Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 10-28-2009, 07:00 AM   #1
wrxcbr6rr
Member#: 203895
06 TR
blk
Default 06 wrx 6speed vf39 gs bcs datalog review please help??
i just relashed my rex using bcs925's 07 wrx map vf39, tmic, gs 3port bcs, tbe, 93 oct, i found it on romraider forums base maps.. i am running same mods plus 6speed and using cali 91oct the car runs great but i have a cel and blinking cruise light.. a generic scanner will not read my ecu.. im pretty sure i have a knock.. im a noob at tuning and am having trouble gaining tuning knowledge somebody please help!!!
I have uploaded my datalog to rapidshare..
http://rapidshare.com/files/29900403...94523.csv.html
wrxcbr6rr is online now   Reply With Quote
Old 10-28-2009, 07:55 AM   #2
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
For the love of god do not drive the car at anything > 50% throttle until you get this fixed. I'm not even going to comment on running a 93map but using 91. You have way too much feeback knock correction, actually surprised you car's still running. You managed to max out the fbkc at peak torque...
My advice is to start at the beginning or get a different map. Lower the boost, get a wideband a/f sensor (stock is useless), and lower the timing.
Bad Noodle is offline   Reply With Quote
Old 10-28-2009, 11:35 PM   #3
elevenpoint7five
Member#: 187798
2004 WRX
Fueled By Corn
View Member's Myspace Profile
Don't use maps that are designed for 93oct when you run 91. ESPECIALLY California 91...
elevenpoint7five is offline   Reply With Quote
Old 10-29-2009, 02:29 AM   #4
wrxcbr6rr
Member#: 203895
06 TR
blk
thanks for your help.. im gonna put back stock bcs and reflash the s****y cobb map i have and enjoy a whopping 11 lbs of boost on a vf39 if someone can help me out with a better map or help tuning the cobb map after i flash and log that would be great..
Old 10-29-2009, 07:47 AM   #5
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
^I'm pretty sure you should be seeing 17 on the cobb map. Did you get the right restrictor pill?
No offense, but it sounds like you need stop what you're doing and do some reading.
Old 10-29-2009, 08:07 AM   #6
udelslayer
Member#: 117214
2003 WRX Wag'n Wagon
Clear
Please provide everyone your VIN number.....
so they know to run when this car goes up on the auction block...
udelslayer is offline   Reply With Quote
Old 10-30-2009, 09:05 PM   #7
wrxcbr6rr
Member#: 203895
06 TR
blk
Default Blah
I was only hitting 11 psi on Cobb stage 3 vf39 map.. I purchased correct drill bit for restrictor pill, I also tried 04 sti restrictor pill and hose assembly(which is the correct size), and had the same result, 11 psi.. I already reflashed that Cobb map again and stck bcs and in the process of doing a compression test and getting a Clark Turner map..
Old 10-30-2009, 09:10 PM   #8
wrxcbr6rr
Member#: 203895
06 TR
blk
Default Haha
Btw udelslayer.. I was lookin for help, not douchebag comments
Old 11-03-2009, 04:15 PM   #9
wrxcbr6rr
Member#: 203895
06 TR
blk
so i did a compression test and i came up with 120 112 124 122.. im guessing this is not too good.. i have yet to do a leak down test. i was also told timing belt can skip and lower compression.. so i might change that as well..
Old 11-03-2009, 04:46 PM   #10
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
yeah, 2 doesn't look too good.... any chance you cracked a ringland?
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 08:55 PM.
