Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 11-01-2009, 01:57 AM   #126
jigga
Member#: 9960
World Rally Blue Pearl
Originally Posted by Richz View Post
Why run negative camber? I would think you want 0-degrees all around for a straight mile. Is it to get the tires to fit with the lower suspension? A little "bite" to save the car from the side-to-side motions?
The goal was probably to reduce rolling resistance by having as little of the tyre in contact with the ground as possible while traveling in a straight line..
jigga is offline   Reply With Quote
Old 11-01-2009, 11:25 AM   #127
beaviscih
Member#: 123362
'98L EJ20G, '04STi -
189mph @ the Texas Mile
Originally Posted by Phatron View Post
i believe he has the power........
Drag is the main component holding the car back. Adding more power to overcome the drag is probably a more difficult solution than making some aero changes because he would need to add a chitload of power. The buggati veyron video is good lesson, they talk about power vs drag starting at 2 minutes. It wasnt in this video, but IIRC it was said in another video that they had to add ~300hp to get from 240-250 mph. But lets say im not remembering that even close to correctly and beavisch would "only" need to add 100hp......thats no simple task on a car that already has a gt40.
When you really look at the different drag equations its quite astonishing how it relates to speed.
"Note that the power needed to push an object through a fluid increases as the cube of the velocity. A car cruising on a highway at 50 mph (80 km/h) may require only 10 horsepower (7.5 kW) to overcome air drag, but that same car at 100 mph (160 km/h) requires 80 hp (60 kW). With a doubling of speed the drag (force) quadruples per the formula. Exerting four times the force over a fixed distance produces four times as much work. At twice the speed the work (resulting in displacement over a fixed distance) is done twice as fast. Since power is the rate of doing work, four times the work done in half the time requires eight times the power."
Now you're cookin with hot grease - thanks for this post. Several of us have had this discussion and came to a similar conclusion. You either add a boatload of power to overcome drag or you look for ways to maximize the power with aeromods. Too much power (e.g. bigger turbo, more aggressive cams, more boost, etc., etc.) risks pushing the car from street / strip use to strip use only. My car is still streetable, albeit there is no way it would pass inspection in a city that is non-attainment for ozone.
Originally Posted by chudlo View Post
Congratulations Bill!!
Thanks Chad.
I've run the same camber setup since switching to the Tic/AST coilovers. I debated about going to 0 degree camber to increase the rubber grabbing the track, but ran out of time and wasn't sure this would help. Friction, resistance, drag...pick your terminology, will increase with the surface area hitting the track. I don't know how much it would help or hurt by minimizing camber, but it's really hard to experiment with the car given the number of times I actually get to run.
beaviscih is offline   Reply With Quote
Old 11-02-2009, 11:31 PM   #128
Full-Race Geoff
Member#: 133386
98 R14, E39
battleship grey
a little OT (and i know he needs aero badly!) but its actually pretty easy for this car to make ~130+whp just turning the boost up and making sure the fuel is there. The turbo is not yet at high boost and there is plenty that can be done to the cams and top end beyond that. If/when they are maxxing out the 4088R, and are ready to bolt-on a bigger turbo thats no problem either the evo thats going 220+ is obviously much more developed than bill's STI, but that level of mph is certainly not an impossibility for a subaru
Full-Race Geoff is offline   Reply With Quote
Old 11-03-2009, 01:55 PM   #129
suby_dude
Member#: 17397
many '02 Rex, 06 STi
WRB, CGM
Congrats Bill! Your car is very impressive After seeing the Full Race kit @ SEMA a couple years ago I've always dreamed of having a GT4088R in my Suby
I'm happy to see the Rota Grid's are working out well for you
-Dan
suby_dude is offline   Reply With Quote
Old 11-03-2009, 02:03 PM   #130
cnstman
Member#: 9548
2004 WRX STi
PSM, 10.741 @ 126.29
Very nice!! Do they give you a 1/2 mile mph?
cnstman is offline   Reply With Quote
Old 11-03-2009, 10:35 PM   #131
beaviscih
Member#: 123362
I hope to meet with Chris at EngineLogics next week and discuss options. While I don't know if I'll do anything before March, I want to at least explore alternatives. Fuel is not a problem...IIRC IDCs were around 80% with plenty of pump capacity as it is set at the lowest flow setting on a very very conservative tune.
-Dan
They worked well. While there are lighter wheels out there, I kept coming back to Rota's because of the price and the fact I've run three different sets at the Mile with no issues.
Old 11-04-2009, 05:28 AM   #132
jamal
Member#: 71875
98 2.5GT
my wheels fit
weight/pressure = contact patch. alignment and width [mostly] only change the shape.
jamal is offline   Reply With Quote
Old 11-05-2009, 11:28 AM   #133
MPS-Dom
Member#: 204421
View Member's Myspace Profile
new rear wing for you bill.
MPS-Dom is offline   Reply With Quote
Old 11-05-2009, 01:33 PM   #134
P20SPD
Member#: 39565
2001 MY00 Uk Wagon
Mica Red
For comparison, this was me driving a Classic shell back in 2006. Full weight, 2.35 engine, gt35/42 hybrid, 560flywheel bhp at 28psi on Dyno Dynamics Rollers, plus 75shot of Nitrous. 10.6 Quarter mile time at 132mph, going on to 194.8mph at 1 mile from a standing start.
http://video.google.co.uk/videoplay?...9131934105870#
P20SPD is offline   Reply With Quote
Old 11-05-2009, 01:46 PM   #135
ScoobKing
Member#: 151420
93 Version 4-3 7/8
Quartz metallic grey son!
