#1 |
Member#: 199522
RMIC
Vehicle:2004 Impreza STi PsM |
So this summer some of you knew I had some problems with my STI and misfires on cyl. 2 and 4. Well for the last couple months I have not been driving it and have been saving for a new engine.
Well I took it to a local shop for a comp test and leak down test to make damn sure it was the engine before I purchased a new short block. Results were 110 across the board....? ![]() So now to what is causing the misfire. The mechanic told me it may be an intake manifold leak? The car has all new injectors, I have tried new coilpacks, new ngk plugs one step colder. All I know is that I am super stoked now but I still have problems. Anyone else ever have this problem? Mods are; FP green, PE850, FMIC, 3" Catless and I am not sure if any of the other mods really matter. I know when John was tuning my car cyl 2 and 4 had a slight roughness and he was having troubles tuning it. Help please!
#2 |
n00b Moderator
Moderator Member#: 99397
RMIC
Vehicle:'13 BRZ, '13 STi SRs13 '83 Skyline '93 GTR |
aftermarket flywheel?
#3 |
Member#: 199522
RMIC
nope, stock clutch and flywheel
#4 |
Member#: 199522
RMIC
#5 | |
Member#: 99442
International
Vehicle:2006 SGM STI I'm on CORN YO! |
You need a better tune. I would change maps and see if it clears up the problem.... You are not the first person I have heard about with misfire codes from Johns tune. |
#6 |
Member#: 158043
RMIC
Vehicle:old Something new SWP |
You were out at tear apart auto this weekend wern't you!.
#7 |
Member#: 199522
RMIC
#8 |
Member#: 199522
RMIC
the shop also pulled these codes, which are new to me.
P0122 Throttle position sensor circuit low input P0123 Throttle position sensor circuit high input |
#9 |
Member#: 99442
International
Sometimes when I tinker with my car I get those cars on initial start up. I reset and they don't come back. Are yours coming on all the time?
#10 |
Member#: 199522
RMIC
yeah, I am guessing those two codes are the culprits when my car goes into limp mode. I will just be driving and all of a sudden it will just die out until it goes under 3k rpm and then it feels like i am driving a honda and it wont let me rev over 3k rpms.
It did this to me a few times while driving to SLC this weekend, it sucks when you are going down the free way and your car just dies out, haha. |
#11 |
Member#: 127704
TXIC
Vehicle:2013 Leggy Scooby no4 - huntin for 5 |
Check the wiring connections on your throttle inlet/ DBW unit, check connectors for pinches or frays, maybe even moisture breakdown dude.
Have you had the IC off recently? or any work in that area? |
#12 |
Member#: 143264
RMIC
Vehicle:2006 WRX TR Obsidian Black Pearl |
Your AVCS Solenoid on cyl. #2 and #4 may be going bad.
#13 | |
Member#: 199522
RMIC
Do these commonly go out and cause misfire codes? I am not to familiar with the AVCS. |
#14 |
Member#: 143264
RMIC
Not super common, but they do go out. When they go bad you will get misfires.
#15 |
Member#: 199522
RMIC
#16 |
Member#: 199522
RMIC
I think I am going to pull the AVCS banjo bolt filter out, hopefully that helps with my Idle issues.
#17 |
Member#: 143264
RMIC
#18 |
Member#: 199522
RMIC
Ok, well its going to Solid on the 30th to install my EWG setup and try to find my issues.
| Thread Tools | |
| Display Modes | |
| May need a new(er) laptop. Need some input. | wizzman | New England Impreza Club Forum -- NESIC | 21 | 10-29-2005 02:47 AM |
| Need some input. | 128d | Car Audio, Video & Security | 2 | 05-07-2002 04:37 PM |
| I need some input | Hittokiri Battousai | Interior & Exterior Modification | 1 | 03-17-2002 01:41 AM |
| needs some input | gnurider | Mid West Subaru Owners Club Forum -- MWSOC | 10 | 10-27-2001 01:13 PM |
| Gonna paint my calipers...need some input | Aaron'z 2.5RS | Interior & Exterior Modification | 3 | 09-25-2001 11:04 AM |
