#1 |
Member#: 187007
MAIC
Vehicle:2002 WRB WRX TPG tuned 301whp/303tq |
Car-
![]() 02 WRX Engine- EJ205 Stock 70mm APS cold air APS Hard inlet Small 16G/ 18.8psi Grimmspeed BCS Samco Hoses 06 STI tmic Engaged Performance P&P TB Engaged Performance TGV Deletes Ks tech 3mm phenolic spacer Deatschwerks 650cc/ Walbro 255 GT Spec header/up Pipe Moore Performance TBE Drive train- 05 JDM STI RA Spec-C transmission DCCD Pro Controller ACT heavy duty street clutch Dyno- DynoJet 70 degrees 35% humidity Standard CF Numbers- 301whp 303wtq Fuel- 93 Pump Graphs posted further down. Thanks for looking, Ian
#2 |
Member#: 178426
Vehicle:2010 Evo X MRt Silver |
Very nice, especially on 93. What kind of dyno was it one?
#3 |
Member#: 81102
MWSOC
is this on the stock ej205? Very nice numbers; post up a dyno sheet if you have one
#4 | |
Member#: 187007
MAIC
These numbers are on a Dyno Jet.
I'll post up the dyno sheet when I get it. |
#5 |
Member#: 43105
Great numbers and it was a good day on the dyno!! I had a great time comparing my new exhaust products to some other proven products that are already on the market and thanks for taking one of the first turbobacks I had to offer!! Great numbers and a butter smooth, fantastic sounding car that has 6 speed goodness! Enjoy!
#6 |
Member#: 205966
NWIC
Vehicle:2002 Impreza WRX Silver |
lbs of boost?
#7 |
Member#: 158313
Vehicle:2003 WRX PSM |
^It says 18.8 psi in the original post.
To the original poster: Was there a correction factor used? I'd like to see the dyno graph too. Any idea when it might be available? |
#8 |
Member#: 187007
MAIC
I honestly don't know about correction factor but I'll ask when I get the graphs.
Should be tomorrow. If not by the end of the week! |
#9 |
Member#: 193949
South East
Vehicle:BugI WRX "Rissa Roo" WRB E III XVIG |
Wow...those are GREAT numbers. When do you hit full boost and how is the tapering??
#10 |
Member#: 43105
Ok,
Here's a graph comparing the two closest dyno pulls in our dyno day comparison of my Moore Performance exhaust to the Turbo XS turboback. It’s neither the best “peak” pull for the Turbo XS or my exhaust, but Nate from TPG Tuning said that after looking through the logs these were the closest in comparison to each other with minimal differences. So, with the best apples to apples data the car was able to achieve +2whp and +19wtq. We should have his 301whp/303wtq graph tomorrow and I can post that as well. Btw, my website is not finished yet but if anyone has any questions or would like to see pics of the exhaust I'd be more than happy to get that for you. ![]() |
#11 |
Member#: 181617
MAIC
Vehicle:2004 wrx 6speed/ 330whp/ 300wtq |
How did you get so much torque?? Wish I had that much.
#12 |
Member#: 156955
SWIC
Vehicle:2006 STI UR GT35R w/ mad bolt ons |
Nice #'s man!
#13 |
Member#: 115276
MWSOC
Vehicle:04 PSM WRX FP 16g--UTEC+raided ROM |
Nice! We have a very similar setup. Only major difference is you have tgv deletes. Those are very good numbers you put down!
#14 | |
Member#: 187007
MAIC
The Exhaust had everything to do with the torque. When we put it on I lost 2psi of boost cause it flowed so much better.
Thanks man I built the car to get those number's and I even meet my boost goal of under 19psi to get them. ![]() Quote:
I'll post some pics of the setup soon. |
#15 |
Member#: 170973
Vehicle:2004 WRX 4EAT PSM |
when you say "exhaust" you are referring to TBE section only, and not the exhaust manifold correct? That was all that was changed?
I'm guessing the TurboXS TBE was not full 3" and not a straight through design on the muffler? If that's true, you should also be seeing gains up top, where there are none to be had. Interesting. I bet you could really give that 6-7K RPM hp curve a bump with an EWG setup! |
#16 | |
Member#: 187007
MAIC
Here's a couple pictures of the NEW TBE I put on the car. ![]() ![]() An EWG would probably get me a little more up top. Thanks |
#17 |
Member#: 43105
Remember too, that we ran the smaller core options (2.5") in both the center and rear muffler to keep things quiet and to have a better comparison to you're existing Turbo xs stealthback. I'd like to also compare a non-center muffler, and only a rear muffler(2.5" core) system to see what the gains would be.
