Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 11-02-2009, 12:23 PM   #1
RSblood
Member#: 87778
2000 Impreza "WRSX"
Default Smoke out that back AFTER Boost
Recently installed a Perrin Turbo inlect because my OEM inlet was broken. Had to do some funky rerouting of the PCV/crank case hose. Did it right according to Perrins instructions. Made sure there were no vacuum leaks, all connections were a tight fit.
*I also didn't get tuned for this, because I figured that this small of an upgrade wouldn't affect it. Perrins charts show that the test car was not tuned when adding this part.
Now whenever I hit boost (EWG opens up fully), a cloud of smoke will pour out the back usually 1-2 seconds after lifting off (deceleration). Sometimes the smoke is grey and white, sometimes blue, sometimes a mix of both.
I've heard similar problems where a catch can could be used to solve this problem. Also found that it could be the turbo seals. I have noticed a little coolant laying around the turbo Center section.
Is it possible that this problem could have been caused by adding the Perrin turbo inlet?
I've noticed small issues with the turbo before, but have never found smoke pouring out the back like this before.
How bad is this? Should I avoid boost at all? I've been driving around like a granny because I'm nervous about this, sometimes I'll open it up and hit boost to see if it's still there, and it usually leaves a cloud behind me, I'm sure the driver behind me isnt too happy about this either.
I'm just confused whether it's just bad timing with the turbo being on it's way out, or if it's caused by the new rerouting of the PCV hose.
MODS:
-Custom short ram intake (its fine)
-Perrin Turbo inlet
-Invidia EL headers/up pipe
-VF22 turbo
-Tial 38mm EWG
-Ebay top mount and y pipe
-Grimmspeed EBCS
Any info/help would be great.
Thanks in advance.
-Matt
RSblood is offline   Reply With Quote
Old 11-03-2009, 11:08 AM   #2
RSblood
Member#: 87778
2000 Impreza "WRSX"
Anyone?
It usually only happens at WOT, regardless of RPM I found out this morning.
Old 11-03-2009, 01:05 PM   #3
Aaron'z 2.5RS
Member#: 1026
00' RS/WRX Stg4
Mindless Self Indulgence
Can you reproduce it in the driveway? revving from under the hood?
If so, what's the cloud smell like?? Oil, coolant or fuel?
I'm having a semi-similar issue with my car... semi-similar set-up... My VF22 is on the way out... I can feel shaft play by hand... not good...
I'm over fueling to the point of fouling plugs, and I can't seem to figure it out... but it gives me some wikkid vapors out the back...
Really, it comes down to what you smell out the pipe, that would be where I would start... if it smells like oil, i'd consider the turbo seals, espically considering what you've said about finding coolant.. sounds all turbo related..
Old 11-03-2009, 01:13 PM   #4
sourcandy
Member#: 212410
I was told the other night when I got on it a little I had some white smoke come out my tail pipe. Doesn't happen during driveway revs. I know I have a valve making some noise, figure maybe burning a little oil from that under load?
changed oil yesterday, coolant, new timing belt. (didn't notice any leaks) I'll have to wait for a friend to drive behind me again as I don't notice it from my mirrors.
sourcandy is offline   Reply With Quote
Old 11-03-2009, 01:34 PM   #5
RSblood
Member#: 87778
2000 Impreza "WRSX"
It really only does it under a load (driving). It might burn a little oil If I rev it a lot standing still, but I havent tried that.
It's mainly oil, but sometimes it's a cloud of white smoke (coolant).
It cam through and into the cabin earlier today, a bit of white smoke that smelled pretty bad, but not like oil.
It's kinda a mix of the two, oil and coolant. I've found that it's mainly oil at lower speeds/revs at WOT, and that its more white smoke at higher rpms, WOT.
I'm going to assume it's the turbo, but I'm also worried about other hidden problems that may have the same symptoms...
Old 11-03-2009, 10:32 PM   #6
crash#2
Member#: 112128
2002 wrx
sedona red pearl
go to the dealer and have them clean out you pcv or take it out and take it to them.
crash#2 is online now   Reply With Quote
Old 11-04-2009, 01:02 AM   #7
69subaru360
Member#: 159682
2002 WRX wagon
1969 360
FWIW, I have rerouted the breather hoses installing inlets and it has not caused oil burning problems.
69subaru360 is online now   Reply With Quote
Old 11-04-2009, 11:47 AM   #8
RSblood
Member#: 87778
2000 Impreza "WRSX"
Should I just replace the PCV valve?
The part was pretty cheap to replace when I was NA, I can't imagine it being that much more for a turbo model.
Old 11-04-2009, 12:56 PM   #9
Aaron'z 2.5RS
Member#: 1026
00' RS/WRX Stg4
The PCV shouldn't cause this... you can pull it though, shake it a little, if it rattles/slides smooth, it's fine... it's nothing more than a weight suspended from each end with springs.. under load of vacuum/boost it moves and seals the valve... while not under load the springs out to the "open/center" position, allowing flow past it....
You can clean it with brake cleaner, just let it dry or blow it out before you put it back on the car..
I bet your turbo is going.... I recently dropped my DP and had a look at mine... it's pretty bad..
