drag strip. 12.6 @108mph 1.7 60ft
#477 |
Member#: 197673
Tri-State
Vehicle:2006 WRX limited WRB |
06 wrx limited
idk for the weight, idk for hp and torque, is been road tuned by mike at innovative tuning stock motor, tranny, clutch, turbo tuned for 17 psi, cx racing top mount COBB turbo back, grimmspeed 8mm spacers and TB waterline mod swift spring, whiteline antidive kit, COBB swaybars, everything else stock, stock 17's with falkens ZE912's heres my time, it was about a month ago, it was around 70 degrees that day, with ice on the top mound while waiting in the staging lane, launching at 5k slipping the clutch a little ![]() and heres a video to prove it |
#478 | |
Member#: 169716
Tri-State
Vehicle:2005 WRX STi PSM |
Where were you shifting? The 60' could be a little lower, but it's still not too bad. How far is this track from you? |
#479 |
Member#: 197673
Tri-State
in ESTA dragway in Cicero NY, is about a hour drive from my house and 3-5 mins from I90, i was shifting at 6K
#480 |
Member#: 188700
Tri-State
Vehicle:1990 325isT White |
08 STI - Stock AccessPort Cobb Stag1 93 octane
3780lbs 60' - 1.845 300 - 5.534 1/8 - 8.567 mph - 80.68 1000 - 11.199 1/4 - 13.422 mph - 101.41 Thoughts? |
#481 |
Member#: 197673
Tri-State
#482 |
Member#: 188700
Tri-State
first time in the sti. also first time awd.
What do you see in the numbers? |
#483 | |
Member#: 85199
AKIC
Vehicle:1988 EvolvedAK disco stick |
Last run at the track with the 20G on about 22 psi and 100 oct equivalent. Not what I wanted, but it is at least acceptable. Car will be back to stock by end of next month so no way to improve. Car #8458 (left) ![]() 1.7622 60' 7.8900 1/8 ET 88.60 1/8 MPH 12.3061 1/4 ET 110.89 1/4 MPH Last edited by AKLGT; 10-21-2009 at 08:07 PM. |
#484 |
Member#: 64673
NWIC
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
Took the family wagon out to the strip (PIR) one last time as it is the end of the season here in Oregon.
Only got one 12.998, but trapped a 110.26! ![]() Was having a hard time hooking up in first. Had some good power though, was 84 mph in the 1/8th and 109/110 in the 1/4, so I was picking up 25mph in the top end. Two best runs, these were also the last runs of the night back to back.... 60' 1.917 2.018 330' 5.519 5.644 1/8th 8.441 8.558 mph 84.70 84.92 1/4 12.998 13.092 mph 109.44 110.26 Full weight 1990 Legacy wagon, the family wagon.... Oh yeah, the ever important mods. 1990 Legacy wagon 2.5 NA block 100mm Wiseco pistons twinturbo heads from 1997 SPEC B Legacy, ofset oversize valves Borla header with custom up and down pipes, 2 1/2 and 3" exhaust NA intake manifold 800cc sidefeed injectors Blow through Modded JECS MAF EBAY T3/T4 turbo BigAss FMIC Greddy TRUST manual boost controller 6puck disk and 550torquepressure plate Tuned with PerfectPower6 (PP6) Last edited by reddevil; 10-25-2009 at 12:11 PM. |
#485 |
Member#: 197673
Tri-State
#486 |
Member#: 216027
heres my stage 2 08 wrx 13.5@100 stock I ran 14.5@95 I want High 12s on the stock turbo so next year some weight reduction is planned(especially for the 285lbs driver). Car is at full weight currently and running an xpt 93 map. e85 and a pump should net me my goal. |
#487 |
Member#: 152680
Vehicle:2002 ej22t 2.35 s363 surged aem ems 6spd wagon |
Updated slip:
11.75 @ 119 mph stock ej205 4800ft elevation ![]() Last edited by GeneralTJI; 12-17-2009 at 11:48 AM. |
#488 |
Member#: 130495
Not sure if i can submit my time on your list?
Australian built 1996 model GC8 Subaru WRX Built by Flat 4 Performance weight 3250pound with test dummy New PB ET 9.963 sec New PB MPH 149.02 mph 60ft 1.724 sec Half track 6.64sec at 115.67mph Ran on 27th January 2010 at Willowbank Raceway, Queensland, Australia Car is in True Street trim running on 98octane pump fuel Dot BFG street tyres Owned by Errol Brittain and Serge LaMonaca Driven by Errol Brittain Youtube link: http://www.youtube.com/user/EBSANE#p/a/u/0/hq0OkQ1KawE Please add to list if possible Errol Last edited by E.B.; 02-13-2010 at 08:28 AM. |
#489 |
Member#: 195743
Vehicle:08 wrx built ej25 lots of e85 |
this was last year, had a bad 60ft. since this run i have built the bottom end with forged internals, 1000cc injectors, act 6puck and hd pressure plate, new custom fmic, new custom sri, and hope to max out the td04 on e85. i already had a full 3" tbe, walbro 255, and some other little things. im shooting for low 12's, i guess we will see.