#18 |
Member#: 81102
MWSOC
probaby just ~5hp at the most, but it will increase your spool and hold that boost rock solid
the big thing is the increase in ve it gives you and holding the boost rock solid seriously though, it's not the best mod in the world; for the price of the whole ewg system, I tell people to spend that money on turbocharger/intercooler; I use to be one of the biggest fans of ewg on the stock turbo, but you live and you learn. |
#19 |
Member#: 223592
pretty nice!
#20 | |
Member#: 170973
- an EWG here, and on any other setup for that matter, would definitly give more than 5hp difference. -It wont help him spool any faster. A BCS, yes. Pnp ex manifold, yes. Ported turbo, yes. EWG setup? NO. -I don't understand how you think he could hold the boost "rock solid" and increase the VE, yet only get 5hp. I have an EWG on my TD04 setup on the EJ205, and I know i gained more than 5hp. |
#21 |
Member#: 157158
MAIC
Vehicle:05 WRX stage 2 PSM |
WOW 301 WHP from a small 16g is insane.
#22 |
Member#: 187007
MAIC
#23 |
Member#: 43105
Alot of you were talking about how an ewg would help Ian's car..... Well, my car and his are VERY similar except we differ on a few parts including the external gate and I ran 23psi on pump gas. Here's the parts list and the graph. We ran on the same dyno, tuned by the same guy, etc. Ian and I were very excited to not only get his car tuned and test out my new exhaust parts but to see how our two cars would vary due to the ewg and higher boost. For me, this tune was to push the motor as far as possible on the little turbo so I could try to catch the damn evo's in autox! lol Ian and I both took some time for our individual cars to research our parts and to make what we think was good part selection. I think we have some of the fastest pump gas, small 16g, 2.0 liter cars around and autox should be a blast next year!
My parst list..... April 2009 Power on 93 octane pump gas : 328 whp 350 wtq Gt Spec unequal length header and custom IAG prepped 44mm EWG setup Tial 44mm polished EWG Engaged Performance ported/polished and coated Blouch small 16g turbo Engaged Performance prepped and coated 06 usdm STi TMIC Engaged Performance ported/polished and coated throttle body Engaged Performance ported and coated intake manifold and TGV deletes Grimmspeed 3mm phenolic manifold spacers and overbored upper manifold gaskets Motor Armour copper wrapped K&N CAI Stylin Motorsports IC and BOV hoses (black) Deatschwerks 650cc injectors Crucial Racial Systems coolsafe 160 degree thermostat Crucial Racing Systems 1.4 Bar radiator cap Samco radiator hoses Redline water wetter (75% water, 25% coolant) SPT polished rad shroud SPT polished turbo heat shield SPT oil cap 14.6lb AMS lightweight race battery and mounts Perrin turbo inlet tube Vishnu lightweight/underdrive crank pulley NGK iridium plugs Perrin fuel rails Walbro 255lph fuel pump Moore Performance 3” turboback exhaust GFB hybrid blow off valve Grimmspeed EBCS/Hallman MBC STi Group N motor mounts COBB V2 Access port engine management tuned by Nate at TPG Tuning Redline 15w-50 synthetic engine oil ![]() Last edited by impreza2; 10-28-2009 at 10:16 PM. |
#24 |
Member#: 115276
MWSOC
^^ Damn thats big numbers for a small 16g and no meth! You still on stock tranny?
#25 |
Member#: 170973
looks about right. You (Impreza2) are holding around 280-ish at 7k, whereas Ian's car is holding at about 262-263-ish at 7k.
So the EWG + BCS combo is definitely doing you good up top. I bet on 100oct unleaded you could hold out darn close to 300 at 7k. Thats a kick @$$ 16G right there! I'll second evan-Impreza....stock tranny? |
| Thread Tools | |
| Display Modes | |
| TPG Tuning and the SBR 20G | Five-seveN | Proven Power Bragging | 42 | 03-05-2009 07:39 PM |
| 02-03 EJ205 WRX ECU, Dom Tuned OpenECU 16g Setup, EBAY NOW | LatentWagen | Engine/Power/Exhaust | 1 | 11-14-2008 09:37 AM |
| lots of compressor flow maps, small 16g, large 16g, and 18g | prometheum | Factory 2.0L Turbo Powertrain | 0 | 10-10-2006 02:21 AM |
| small 16g vs big 16g | silverstreakwrx | Factory 2.0L Turbo Powertrain | 27 | 01-10-2006 02:51 AM |
