#1 |
Member#: 189497
South East
Vehicle:2008 WRX 5 door |
I have looked in the clutch FAQ thread and didnt see anything that will help me. Im planning on replacing my clutch with the ACT modified street and HD pressure plate. I know there is a thread about it on here but I cant find it. I need to know the torque specs and special tools that im going to need. Can someone point me in the right direction? Thanks in advance.
#2 |
Member#: 189497
South East
TTT! None of these all knowing mods know?
#3 |
clutch alignment tool should come with your clutch kit.
factory torque specs should not be used with aftermarket clutch kit. but anyways..clutch bolts should around 35 ft-lbs.. |
#4 |
Member#: 189497
South East
Thanks local suby guy....
#5 |
Member#: 228908
wow great post
#6 |
Member#: 189497
South East
What about bell housing bolts, drive shaft, and trans mount bolts? ANyone know the torque?
#7 |
Member#: 136358
NESIC
Vehicle:2006 WRX Limited Cobb Stage 2 |
Do not quote me on this because these are the torque specs for the older gen02-07 but am sure their close to yours. Just see if you can get a manual
Bell housing(tranny to engine), was 37ft lbs Driveshaft to rear diff I think is like 12 ft lbs(but because it spins I just tapped it with a hammer and called it a day. Putting it in gear will help stop some sping but not a lot) transmission mount is 25 ft lbs Clutch alignment tool should have come in your clutch kit Flywheel my manual said 11ft lbs but that seemed wrong so I did what ACT recommended which I think was 23 ft lbs(says it on the paper right next to the bolt type) Pressure Plate I can't remember anymore. Hope that helps some what. Again try to find a manual for your car as it has everything there. |