im on the right obviously, raced a busa haha ![]() |
#490 |
Member#: 111249
South East
Vehicle:'06 VF39 WRB WRX |
![]() On the right: 2006 wrx with vf39, css tmic, aps 65mm CAI, gms after-maf and inlet, ebcs, walbro 255lph, catless tbe, stock wheels w/ dunlop direzzas...I think that's it. It was in the 70's that day, located in central Florida. edit: open source tuned to ~20 psi. I feel like my times should be better, it was my first time with this setup at the track. Let me know what you think. |
#491 |
Member#: 152575
BAIC
Vehicle:2001 Honda S2000 Silverstone |
Well I made my first trip to the strip weds. at Infineon Raceway in Sonoma Ca. I've never raced before. 07 STi 3" turboback, aps 65 cai, walbro 255 fuel pump, hallman mbc, and protune on ca 91 octane 283hp/315tq. Here are my slips. First 2 no launch last run nailed the launch
#492 |
Member#: 237829
MWSOC
Vehicle:2005 WRX Sedan Black |
05 WRX premium with everything~ 5mt. stock ej205
Intake: Stock. Exhaust: Speedtech Catless TBE EMS: Romraider tuned by Testes1010 Turbo modificiations: none Engine modifications: Stock Drivetrain Modifications: 225/50/16 Dunlop Fierce All seasons (SUCK!) - Stock Rims Weight Reduction: Spare tire removed Gas Octane: 94 Suspension: Stock The MPH is so low becuase I had resolved that run to see if I could carry 3rd all the way through, and was bouncing off the rev limiter just before the 1/4. I think that if I had just shifted It would be a faster run. Also, with a run like this, if I have a better 60ft, say 1.8, how would that translate out into 1/4 time? (In other words, how fast can the car go if I dont suck?) ![]() |
#493 |
Member#: 231403
Vehicle:05 STi Aspen White |
SUPER HAPPY!!!!
![]() ![]() ![]() ![]() First time racing my 05 sti and an awd car! My best time for the night was 8.56 with a 1.9 60ft and I think 79mph. Whats weird is that the slower my time the higher my ET? I didnt get it. I got an ET as high as 82mph with 9.2 o_O Oh yeah my car is nearly dead stock, just a cai and act clutch with 10k on it. Oh yeah to all those thread saying "launch at 3.5k" I have no idea how people launch that low I had to go up to 5k and feather out the clutch. I baaaarely smelled it the two times I launched at 5k. |
#494 |
Member#: 113335
Vehicle:04 wrxVF39 282/266 05 STi AgileTuned 320/352 |
Launching at around 4500. Stage 2 OTS AP STi. 70deg, 50% humidity. I can't seem to get that 60' down. Could I be not letting the clutch out fast enough?
Best run of 4 (hot lapping, 4 runs in 30 mins, track was closing) ![]() 60' - 1.964 330 - 5.732 1/8 - 8.894 MPH - 78.17 1000 - 11.551 1/4 -13.792 MPH - 101.45 I'm getting a tune in two weeks then back to the track to compare. Last edited by pearljam11; 05-26-2010 at 08:15 PM. |
#495 | |
Member#: 231403
#496 |
Member#: 113335
#497 | |
Member#: 231403
I was just really happy to hit an 8.5. I have the timeslips at home, Ill post them up later today. |
#498 |
Member#: 231403
here it is! 05 sti with "cold air intake" and over 10k on a stage 1 act clutch kit. bLah, yes Im on the right
#499 |
Member#: 195623
MWSOC
Vehicle:2002 WRX STi swapped Built, PTE5830, PSM |
Time slip is in my car at DS1. But this was me last year (9/25/09) Out at the ****ty track by my house. After 3 fridays of going out to the track and getting 3 passes in each friday. I finally got this time.
I spun super bad in 1st gear. And had knock up top about 80'-90' from the end of the track. So let off. Reaction: +.1589 60' Ft: 1.8021 330' Ft: 4.9579 ET@594 Ft: 7.0899 1/8 ET: 7.5631 1/8 MPH: 95.10 1/4 ET: 11.7190 1/4 MPH: 118.42 And sorry for the facebook link, but this is the video my friend took on that pass. |
#500 |
Member#: 118533
NESIC
Vehicle:1999 rsd-wrx silver |
here is a link to my time slip in my 95 suby. gonna do some tuning and be in the 11's next time hopefully. it should be easy to reach
forgot to say im car 414http://www.facebook.com/photo.php?pi...00000937570310 Last edited by dougie fresh; 06-04-2010 at 11:59 AM. Reason: car 414 |
| Thread Tools | |
| Display Modes | |
| Happy Birthday cassieswrx your inappropriate pics here | car_cursed | Rocky Mountains Impreza Club Forum -- RMIC | 11 | 07-11-2008 02:23 AM |
| Add Your Timeslip Today! | Nick | Proven Power Bragging | 29 | 07-20-2004 10:06 AM |
| get your Hatorade pics here! | RidinLow | Tri-State Area Forum | 16 | 10-16-2002 11:24 PM |
| Post your leather pics here! | Fernely | Interior & Exterior Modification | 12 | 10-30-2001 10:15 AM |
