Welcome to the North American Subaru Impreza Owners Club Sunday December 21, 2014
Old 10-26-2009, 11:45 AM   #1
Venphic
Member#: 187007
2002 WRB WRX
TPG tuned 301whp/303tq
Default TPG Tuned Small 16G - EJ205 - 93octane
Car-
02 WRX
Engine-
EJ205 Stock
70mm APS cold air
APS Hard inlet
Small 16G/ 18.8psi
Grimmspeed BCS
Samco Hoses
06 STI tmic
Engaged Performance P&P TB
Engaged Performance TGV Deletes
Ks tech 3mm phenolic spacer
Deatschwerks 650cc/ Walbro 255
GT Spec header/up Pipe
Moore Performance TBE
Drive train-
05 JDM STI RA Spec-C transmission
DCCD Pro Controller
ACT heavy duty street clutch
Dyno-
DynoJet
70 degrees
35% humidity
Standard CF
Numbers-
301whp
303wtq
Fuel-
93 Pump
Graphs posted further down.
Thanks for looking,
Ian
Venphic is offline   Reply With Quote
Old 10-26-2009, 03:40 PM   #2
rexblake
Member#: 178426
2010 Audi S4
Very nice, especially on 93. What kind of dyno was it one?
Old 10-26-2009, 03:45 PM   #3
CatfaceType-R
Member#: 81102
is this on the stock ej205? Very nice numbers; post up a dyno sheet if you have one
Old 10-26-2009, 04:23 PM   #4
Venphic
Member#: 187007
2002 WRB WRX
These numbers are on a Dyno Jet.
Its the stock ej205.
I'll post up the dyno sheet when I get it.
Old 10-26-2009, 10:16 PM   #5
impreza2
Member#: 43105
Great numbers and it was a good day on the dyno!! I had a great time comparing my new exhaust products to some other proven products that are already on the market and thanks for taking one of the first turbobacks I had to offer!! Great numbers and a butter smooth, fantastic sounding car that has 6 speed goodness! Enjoy!
impreza2 is offline   Reply With Quote
Old 10-27-2009, 03:57 PM   #6
mapleWRX
Member#: 205966
2002 Impreza WRX
lbs of boost?
mapleWRX is offline   Reply With Quote
Old 10-27-2009, 05:18 PM   #7
jason miller
Member#: 158313
^It says 18.8 psi in the original post.
To the original poster: Was there a correction factor used? I'd like to see the dyno graph too. Any idea when it might be available?
jason miller is offline   Reply With Quote
Old 10-27-2009, 06:02 PM   #8
Venphic
Member#: 187007
2002 WRB WRX
I honestly don't know about correction factor but I'll ask when I get the graphs.
Should be tomorrow. If not by the end of the week!
Old 10-27-2009, 08:20 PM   #9
SacksLax
Member#: 193949
BugI WRX "Rissa Roo"
WRB E III XVIG
Wow...those are GREAT numbers. When do you hit full boost and how is the tapering??
SacksLax is offline   Reply With Quote
Old 10-27-2009, 10:49 PM   #10
impreza2
Member#: 43105
Ok,
Here's a graph comparing the two closest dyno pulls in our dyno day comparison of my Moore Performance exhaust to the Turbo XS turboback. It’s neither the best “peak” pull for the Turbo XS or my exhaust, but Nate from TPG Tuning said that after looking through the logs these were the closest in comparison to each other with minimal differences. So, with the best apples to apples data the car was able to achieve +2whp and +19wtq. We should have his 301whp/303wtq graph tomorrow and I can post that as well. Btw, my website is not finished yet but if anyone has any questions or would like to see pics of the exhaust I'd be more than happy to get that for you.
Old 10-27-2009, 11:04 PM   #11
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
How did you get so much torque?? Wish I had that much.
Brother EddieJ. is offline   Reply With Quote
Old 10-27-2009, 11:46 PM   #12
Iflysti06
Member#: 156955
2006 STI
UR GT35R w/ mad bolt ons
Nice #'s man!
Iflysti06 is offline   Reply With Quote
Old 10-27-2009, 11:50 PM   #13
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
98 RS- WRX swap complete!
Nice! We have a very similar setup. Only major difference is you have tgv deletes. Those are very good numbers you put down!
evan_impreza is offline   Reply With Quote
Old 10-28-2009, 12:15 AM   #14
Venphic
Member#: 187007
2002 WRB WRX
The Exhaust had everything to do with the torque. When we put it on I lost 2psi of boost cause it flowed so much better.
Originally Posted by Iflysti06 View Post
Nice #'s man!
Thanks man I built the car to get those number's and I even meet my boost goal of under 19psi to get them.
Not only are the TGV's gone but all the holes have been welded over and smoothed out, so the intake manifold is like a Japanese longtube one.
I'll post some pics of the setup soon.
Old 10-28-2009, 01:42 AM   #15
xsnapshot
Member#: 170973
2004 WRX 4EAT
when you say "exhaust" you are referring to TBE section only, and not the exhaust manifold correct? That was all that was changed?
I'm guessing the TurboXS TBE was not full 3" and not a straight through design on the muffler? If that's true, you should also be seeing gains up top, where there are none to be had. Interesting.
I bet you could really give that 6-7K RPM hp curve a bump with an EWG setup!
xsnapshot is offline   Reply With Quote
Old 10-28-2009, 09:57 AM   #16
Venphic
Member#: 187007
2002 WRB WRX
The TBE was all that was changed. The TurboXs tbe was a cat-less 4" bell-mouth with the 2.5" standard/stealth axle back. The New tbe is a 3" DP with a divorced 2" pipe for the internal gate with a full 3" out the back.
