Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 11-02-2009, 02:47 AM   #1
Sir Punk
Member#: 173492
99 RS
BRP
View Member's Myspace Profile
Default losing oil 1qt/1000 miles
I lose about 1qt/1k miles, that it's too much. I just changed that valve cover gasket/spark plug pipes gaskets which were leaking, I know my head gasket it's leaking a bit but there's no trace of oil on my skid plate, or the ground. Also there is no trace of oil in my exhaust. A quart is a lot of fluid not to see where it goes in such a short period of time. I drove 2k miles in 3 days, all highway at speeds between 70-80 and had to add 2qt.
- I changed the PCV valve
- compression test is good 170:170:170:165
- car has 85k, and it's been doing it since I got it at 65k
- I tried Castrol dino 5w30,10w30,10w40 and M1 5w30. same results.
what would be the cause, is there any test I can do to troubleshoot the problem? I am getting a bit desperate. next thing I am gonna try valvoline 10w30, but I doubt that it's Castrol.
Sir Punk is offline   Reply With Quote
Old 11-02-2009, 03:26 AM   #2
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Are you sure it's not the Castrol?
Subarus normally consume a fair bit of oil, and it seems the problem is compounded by the types of oil. I'm not a fan of dino oil, M1 is no longer fully synthetic. M1 is also notorious for having bad shear in Subarus and to be fair are very particular with which engine it works well on.
Oils people recommend on these engines seem to be Amsoil, Shell Rotella, and some other stuff if you search in the maintenance forum.
I personally use Castrol Syntec 0w-30. This is also known as German Castrol, and has consistently had very good UOA on BITOG. Don't let the 0w turn you off, German Castrol is one of the thickest 30 weights out there.
Another problem could be excessive blowby into the crankcase? I personally had little problem with blowby when I switched to German Castrol. All I have in the oil catchcan is a clear liquid that kinda smells like fuel.
formula91 is offline   Reply With Quote
Old 11-02-2009, 11:39 AM   #3
IAmTheSleepySubie
Member#: 204177
2000 OBS
rear main seal maybe
is there any sign of oil at the bottom of the clutch/flywheel plate?
IAmTheSleepySubie is offline   Reply With Quote
Old 11-02-2009, 12:33 PM   #4
bobko
Member#: 64646
1995 Legacy wagon
Green
If it's not dripping anywhere, and ruling out oil in your coolant, it's gotta be going out the tailpipe. Check the spark plugs to see if one or more shows evidence of oil or fouling. It might be oil seals in the cylinder heads, such as those on the valve stems.
I have a 1995 Legacy (2.2 engine) with 200k+ miles, and it uses no oil. I use Walmart 5W-30 synthetic and the car seems to love it.
--Bob
bobko is offline   Reply With Quote
Old 11-02-2009, 01:36 PM   #5
Sir Punk
Member#: 173492
99 RS
BRP
could the blowby be caused party by the headgasket leak? too bad I just bought Valvoline 10w30. next time I'll try either german castrol or rotella T. should I get the dino or synth rotella? I am just a bit skeptical that the oil brand would make such huge difference. worth a shot.
no sign of oil there. the only sign of oil is on the headgasket driver side and if i look from above on the driver side just below the starter where the block sits on the frame, I see a bit of oil residue there.
--Bob
should I post a video/picture of the tailpipe. I don't see any white smoke though. I also just changed the spark plugs and there was oil but that was due to the valve cover gasket, I could check again and see what state they are in right now though. how would I know if there's a sign of fouling?
Old 11-02-2009, 01:46 PM   #6
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
i was loosing oil like you and switched to 5w 40 and it has gotten better. obviously **** seals / cheap rings in the heads. i mean the fact that my spark plug gaskets had a visable leak at 25k wow.
watchunglava is offline   Reply With Quote
Old 11-02-2009, 02:27 PM   #7
bobko
Member#: 64646
1995 Legacy wagon
Green
A fouled spark plug will have black tarry stuff on the electrodes (the metal tip and the curved bit of metal that goes under the tip). Plugs that are not fouled have a thin, hard, gray/white (or maybe a little yellow) on the electrodes. If you see anything black and it's thick enough to scrape off, that's evidence of oil burning in that cylinder. The more oil getting into that cylinder, the thicker the black gunk will be. If it gets too thick, it will foul the plug and cause that cylinder to miss.