I need a towel....=(
ScoobKing is offline   Reply With Quote
Old 11-05-2009, 09:45 PM   #136
quadrozontal_1
Member#: 188312
MY02 WRX w/Version 8
same as the others PSM...
daaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaamn! lol thats movin!!
quadrozontal_1 is offline   Reply With Quote
Old 11-05-2009, 11:22 PM   #137
beaviscih
Member#: 123362
Very nice. Another Subaru did 210mph in a 1.25 standing mile in the UK several years ago, but 194.8 in one mile is very impressive. Any pictures of the car?
Old 11-05-2009, 11:45 PM   #138
Full-Race Geoff
Member#: 133386
98 R14, E39
battleship grey
give me a shout, i have some alternatives to suggest as well
re the wheels, im a huge fan of the enkei rpf-1's, they are really light, very affordable and ultra-strong. worth considering also
Old 11-06-2009, 01:12 AM   #139
texas05sti
Member#: 126242
2005 42r Moneypit
TXIC's most loved
Thanks for the props. I was disappointed you couldn't make it but can't wait till March. Ripler is close and once he gets it dialed in it will be much faster than what he posted this time.
I don't care who does it but one of the Subarus has to break 190 March. I saw Matt Monson is considering March with his TT EZ30, which would be cool and probably pretty fast.
Cheers.
I'm not interested in doing anything in the 190's, I'm going straight for the 200's.
I'm sorry I didn't make it out there too, but work got in the way too much at the end and getting it finished didn't happen, then I didn't get to come out there at all because I was at the lot. Oh well, that's life I guess. I'm tuning mine for pump gas/street duty in a couple weeks. Come February it'll be up at the shop for the c16/water tune.
texas05sti is online now   Reply With Quote
Old 11-06-2009, 01:48 AM   #140
TheRipler
Member#: 34010
04 LandShark STi
Great White Tundra
Originally Posted by texas05sti View Post
I'm not interested in doing anything in the 190's, I'm going straight for the 120.0's.
Fixed.
TheRipler is offline   Reply With Quote
Old 11-06-2009, 12:42 PM   #141
P20SPD
Member#: 39565
2001 MY00 Uk Wagon
Mica Red
Hi
The 210 was done by Andy Forrest in 2005.
The car i did 194.8mph is the grey one here
and looked exactly like this when it did 194.8.
Begining of 2009 we decided to do this to the car http://forums.nasioc.com/forums/show....php?t=1822756
As the car is now some 200kg lighter than when it did 194.8, and also has some 200bhp more, the aim in 2010 is to try and break 200mph over 1km (0.62 mile).
This should be possible, in the right conditions, as the car has done a 9.6 quarter in its current guise at 147, without nitrous. That's 15mph quicker at the quarter than the run in the video.
I would also like to try and break Andy's world record of 210mph, but i dont know if i am brave enough, as i have had a 170mph side wind wobble, which was a mild brown trouser moment!
Steven
Old 11-06-2009, 01:07 PM   #142
texas05sti
Member#: 126242
2005 42r Moneypit
TXIC's most loved
Originally Posted by TheRipler View Post
Fixed.
I hate you.
Old 11-06-2009, 02:32 PM   #143
TheRipler
Member#: 34010
04 LandShark STi
Great White Tundra
I hate you.
Baby steps, Peter. Have to walk before you can run.
Old 11-06-2009, 04:36 PM   #144
sburck
Member#: 191491
2006 Subaru STI
I wonder how much faster it would be without that 8mph head wind
sburck is offline   Reply With Quote
Old 11-07-2009, 10:54 PM   #145
beaviscih
Member#: 123362
I have a set of 17" Enkei RPF-1s on my '98L...I thought about swapping these over - but since the car is for street / strip use I decided to go with a set of 18" that would hopefully give me a little more RPM and still look good on the car after the event.
So I guess you've decided to keep the '05 STi. If so, finish the damn thing and get it out there in March!
Hi
The car i did 194.8mph is the grey one here YouTube- Scooby Shoot Out 2005 Final and looked exactly like this when it did 194.8.
Steven
Thanks for the info - extremely impressive. I can relate to the crosswind bobble... I had to pull the seat fabric from my ass after the last run Friday when the car walked sideways after hitting the brakes (AWD FTW). I didn't read the entire project thread so I may have missed it...what trans / final drive did were you running for the 194.8?
On a separate note, after Andy Forrest's webpage I was fascinated with the best of 3 and 5 race events hosted in the UK - very cool stuff.
Old 11-08-2009, 05:44 PM   #146
Rexxyou
Member#: 110816
GT35 Nitrous, PPG's
Kelford 272's WFC#052
Hey would switching to an 06-07 front end help with the aerodynamics? they look a lot more efficient
Rexxyou is offline   Reply With Quote
Old 11-08-2009, 05:56 PM   #147
armyssoldierboy
Member#: 109424
06 STI
man, i wish i could see all the pics and charts at work what a beast tho!!
armyssoldierboy is offline   Reply With Quote
Old 11-08-2009, 06:01 PM   #148
Rexxyou
Member#: 110816
GT35 Nitrous, PPG's
hahahaha i feel you this nipr sucks
Old 11-08-2009, 06:03 PM   #149
Rexxyou
Member#: 110816
GT35 Nitrous, PPG's
but ill be home in 17 days sucker
Old 11-08-2009, 09:30 PM   #150
Phatron
Member#: 36033
02WR X HTAGreen+Meth
06 STi OG Green + Meth
The front of the car has very little to do with the drag on the car. No matter what u do to the shape of the front the frontal area stays constant, plus the radiator and fmic needing airflow significantly reduces options for reducing drag at the front.
Keeping the flow attached to the rear of the car is the key.
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 08:14 PM.
