Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 11-03-2009, 10:57 AM   #1
Big_Red
Member#: 189497
2008 WRX 5 door
Default I need direction. Please help.
I have looked in the clutch FAQ thread and didnt see anything that will help me. Im planning on replacing my clutch with the ACT modified street and HD pressure plate. I know there is a thread about it on here but I cant find it. I need to know the torque specs and special tools that im going to need. Can someone point me in the right direction? Thanks in advance.
Big_Red is offline   Reply With Quote
Old 11-03-2009, 05:04 PM   #2
Big_Red
Member#: 189497
2008 WRX 5 door
TTT! None of these all knowing mods know?
Old 11-03-2009, 08:10 PM   #3
jaxscuby
Member#: 10613
blue
clutch alignment tool should come with your clutch kit.
factory torque specs should not be used with aftermarket clutch kit.
but anyways..clutch bolts should around 35 ft-lbs..
Old 11-03-2009, 10:48 PM   #4
Big_Red
Member#: 189497
2008 WRX 5 door
Thanks local suby guy....
Old 11-03-2009, 10:56 PM   #5
Daveed
Member#: 228908
wow great post
Daveed is offline   Reply With Quote
Old 11-04-2009, 11:51 AM   #6
Big_Red
Member#: 189497
2008 WRX 5 door
What about bell housing bolts, drive shaft, and trans mount bolts? ANyone know the torque?
Old 11-04-2009, 12:07 PM   #7
talvai
Member#: 136358
2006 WRX Limited
Cobb Stage 2
Do not quote me on this because these are the torque specs for the older gen02-07 but am sure their close to yours. Just see if you can get a manual
Bell housing(tranny to engine), was 37ft lbs
Driveshaft to rear diff I think is like 12 ft lbs(but because it spins I just tapped it with a hammer and called it a day. Putting it in gear will help stop some sping but not a lot)
transmission mount is 25 ft lbs
Clutch alignment tool should have come in your clutch kit
Flywheel my manual said 11ft lbs but that seemed wrong so I did what ACT recommended which I think was 23 ft lbs(says it on the paper right next to the bolt type)
Pressure Plate I can't remember anymore.
Hope that helps some what. Again try to find a manual for your car as it has everything there.
talvai is online now   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 07:38 PM.