I had a car that used a lot of oil (a quart every 500 miles) and the exhaust looked clear. But that had to be where the oil was going.
One other point: If a car is driven aggressively with lots of high-revving and heavy power demands, that will burn more oil. I'm not saying you do that, just that hard driving increases oil consumption. I knew one idiot who got a new high-performance Audi and thrashed the crap out of it for 3,000 miles, until it ran out of oil and engine seized. He couldn't believe a new car could need oil so soon, but three racing events and several trips north of 120 mph will do that to any car. Idiot...
Good luck!
--Bob
Old 11-02-2009, 02:29 PM   #8
jay25RS
Member#: 4273
2006 WRX Sedan
Try some Shell Rotella Synthetic 5w-40. I've gotten great results from my UOA.
jay25RS is offline   Reply With Quote
Old 11-02-2009, 03:53 PM   #9
Matt Monson
Member#: 832
1999 2.5RS, '08 WRX
'73 914 and Bumblebee
What kind of gas mileage did you get on the road trip?
Old 11-02-2009, 05:45 PM   #10
Sir Punk
Member#: 173492
99 RS
BRP
my car was loaded, because I was moving. MPG kept going up at every refill. I think the latest two I was around 30/32 and the very last one around 40 but just because I drove from Reno to San Francisco and there was a lot of downhill from Lake Tahoe, but usually I get around 30-32. why?
Old 11-02-2009, 06:03 PM   #11
chazly413
Member#: 151079
2005 2.5RS RBP
go skins/caps!
Oil lowers your effective octane rating, so if you were consuming a lot through your cylinders, your gas mileage should be somewhat bad, depending on the amount being burned.
chazly413 is online now   Reply With Quote
Old 11-02-2009, 09:30 PM   #12
Sir Punk
Member#: 173492
99 RS
BRP
so I took a couple of pictures. of the tail pipe as well. I haven't cleaned the tail pipe in more than a year. I tried to clean it a bit and it's very hard to get to the shiny part. it looks a bit more brownish in the picture.
The only visible leak is on the driver side, I hope you guys understand where this is. does this look like the rear main seal? the passenger side is rather clean.
is it possible that a headgasket leak can cause so much blowby?
Old 11-03-2009, 12:22 AM   #13
a_k
Member#: 198767
2002 Outback Sport
I am having the same problem. I have a 2002 outback sport with 127k. It does not leak anywhere and has no oil in the coolant, and it goes through at least a quart every 1k. One of my spark plugs looks worse than the others. I switched to 20w50 and it helped. I also noticed that it consumes more when I tow my boat (1200 lbs) and it smokes out the tailpipe near red line. I've just been adding oil and the car runs great with an average of 23mpg. Any ideas?
a_k is offline   Reply With Quote
Old 11-03-2009, 12:23 AM   #14
Back Road Runner
Member#: 60082
2002 Forester
Burning oil evidence on the plug is only black if it's monstrous amounts. Lower amounts turn into white, clumpy deposits.
Couple links for reading spark plugs:
http://www.verrill.com/moto/sellingg...colorchart.htm
http://www.superstreetonline.com/tec...ugs/index.html
Burning oil is due to wear or damage. To lessen the amount burned, you run a thicker oil. Note this does NOT mean going from a 5w30 to a 10w30. At operating temperatures, both of these oils are the same thickness, equivalent to a straight 30 weight oil. The thickness of these only varies when cold when both are quite thick. You instead bump up the "hot" viscosity, stepping from a 5w30 to a 5w40. Consumption will lower. You have the option to even step to a a 5w50 and even a 10w60 if so needed. As well, not all oils are created equal and two 5w40 oils will burn off at different rates despite their raw viscosity is very similar.