Old 11-04-2009, 02:42 PM   #10
Nicklz
Member#: 94096
2003 WRX
I always thought if it smoked AFTER boost (as in boost, off throttle then smoke) it was a ring or ringlands? But that should just be blue smoke....
Nicklz is offline   Reply With Quote
Old 11-04-2009, 02:47 PM   #11
RSblood
Member#: 87778
2000 Impreza "WRSX"
It's mainly just blue smoke now?
It changes from day to day.
Old 11-04-2009, 11:09 PM   #12
DriftIt
Member#: 137388
'05 WRX
Cobb AP Stg 2
You might check into the TGV. If that isn't working properly, it's possible to run rich and smoke really bad. Happened to me when I did an up-pipe and accidentally cracked the TGV sensor that sits right in front of the turbo. Does it throw a CEL?
DriftIt is offline   Reply With Quote
Old 11-04-2009, 11:13 PM   #13
woodys77
Member#: 192147
2007 STI EfiLogics
407whp 402wtq fpgreen
like this?
*edit- this isnt my car but i found it on youtube, it seems to be what your talking about.
woodys77 is offline   Reply With Quote
Old 11-05-2009, 12:08 AM   #14
RSblood
Member#: 87778
2000 Impreza "WRSX"
^^^ Dead on
I've noticed smoke rising from the hood also, not sure why?
What was wrong with your car, and what did you do to fix it?
Old 11-06-2009, 12:08 AM   #15
woodys77
Member#: 192147
2007 STI EfiLogics
Originally Posted by RSblood View Post
^^^ Dead on
HAHA no its not my car i just remembered seeing it on you tube and thought of your situation. it says in the notes that he had bad turbo seals.
Old 11-06-2009, 02:35 AM   #16
Nicklz
Member#: 94096
2003 WRX
I could be wrong but I'd bet my last buck that the car in the video (and the OP's car) have a bad ring or ringland.
It's never happened to me but I've always heard it described that way.
Compression test and preferably a leakdown is in order.
Old 11-06-2009, 05:31 AM   #17
relliMmoT
Member#: 206931
2004 WRX WAGON
5MT Stg4 Java Black Pearl
Keep track of your dipstick. Fill it to a certain marked amount PERFECTLY. A week later check it.
Do this the morning after the car sits both times to ensure the oil is at the same settling/temperature to ensure linearity of test conditions.
Do a compression and leakdown test. - If during the leakdown check you lose pressure out of tolerance squirt oil on the piston rings --Your going to have to rig up some way to do this, ensuring you get oil all the way around the ring as your engine is subject to GRAVITY and your piston is a round object on its side (car skewer maybe? haha)- If your leakdown checks better with oil around the piston rings its a bad valve seal.
Open your oil fill cap with the engine running- if its airflow as usual your good.. If you have RAW EXHAUST coming out of the fill tube and oil sputtering up if its baaad then you know your in on some big problems..
Take off your downpipe, is there a lotve oil in it? Turbo seals.
Do you have a catch can- is it full?
Try buying a new gasket for the idle air control value (mounted to the top of the throttle body. Get the gasket (the one thats in there will stretch out as soon as you pull it out). Clean out the idle air control valve while its off.. Gasoline, alcohol, purple power, whatever. Those gasket can easily go bad! They do more often then they should. Its all there is sealing between 1 bar of boiling hot coolant and the constantly changing intake pressures.
Keep searching! I hope you dont have a bad head gasket turbo or ring!
relliMmoT is offline   Reply With Quote
Old 11-07-2009, 12:09 AM   #18
woodys77
Member#: 192147
2007 STI EfiLogics
Do a compression and leakdown test. - If during the leakdown check you lose pressure out of tolerance squirt oil on the piston rings --Your going to have to rig up some way to do this, ensuring you get oil all the way around the ring as your engine is subject to GRAVITY and your piston is a round object on its side (car skewer maybe? haha)- If your leakdown checks better with oil around the piston rings then its worn rings.
fixed
Old 11-07-2009, 02:38 AM   #19
relliMmoT
Member#: 206931
2004 WRX WAGON
Originally Posted by woodys77 View Post
fixed
Brain fart yeeah!
I probably meant to type "if it checks the same with oil around rings its valve seals"
Old 11-09-2009, 02:45 PM   #20
RSblood
Member#: 87778
2000 Impreza "WRSX"
It must be the turbo seals, theres no oil sputtering out of the oil filler neck, just normal suction/breathing? hard to tell. It's fine though.
Tightened the oil return/inlet lines to the turbo, check for all intake leaks, made sure fittings were tight.
There was no sign of oil dripping on the hotside of the turbo, or in the downpipe..? Normal oil in the y-pipe/throttle body, only a little bit, not nearly enough to even make a small cloud of smoke.
Any other ideas? Don't rely have the money to do a full leakdown test/compression test.
Old 11-09-2009, 08:44 PM   #21
Aaron'z 2.5RS
Member#: 1026
00' RS/WRX Stg4
I doubt you would actually SEE oil inside of the DP... Like I said, I recently dropped mine and while it wasn't "wet" with oil, it did feel "greasy"
I would think any liquid oil would quickly burn up..
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 07:59 PM.
