#1 |
Member#: 90357
Vehicle:2004 STi - SCCA STU 1993 RX7 - SCCA ASP |
It's going down Nov 21, 2009. Likely the LAST ever PBX rally.
Who's going? http://www.rvscc.com/files/flyerpbx09.pdf |
#2 |
Member#: 24568
Vehicle:1993 Impreza, WRX drive train, Open class |
I'll be there navigating for one of my crew guys whose driving his rex. Great roads, too easy to get lost sometimes in the middle of the barrens. Interesting wandering around the cranberry bogs when you can see other competitors off in the distance. Fun in the evening when it gets dark.
#3 |
Member#: 84916
Vehicle:02 M3 |
ive always wanted to try one of these, however, the part that says "Legal speeds will be used." Does this mean, you have to drive the legal gov posted speed limits, or the rally has its own posted limits?
#4 |
Member#: 166834
Vehicle:02 WRX WRB |
why the last one?
#5 |
Member#: 24568
#6 |
Member#: 24568
I guess you've never run a rally before! No time like the present to start. A TSD rally always tells you what speed you are to 'average' for each instruction. Their statement means that there will be no instructions with speeds that are above the legal speed limit.
#7 |
Member#: 27258
Vehicle:04 TS wagon 98 L wagon |
See you guys there. I'll be in a white 98 L.
#8 |
Member#: 166834
what do you guys think I would need for this. Currently stock lighting and all season tires? Skid plate, more lights, and snows or something needed?
#9 |
Member#: 27258
You will need a co-driver. A calculator and watch would be helpful too. Other than that, you will be fine.
#10 |
Member#: 166834
Those things I have I just dont really know what to expect road wise. I should be able to fab up my skid plate but im not sure if my Hankook v4 es tires will be suited for this.
#11 |
Member#: 24568
Extra lights are the only thing I might consider. This is sand, pine barrens is all sand. So skid plate, while nice, is not a necessity. You're not going to be going fast enough for tires to make a difference. If I had snows, Id' run them. If I didn't, as long as you've got good tread you'll be okay.
#12 |
Member#: 30909
Vehicle:RA East Open Class Champs 07-08-09 |
The back roads in The Pines are really sandy with occasional very soft stretches. If you have a choice of tires, choose wider ones for max flotation thru the soft bits. If it's wet leading up to the rally, get ready for some water splashes too. If rallymaster chooses some of the more remote 2-track roads, be prepared for your car to get some good brush scratches...I learnt this the hard way there with a Hertz rental (fortunately I'd taken out the damage waiver). Don't worry tho, the rally is memorable for good reasons, and following the web of roads back in The Pines will be a blast.
#13 |
Member#: 166834
any suggestions on cheap extra lighting for an 02 sedan with fogs already
#14 |
Member#: 159682
Vehicle:2002 WRX wagon 1969 360 |
Does the entry fill up fast for this? I think we are going enter. We just put a fresh set of snows on Barney the purple 93 Impreza beater, it should be good to go.
#15 |
Member#: 24568
It could, but probably not. What's the limit, 70 cars? I don't remember and am too lazy to look it up. 70 probably won't fill up.
#16 |
Member#: 198098
This is a bucket list event.come and enjoy!It is well attended well run and well organized.Don't care to run?Come along and volunteer!Day time in the pine barrens is tuff,especially the quarry section.Nite time is unreal.
#17 |
Member#: 156443
Vehicle:2004 WRX WRB |
We'll be there in an '04 WRX.
As per prep skids are nice if it's rutted to **** like it was last year. Extra lighting is also a big plus. Hopefully no one will decide to stuff a Jeep off the side of the road this year, and we'll make all of the pre-dinner stages. I took way too many balks last year after getting caught up in the cluster that was the novice class. Every year it's the last year. If they make enough money, I guarantee it won't be the last one ever... |
#18 | |
Member#: 156443
Night time in the Barrens is not unreal, it is a bit more challenging. Unreal is driving at night, in white out conditions in snow up to your head lights on one lane mountain passes whilst trying to stay on time at 45mph. |
#19 | |
Member#: 22365
Vehicle:1995 Imp Coupe & Wag 2000 Impreza Sedan |
![]() Looks like I'll be there in the right seat for my brother. I think we'll be running with a box, if so, it'll be my first time using a box on a TSD (I've always run either the stock or no-odo class). Matt Kennedy www.RockyRoadRacing.com |
#20 |
Member#: 156443
Does that mean we'll be seeing the "new car"? I thought I read on the other board that you were building up a GD chassis.
I've not made Mr Buffum's yet, but have spent enough time running around with Mr Smith and the rest of the FLR folks in lake effect. It's not that uncommon to be in front of the snow plows going up a remote southern tier road. I refuse to run another one of Mr Goddard's events (at least the ones Jon isn't helping with) after the lack luster roads on last years Covered Bridge and the debacle of NEFR's first day this year. At 5 pm you should have in more than 1 mile of stages... We'll be running sans box, I'll be sitting in the silly as well. |
#21 |
Member#: 166834
Im sending my registration tomorrow. Any good sites to get familiar with tsd and tulip directions. It will be the first time for me and my codriver. Thanks
#22 | ||
Member#: 22365
We'll be in street cars at PBX.Quote:
).As for NEFR, I was the stage captain for the stages that were canceled on Friday, and I can tell you that Ted had absolutely nothing to do with it. In fact, Ted has been stepping back from the event more and more each of the past couple of years. The reason the stages were canceled on Friday was because of a mix-up that left us with no ambulance. Although the call to cancel the stages was eventually made by people "above" me, many of the competitors didn't feel safe running the stages without an ambulance, and as a regular competitor myself I agreed with them (so too did a number of other officials who also compete), especially in light of the serious accident that had happened at the RNY Rallysprint just a few weeks earlier. See you there! ![]() Matt |
#23 |
Member#: 90357
looking for a seat for the event if anyone wants to volunteer. My driving/racing resume can be seen here: Hamfist Racing
#24 | |
Member#: 156443
Then do some digging here: http://tsdroadrally.com/ They have a whole section geared toward novice rallyists. Lastly, see if you can pick up a copy of Clint's book: |
#25 |
Member#: 159682
Does anyone know if you have to be an SCCA member to run the PBX? I was about to send in an entry form and wasn't sure.
