Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 11-04-2009, 03:52 PM   #1
Franks2308
Member#: 228793
Default HP increase...looking for opinions
Hey guys,
So basically I've been throwing around ideas for my next upgrade on my 02 WRX(already have catback) and I'm not 100% on what I'm going to do. I've heard a lot of good things about COBB APv2's and installing an up/down pipe. The nice thing about this is that I don't need to tune hence the AP. Another idea I had was to just turbo swap to a vf 39 and buy a new tmic, injectors, and a fuel pump. After this I would of course have it tuned. Would the turbo swap decrease engine/tranny life dramatically? Also, is there anything I'm overlooking? Thanks!
Franks2308 is offline   Reply With Quote
Old 11-04-2009, 03:54 PM   #2
Franks2308
Member#: 228793
Also, does anyone know what kind of HP gains would be obtained through a vf39 from TD04 Turbo swap?
Old 11-04-2009, 03:54 PM   #3
Audiosavvy
Antique Roadshow groupie
Member#: 150794
2.3 built bugeye
In it to win it
View Member's Myspace Profile
If your car is stock, a turbo upgrade is way to large of an initial jump.
I would start with an uppipe/turbo-back exaust, and a professional tune. That's a SOLID 25% increase in power at the wheels, with that power coming sooner and staying longer than stock, basically a taller AND fatter powerband, as well as being smoother and getting better mileage.
As to how it's tuned (AP or open-source), that depends on what software your local tuner(s) use.
Fill out your profile please.
Audiosavvy is offline   Reply With Quote
Old 11-04-2009, 04:10 PM   #4
luvless2620
Member#: 190566
MMVI REX
Surfer Silver
+1
What he said, also any large turbo swap can decrease engine/tranny life dramatically, it all depends on its tune and how you drive/abuse it.
luvless2620 is offline   Reply With Quote
Old 11-04-2009, 04:13 PM   #5
rtmccormick
Member#: 216280
2009 WRX 4dr
Originally Posted by luvless2620 View Post
+1
What he said, also any large turbo swap can decrease engine/tranny life dramatically, it all depends on how you drive/abuse it.
truth. the reliability of your car depends heavily on maintenance and the way you drive it. lots of clutch drops and WOT runs every time you leave a stoplight is a great way to blow up any car, regardless of power.
rtmccormick is online now   Reply With Quote
Old 11-04-2009, 04:41 PM   #6
Agkelos
Member#: 58163
2002 Stage 2 WRX
Gut your up pipe, get a used accessport, get a downpipe and midpipe. If that is not enough power for you, then get the VF series or a 16g.
Try out stage two first though, it will likely satisfy you for a few months anyway.
Agkelos is offline   Reply With Quote
Old 11-04-2009, 04:41 PM   #7
Agkelos
Member#: 58163
2002 Stage 2 WRX
double
Old 11-04-2009, 05:14 PM   #8
Franks2308
Member#: 228793
so you guys suggest a professional tune? Are the AP maps not very good or are professional custom tunes that much better? Also, do you know how much a custom tune is?
Old 11-04-2009, 06:00 PM   #9
luvless2620
Member#: 190566
MMVI REX
Surfer Silver
OTS maps are okay but they're not as effective as a protune because unlike an OTS map, it can specifically factor in the many intangibles of your car that an OTS map cannot cuz every car behaves different. A custom tune could range from $350-$500, depending on your relationship with your tuner. However, which ever route you decide to take, both are a cost-effective means to getting an extra "Hmmf!" out of your ride.
Old 11-04-2009, 06:07 PM   #10
leecea
Member#: 37359
2003 WRX (Sedan)
In my opinion, OTS maps are a safe, average tune. A good tuner can do better and a poor tuner can do worse. In fact, a poor tuner can damage your car. So, if you go with a custom tune, make sure you find a good, reliable tuner.
leecea is offline   Reply With Quote
Old 11-04-2009, 09:55 PM   #11
fastwrx25
Member#: 126441
02 bugeye
skip the ap and get a real tune, you'll get better smoother power tuned for YOUR car and mods. Uppipe, full turboback exhaust at a minimum. Intake, inlet, samco tmic hoses, bar plate tmic optional.
don't gut the uppipe...takes too much time and the flow path is still not great. I wouldnt get a flex uppipe.
and don't use mobil1 5w30, change plugs, clean maf sensor if it hasn't been done recently. Do maintenance stuff before you get a tune.
if you on stock suspension......suspension can be just as satisfying or if not more imo.
Old 11-04-2009, 10:26 PM   #12
chazly413
Member#: 151079
2005 2.5RS RBP
go skins/caps!
If your engine is tuned properly and you stay on top of your maintenance, this shouldn't be a problem. Worry more about abusing the car when the engine is cold versus when it's warmed up.
chazly413 is online now   Reply With Quote
Old 11-04-2009, 11:31 PM   #13
Franks2308
Member#: 228793
alright thanks for the opinions guys! I'm going to do some upgrades in the next few weeks...I'll post pics after!
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 08:49 PM.
