#1476 |
Member#: 165558
Tri-State
Vehicle:2003 RS6 Silver |
you can get from us lol it should polish them up good.
#1477 |
Member#: 165558
Tri-State
Many of you have asked for it so here it is a HUGE Special I mean HUGE Special on our UBER Foam Pads and Microfiber!
If there was a time to stock up...... well its now! Here it is ----- 20% off all Uber Buffing Pads as well as LC Wool Pads and leftover LC Foam Pads. Uber Yellow/ Uber Orange / Uber Green/ Uber Blue/ Uber Black ![]() 20% off Uber Microfiber Products as well! Uber No Name Towels ![]() Uber Classics ![]() Uber Glass ![]() Uber All Purpose ![]() Uber Microfiber Applicator Pads ![]() But wait there's more We will do $9.95 flat shipping on orders over $100.00! Start Date: Now End Date: Nov 8, 2009 The all important code: UBER |
#1478 |
Member#: 165558
Tri-State
As the title states on this one this was one pretty trashed Bentley, for the most part I wasn't expecting anything this bad. The customer wanted it fixed and didn't really mind how long it took or how much. Again we couldn't believe how bad it was, until we saw it in the direct sunlight.
We did the normal prep work, wash, wheels, clay, etc. For the paint correction we enrolled Menzerna Power Gloss Compound with an Uber Yellow Pad, followed by Menzerna Super Intensive Polish with an Uber Green Pad, finally we finished with my favorite Menzerna PO85RD. As a last step we gave it a coat of Swissvax Divine. Enjoy! Products Used: Exterior: Einszett Blitz in the Cam Spray Foam Canon Adam's Gray Clay Bar [/url]and Optimum Instant Detail Spray and Gloss Enhancer for clay lube Menzerna Power Gloss Compoune Menzerna Super Intensive Menzerna PO85RD Menzerna Top Inspection Swissvax Divine Einszett Spray Wax Wheels and Tires Uber Wheel/Tire/Wheel Well Kit Tools: Infratech 5300 Fenix TK11 3M Sun Gun Brinkmann MaxFire Metabo PE12-175 Flex 3403 Makita 9227 Hi Speed Rotary The Uber Foam Pads (5.5inch) Tons of "Uber" Microfiber Towels Uber Drying Towels Cam Spray 1500A with Cam Spray Foam Gun Let's start with some before shots in the direct sunlight at drop off. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#1479 |
Member#: 165558
Tri-State
Removing Plates
![]() Pre soak with Einszett Blitz (bug and tar) ![]() ![]() ![]() Before shot of the wheel ![]() ![]() Ace Powerstick used to clean up the inner wheels ![]() ![]() ![]() |
#1480 |
Member#: 165558
Tri-State
Washing off the Blitz
![]() Washing the car ![]() ![]() Clay ![]() Tommy claying the Bentley ![]() Wheels all cleaned up ![]() Tommy rinsing up the car after the clay ![]() After shot of the wash and clay, massive paint correction ahead of us ![]() Dan on the Metabo with an Uber Green Pad and SIP ![]() |
#1481 |
Member#: 165558
Tri-State
50/50 shots after the 3 steps!
![]() ![]() ![]() Spot checking with the Fenix ![]() Then checking the car again outside ![]() Finishing out with Menzerna PO85RD ![]() |
#1482 |
Member#: 165558
Tri-State
Tommy pulling off the masking off the windows and trim
![]() ![]() Swissvax Divine ![]() After shots ![]() |
#1483 |
Member#: 165558
Tri-State
#1484 |
Member#: 165558
Tri-State
#1485 |
Member#: 165558
Tri-State
#1486 |
Member#: 165558
Tri-State
#1487 |
Member#: 123057
NESIC
Vehicle:04 WRX blue Volk CE28N and Cusco lip |
Looks fantastic Phil! Question? I noticed you have been using your yellow foam compound pad more and not your orange mid. polish as much, any reason or just playing around? Also how was the SIP with the green pad?
Thanks, Ian |
#1488 |
Member#: 165558
Tri-State
i used the yellow as it has great cut for compounding and for sip as well it finishes down very nicely.
#1489 |
Member#: 174338
Phil,
How many hours did u have in the paint correction on the Bentley? Also, What is the biggest difference between the menzerna 203 and the SIP? what would u suggest to use for the medium polish for darker colored cars? I see u use SIP with the green pad quite often... what pad would u use with the 203 and what would the benefit be for either one? thanks a million. |
#1490 | |
Member#: 165558
Tri-State
PO203 has less cut than SIP. As for the Bentley I think it was 12 hours exterior only. |
#1491 |
Member#: 219756
Tri-State
Vehicle:07 2.5i |
Question, someone hit my car with eaither a shopping cart or their car and put a few scratches in the door. It's not too bad and doesn't look to deep.
What would you recommend to try and remove them? |
#1492 |
Member#: 165558
Tri-State
#1493 |
Member#: 97449
SCIC
Vehicle:2007 WRX SWP |
So what was the owner's reaction when he saw his Bentley?
#1494 |
Member#: 165558
Tri-State
the owner's jaw dropped!
#1495 |
Member#: 219756
Tri-State
Vehicle:07 2.5i |
#1496 |
Member#: 165558
Tri-State
are you doing this by hand or by machine?
what products do you have on hand? |
#1497 |
Member#: 219756
Tri-State
Vehicle:07 2.5i |
Most likely by hand. I Don't have much, actually just wax haha.
#1498 |
Member#: 221778
i used to detail cars for a body shop and and can wet sand/buff pretty good, i just got an 04 white sti and want to gather a good detailing kit
i need everything , only thing i have is a makita buffer so... what do you recomend car wash soap/wool mit clay bar /quick detailer sealer/compounds/foam pads wax dryng pads/micro fiber? as far as what brand and if im missing something let me kno, ill be purchasing everything from ur site |
#1499 |
Member#: 165558
Tri-State
car wash- if you like suds go with Adam's Car Wash
if not go with Lusso Auto Bath or Einszett Perls Clay bar go with the Uber Clay Bar and Optimum Instant Detail Spray Your going to need polish - I suggest Menzerna IP and MicroPolish Get some Uber Yellow /Green/Blue pads Microfiber Towels Wax- Einszett Glanz - Lusso Oro |
#1500 |
Member#: 165558
Tri-State
