Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 11-02-2009, 07:43 PM   #1
chubifcr
Member#: 214797
2002 Impreza WRX STI
Angry ej207 ver. 7 BC stage 3 cams
Hi everyone i will like to know if BC stage 3 cams can work with a ej207 version 7 engine.
by thw way, i already know bc stage 3 cams dont work with avcs, but they can be deleted with a little work.
what do you think guys? do you think this will work?
Chubi
chubifcr is offline   Reply With Quote
Old 11-02-2009, 10:47 PM   #2
RA Limited
Member#: 171249
1994 Sambar Dias 4x4
Green
why the angry face?
RA Limited is offline   Reply With Quote
Old 11-02-2009, 11:05 PM   #3
sorrowfulkiller
Member#: 170439
talk to someone at brian crower first
sorrowfulkiller is offline   Reply With Quote
Old 11-03-2009, 04:11 PM   #4
chubifcr
Member#: 214797
Because i talk to someone at BC and they told me: sorry this cams are non compatible with ej207..... and in the website it says that this cams can work with ej207, but you have to delete avcs ( its says this is a very little work).
please helpppppppppppppppp
Old 11-03-2009, 07:57 PM   #5
jaxscuby
Member#: 10613
blue
if the cams are non-avcs you answered your own question.
jaxscuby is online now   Reply With Quote
Old 11-03-2009, 08:08 PM   #6
whatishe
Member#: 65711
2004 WRB WRX Wagon
w/ EJ207 & 6MT Swap
Is it just a 207 bottom end (block) or do you have the whole long block (bottom end + heads)? If you are running a 207 block with 205 heads, you'll have no issues, put the cams in. If you are running a full 207 block with JDM ecu, you need cams specific for those heads. The 207 heads are different from the 205 and have different cams. You will most likely need Stage 3 cams designed and ground for your application. If you do have 207 heads, you can try just deleting the AVCS, but that is kind of dumb, since AVCS is one of the most attractive features of those heads. If you do delete the AVCS, you'll still need cams designed for the 207 as the 207 cams have a longer duration and a different lift from cams designed for use in a USDM model.
whatishe is offline   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 09:26 PM.