Moderate burning of oil typically also comes with blue smoke. Blue smoke at start up = heads and valvetrain. Blue smoke after warmed = piston rings, worn or broken. There can of course be other issues. A leak down test will point to specific issues.
I will note that our engines can burn a lot of oil. I can throw some Mobil 1 or Amsoil 0w30 in and eat 0.5 quart during a rally-x or auto-x. I can run some Mobil 1 0w40 or Rotella or Duragard(local produced) 5w40 normally and not lose more then 0.5 quart over 3k to 5k miles. It does depend on what you do with the car, although wear does play a big part too. I know my engine is moderately worn at 100k miles compared to when I got the car back at 23k miles. It uses about 2x the oil since then and can at times moderately use oil if I'm running an inappropriate viscosity for the conditions (like a 0w30 in the summer under race conditions).
I'll note after my wearing through my current Rotella 5w40 fill, I plan to step to Eneos 0w50 as a year round solution and to promote additional longevity of the engine through the sport use. It's the most broad spectrum solution I'm aware of. A close second is Castrol's 10w60 exclusively used in BMW M cars but isn't the best suited for extremely cold climates.
Old 11-03-2009, 03:30 AM   #15
imprezkid
Member#: 71462
2002 WRX, RS Graphit
Grey Pearl Metallic
I was losing oil at about the same rate, nothing i did would stop it, had some tick in the motor, but no smoke or oil spots that i noticed, i ended up running a 40w towards the end, then one day running down the highway midway through a 1hr40min trip, cruise @ 70 something let go, don't know what it was. Ran it/limped it till it seized enough the starter wouldn't turn it over, went to pop starting at intersections but eventually ran out of steam, so we pushed. Next day went to pick it up, drove it onto the trailer, and then moved it around the yard for a few months till i drove it into the garage and a ej253 went in.
Don't know what the problem with the motor was, believe it started after i accidently ran it low for a bit too long, and haven't taken the motor apart yet to see what came apart, still has compression so who knows..but man it was knocking bad
imprezkid is offline   Reply With Quote
Old 11-03-2009, 10:52 PM   #16
Sir Punk
Member#: 173492
99 RS
BRP
so after all this talk what should I do first? from what I remember the plugs were ok when I changed them. also I could try another oil. but I am not sure if it's a good idea to switch to synthetic. is there a rotella 10w40 dino?
does anybody have any idea where is leak coming from on that pic I posted? I am almost certain that the headgasket leak only counts for maybe 10% of it. Because at times I left the car sitting for 1-2 months and the oil level was stable. it's gotta be something else.
Old 11-04-2009, 12:18 AM   #17
Rocketjones
Member#: 142754
2005 RS Wagon
I burn 1 quart of oil/tank if I drive 80 miles/hour. Slow down and you will consume way less oil.
Rocketjones is offline   Reply With Quote
Old 11-04-2009, 12:29 AM   #18
GARGOYLE
Member#: 178918
007 STi
OBp
Im no authority,But I filled my library before my garage.
Heres 1 of the things I absorbed.
'' 1 qt of oil goes ''poof''every 1000 miles'',that in fact, is the american petro. institutes' ''normal''
avg ammt. documented to go MIA in between changes for all cars turbos included.
This oil consumption was adopted by,and is now written in stone, for ALL cars passing emissions in this country.NORMAL!
I do not give a rats' testicle if you believe it,agree with it, or wtf ever?...go ask black fang [service writer/ subaru]if you need it repeated from more persons than me.
IMO-It is bull**** for the API to group all the cars for such consumption.No significance between dyno or synthetic considered.Also,I have many other opinions on this loss of oil,but I am in a too bad of a mood to discuss.I need to eat...cary on.
GARGOYLE is offline   Reply With Quote
Old 11-04-2009, 01:29 AM   #19
Back Road Runner
Member#: 60082
2002 Forester
So there ya go.
All I can suggest is try a thicker oil if you want less. If consumption doesn't reduce, then there may be a problem. I think the biggest issue is just normal wear of the engine and staying with a relatively thin oil.
Running low on oil is ALWAYS a bad, bad thing. Don't do it if you know what's good for your engien.
