Old 10-28-2009, 01:01 PM   #1
bend_bugeye
Member#: 210459
'03 WRX 2.5 20G
Default 2003 Bugeye 2.0L Evo III 16G tuned by Surgeline
Got tuned yesterday up at Surgeline and here are the results.
Boost levels were kept fairly conservative to save my stock transmission. Once I do get a 6spd swap I will not hesitate to bring my car back to Tim and the team at Surgeline Tuning, very professional and helpful! Thanks Surgeline.
Event:
Dyno tune
Ambient Temp: 45 F
Elevation: at sea level
Weather: Wet
Tires: Bridgestone Blizzak 205/60/16
Car: 2003 WRX
Tuner: Tim Bailey
Dyno Info: Mustang
Peak HP: 292
Peak Torque: 271
Target Boost: 19 psi
Target AFR: 12.1
Fuel: Chevron 92 octane
Mods done by
Barrett Dash @ All Wheels Driven
Engine/Power Modifications:
Blouch Evo III 16G
DW 750cc
Walbro 255 pump
Perrin Turbo inlet
Stock airbox w/ snorkus removed
K&N drop in filter
STi TMIC
Grimmspeed EBCS
Grimmspeed deleted TGVs
Grimmspeed Phenolonic spacers
Grimmspeed PnP & coated manifolds
Grimmspeed coated crosspipe
Grimmspeed coated catless uppipe
Invida catless downpipe
Borla hush exhaust
Driveline Modifications: Stock
Suspension Modifications: H&R sport springs
bend_bugeye is offline   Reply With Quote
Old 10-28-2009, 01:42 PM   #2
BONFIRE074
Member#: 166936
2006 Unicorn
Saabaru 9-2x
Wow nice graph for sure
BONFIRE074 is offline   Reply With Quote
Old 10-28-2009, 02:02 PM   #3
Longshot55
Member#: 164121
2005 WRX EvoIII 16G
EFI Logics Tuned
Impressive.
Longshot55 is offline   Reply With Quote
Old 10-28-2009, 02:05 PM   #4
SLDWYZ
Member#: 85008
03 wrx
blue
not possible...... what is the correction factor
SLDWYZ is offline   Reply With Quote
Old 10-28-2009, 02:14 PM   #5
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
45 degrees and at sea level.... doesn't seem 'unpossible.'
Audiosavvy is offline   Reply With Quote
Old 10-28-2009, 03:36 PM   #6
bend_bugeye
Member#: 210459
'03 WRX 2.5 20G
Zero correction.
Old 10-28-2009, 03:39 PM   #7
bend_bugeye
Member#: 210459
'03 WRX 2.5 20G
Originally Posted by Longshot55 View Post
Impressive.
Thanks for the feedback.
Old 10-28-2009, 03:41 PM   #8
SLDWYZ
Member#: 85008
03 wrx
blue
all mustang dyno have a correction factor ... all dynos for that matter have a correction factor .... most have it on the graph
Old 10-28-2009, 03:51 PM   #9
MonopolyMan
Member#: 224622
2005 Legacy GT
Red
I love the torque curve =)
MonopolyMan is offline   Reply With Quote
Old 10-28-2009, 04:01 PM   #10
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
12:1 target AFR on a tmic??? Seems a little ballsy.
Good power though, save your tranny now lol.
project_skyline is offline   Reply With Quote
Old 10-28-2009, 04:59 PM   #11
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
Congratulations. Tim is the guy to go to for sure.
SLDWAYZ: Why don't you contact Surgeline and ask Tim ? Not sure what your point is, as I doubt you are coming to get a tune out here, though many folks have. Are you attempting to compare two dynamometers from two different parts of the country ? You do know it doesn't work like that right ? Stop worrying about specific numbers and start paying attention to the part that is actually important, if you even know which part that is.
UFOpilot is offline   Reply With Quote
Old 10-28-2009, 05:10 PM   #12
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Where do you see full boost (or at least say 17psi)? That torque curve looks good, the whole curve in general looks just like it should.
Old 10-28-2009, 05:12 PM   #13
rexblake
Member#: 178426
2010 S4
Gray
very nice.
Old 10-28-2009, 05:34 PM   #14
SacksLax
Member#: 193949
Wow...very, very impressive
SacksLax is offline   Reply With Quote
Old 10-28-2009, 06:07 PM   #15
JamesBernard
Member#: 180038
IB You dont even
own a subaru!
why no E85 tune?
my friend had basically the same setup, almost exactly the same. and he made like 300/310 on pump and 320/333 on E85. Same place same tuner.
a 6spd will really let out the beast
JamesBernard is offline   Reply With Quote
Old 10-28-2009, 06:08 PM   #16
bend_bugeye
Member#: 210459
'03 WRX 2.5 20G
I'm actually not sure what his target AFR was, I just posted what the average came out on the graph, But I trust his judgment on what it should be at for my setup.
3600 - 3700 @ 17psi in 3rd. I am going to log some pulls and see where it's at in 2nd and 4th.
Old 10-28-2009, 06:10 PM   #17
bend_bugeye
Member#: 210459
'03 WRX 2.5 20G
Originally Posted by JamesBernard View Post
why no E85 tune?
No E85 in Bend What is your friend running for boost levels on pump gas?
Old 10-28-2009, 07:43 PM   #18
JamesBernard
Member#: 180038
IB You dont even
own a subaru!
I want to say around 21.5 on pump gas and a little over 23 on E85, tim said we could have upped the boost more but he was missing something he needed to safely run over 23 psi, im not sure what it was.
but coming from stage two it was quite a jump.
Old 10-28-2009, 08:41 PM   #19
kornykidd0
Member#: 156466
2008 E90 M3
Jerez Black Metallic
glad to see you got numbers like that with only 19psi on a mustang no less. I'm putting together my evo3 setup now and its fairly similar to yours. How many miles on your car if you don't mind me asking? how did Tim feel about tuning it with that setup (assuming your fairly high miles)?
kornykidd0 is offline   Reply With Quote
Old 10-28-2009, 10:20 PM   #20
bend_bugeye
Member#: 210459
'03 WRX 2.5 20G
80k miles. Tim was liking how the tune came out and how good my car was running for the mileage.
Old 10-28-2009, 11:04 PM   #21
mongoosaroo
Member#: 115056
2002 psm now w/ 2.5
jesus tuned my hot rod
that's a beautiful torque curve! good power as well. enjoy your new power!
mongoosaroo is offline   Reply With Quote
Old 10-28-2009, 11:42 PM   #22
burtonboy759
Member#: 178707
2002 BUGEYE HYBRID
MBP- NO ITS NOT BLUE
I recently got tuned on my Evo III with very close to the same mods and numbers! Will be posting up my graphs once i fix my header leak...
Very nice numbers! This turbo is def awesome for the 2.0 Enjoy it!
burtonboy759 is offline   Reply With Quote
Old 10-29-2009, 12:08 AM   #23
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
lucky!!!!! sea level numbers!!!!
congrats!
Surgeline tuned: Evo III 16G. I am pleased ! UFOpilot Proven Power Bragging 27 09-03-2009 08:29 PM
WTB: 16g, big 16g, or Evo III 16g bcWRX-02 Private 'Wanted' Classifieds 17 08-28-2008 02:40 AM
Evo III 16g good on 2.5?? C-grunt Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 02-18-2008 12:16 PM
Evo III 16G on 2.0 question Dynasty336 General Community 16 07-16-2007 07:22 PM
which do i get? EVO III 16G vs 16G vs TDOH5 16G subbiedo04 Newbies & FAQs 21 01-14-2007 06:49 AM