Here's a couple pictures of the NEW TBE I put on the car.
An EWG would probably get me a little more up top.
Old 10-28-2009, 11:55 AM   #17
impreza2
Member#: 43105
Remember too, that we ran the smaller core options (2.5") in both the center and rear muffler to keep things quiet and to have a better comparison to you're existing Turbo xs stealthback. I'd like to also compare a non-center muffler, and only a rear muffler(2.5" core) system to see what the gains would be.
Old 10-28-2009, 01:46 PM   #18
CatfaceType-R
Member#: 81102
probaby just ~5hp at the most, but it will increase your spool and hold that boost rock solid
the big thing is the increase in ve it gives you and holding the boost rock solid
seriously though, it's not the best mod in the world; for the price of the whole ewg system, I tell people to spend that money on turbocharger/intercooler; I use to be one of the biggest fans of ewg on the stock turbo, but you live and you learn.
Old 10-28-2009, 01:47 PM   #19
AllOverSTi
Member#: 223592
pretty nice!
AllOverSTi is offline   Reply With Quote
Old 10-28-2009, 07:19 PM   #20
xsnapshot
Member#: 170973
2004 WRX 4EAT
He's not on the stock turbo....
- an EWG here, and on any other setup for that matter, would definitly give more than 5hp difference.
-It wont help him spool any faster. A BCS, yes. Pnp ex manifold, yes. Ported turbo, yes. EWG setup? NO.
-I don't understand how you think he could hold the boost "rock solid" and increase the VE, yet only get 5hp.
I have an EWG on my TD04 setup on the EJ205, and I know i gained more than 5hp.
Old 10-28-2009, 07:51 PM   #21
SlverEJ20
Member#: 157158
05 WRX stage 2
WOW 301 WHP from a small 16g is insane.
SlverEJ20 is offline   Reply With Quote
Old 10-28-2009, 08:02 PM   #22
Venphic
Member#: 187007
2002 WRB WRX
THANKS
Old 10-28-2009, 11:09 PM   #23
impreza2
Member#: 43105
Alot of you were talking about how an ewg would help Ian's car..... Well, my car and his are VERY similar except we differ on a few parts including the external gate and I ran 23psi on pump gas. Here's the parts list and the graph. We ran on the same dyno, tuned by the same guy, etc. Ian and I were very excited to not only get his car tuned and test out my new exhaust parts but to see how our two cars would vary due to the ewg and higher boost. For me, this tune was to push the motor as far as possible on the little turbo so I could try to catch the damn evo's in autox! lol Ian and I both took some time for our individual cars to research our parts and to make what we think was good part selection. I think we have some of the fastest pump gas, small 16g, 2.0 liter cars around and autox should be a blast next year!
My parst list.....
April 2009 Power on 93 octane pump gas : 328 whp
350 wtq
Gt Spec unequal length header and custom IAG prepped 44mm EWG setup
Tial 44mm polished EWG
Engaged Performance ported/polished and coated Blouch small 16g turbo
Engaged Performance prepped and coated 06 usdm STi TMIC
Engaged Performance ported/polished and coated throttle body
Engaged Performance ported and coated intake manifold and TGV deletes
Grimmspeed 3mm phenolic manifold spacers and overbored upper manifold gaskets
Motor Armour copper wrapped K&N CAI
Stylin Motorsports IC and BOV hoses (black)
Deatschwerks 650cc injectors
Crucial Racial Systems coolsafe 160 degree thermostat
Crucial Racing Systems 1.4 Bar radiator cap
Samco radiator hoses
Redline water wetter (75% water, 25% coolant)
SPT polished rad shroud
SPT polished turbo heat shield
SPT oil cap
14.6lb AMS lightweight race battery and mounts
Perrin turbo inlet tube
Vishnu lightweight/underdrive crank pulley
NGK iridium plugs
Perrin fuel rails
Walbro 255lph fuel pump
Moore Performance 3” turboback exhaust
GFB hybrid blow off valve
Grimmspeed EBCS/Hallman MBC
STi Group N motor mounts
COBB V2 Access port engine management tuned by Nate at TPG Tuning
Redline 15w-50 synthetic engine oil
Old 10-29-2009, 02:45 AM   #24
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
^^ Damn thats big numbers for a small 16g and no meth! You still on stock tranny?
Old 10-29-2009, 02:59 AM   #25
xsnapshot
Member#: 170973
2004 WRX 4EAT
looks about right. You (Impreza2) are holding around 280-ish at 7k, whereas Ian's car is holding at about 262-263-ish at 7k.
So the EWG + BCS combo is definitely doing you good up top.
I bet on 100oct unleaded you could hold out darn close to 300 at 7k. Thats a kick @$$ 16G right there!
I'll second evan-Impreza....stock tranny?
TPG Tuning and the SBR 20G Five-seveN Proven Power Bragging 42 03-05-2009 08:39 PM
02-03 EJ205 WRX ECU, Dom Tuned OpenECU 16g Setup, EBAY NOW LatentWagen Engine/Power/Exhaust 1 11-14-2008 10:37 AM
lots of compressor flow maps, small 16g, large 16g, and 18g prometheum Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-10-2006 03:21 AM
small 16g vs big 16g silverstreakwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 01-10-2006 03:51 AM