Go order some Eneos 0w50. You live in Minnesota like me, so you really should use an oil well suited for the winter months. A zero base weight will do you good (less wear on start up, quicker pumping and pressure) in the winter. The thicker hot viscosity will keep the oil more readily on its side of the combustion process. Consider it a last attempt. If you burn very little oil, great. If you're engine is still drinking the stuff like water, expect a rebuild or swap in the spring and start saving for it now. If a 50 (hot) weight burns up like water, nothing will save the engine.
By the way, since you're a Minnesotan, head over to www.MNSubaru.com and sign up if you're not already there under a different name. Come say hi. I'll note there are a lot of Subaru guys around you, many happy to help out a fellow Subaru owner. If you need rebuild help or maybe cheap parts, or just some spare hands on the project, ask. Many of us love wrenching on cars, a little more fun if it's not our own. I'm down in the Mankato-Rochester area, but a lot of MNSubaru members are in the Cities and quite a few up in Duluth and well everywhere really. There are meets that happen pretty much weekly at a local Firestone if you want to do some fellow socializing. It's a little out of the way for me, but there are also tons of events we do throughout the year, some small, some rather large. If you're already a member, you know. If you're not, you'll find out.
Old 11-04-2009, 12:51 PM   #20
kay95
Member#: 45494
95 impreza L awd
green
For highway that isnt bad really. Engines burn oil you can stop that unless you dont want to keep the piston oiled. Think about it the cylinder needs oil for the rings and piston to slide on or else it would gald and seize quickly. Well that little bit of oil is exposed to combustion temps and cooks off on each exhaust stroke. Since you where cuising at that speed for a long time you had high EGTs and RPM to contribute to max oil consumption that you saw.
Look at it this way. I went to the track and in 80miles I went through half a quart because I was on it the entire time.
kay95 is offline   Reply With Quote
Old 11-05-2009, 02:14 AM   #21
VIsubi
Member#: 187834
06 2.5i impreza
Red
Shell Rotella is garbage sure good cleaning oil for your engine but royal purple is what I use in everything tranny engine rear diff..no problems and no oil burning like above I love this stuff so much I bought 2 cases sitting in the car garage...
VIsubi is offline   Reply With Quote
Old 11-05-2009, 02:33 AM   #22
a_k
Member#: 198767
2002 Outback Sport
That sounds good but I had a 95 2.0 Passat with 200k before this car and it would not burn a drop of oil between the 5k oil changes...
Old 11-05-2009, 02:30 PM   #23
Sir Punk
Member#: 173492
99 RS
BRP
I went under the car and I noticed the usual leaks. can anybody tell me if this leak is just due to a head gasket? at this point I think that it is a con cause of things: normal oil consumption+minor leak. At this point next time I will try german castrol or that 0w50.
road runner, I am no longer in minnesota, at least for now, so cold start are not an issue, I am in the bay area, I should update my profile here. But yes, I am on mnsubaru as well. I had a chance to work on other people cars and always had fun but never got to a meeting. it's a great community for sure.
I also called Shell and the tech told me that "rotella will accelerate the wear on the cat, because of some chemicals that has in it. He also told me that changing oil might reduce the consumption a bit but not by 1qt/1k miles. He suggested not to switch to synth in my case and to look for the cause somewhere else." so again, this comes from them, rotella is bad for your cat because it is made for diesel engines.
here are the pictures. the head gasket on the passenger side is relatively clean. you can also see oil in the engine mount area and the cross member.
Old 11-05-2009, 02:30 PM   #24
Sir Punk
Member#: 173492
99 RS
BRP
Old 11-06-2009, 02:08 PM   #25
VIsubi
Member#: 187834
06 2.5i impreza
Red
yeah bro thats a head gasket leak and probably your cause of loss of oil reason being is the oil still looks very wet not like grease or gunk from over time..you ca nrun it till your ready to rebuild or take it in and rebuild it now..change your mounts while your at it too. Sorry to say but yeah that looks like a bad leak only to get worse than that...
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 08:57 PM.
