Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 11-03-2009, 04:13 PM   #26
albert.vazdom
Member#: 217939
2006 impreza Sti
master power T70
albert.vazdom is offline   Reply With Quote
Old 11-04-2009, 01:07 PM   #27
albert.vazdom
Member#: 217939
2006 impreza Sti
master power T70
does the camshaft sensor have position, I mean there one specific for left and one specific for rigth? of that donīt matter bouth of the camshaft sensors are same and can use in any place ?
thanks
Old 11-04-2009, 01:41 PM   #28
albert.vazdom
Member#: 217939
2006 impreza Sti
master power T70
hummm maybe the immobilizer system???
Old 11-04-2009, 03:58 PM   #29
albert.vazdom
Member#: 217939
2006 impreza Sti
master power T70
Originally Posted by albert.vazdom View Post
I found this haness, this plug to the pcv ...
same problem still...
Old 11-04-2009, 04:17 PM   #30
bannerd
Member#: 110771
2006 WRX
black
Fuse?
Number 11
bannerd is offline   Reply With Quote
Old 11-04-2009, 04:35 PM   #31
albert.vazdom
Member#: 217939
2006 impreza Sti
master power T70
Originally Posted by bannerd View Post
Fuse?
Number 11
which one is that fuse? in the case comes like names, I will take a pic
thanks
Old 11-04-2009, 04:38 PM   #32
Haelan
Member#: 151045
2004 JBP WRX
Stage II - Monster TD04
thanks
Crank and cam sensors have different part numbers and price difference. I don't believe they are interchangeable. You'd have to temporarily swap in a known good sensor in order to rule them out.
Haelan is offline   Reply With Quote
Old 11-04-2009, 04:42 PM   #33
bannerd
Member#: 110771
2006 WRX
black
thanks
Should say eng/ignition on the panel
Old 11-04-2009, 04:58 PM   #34
albert.vazdom
Member#: 217939
2006 impreza Sti
master power T70
Old 11-04-2009, 05:03 PM   #35
albert.vazdom
Member#: 217939
2006 impreza Sti
master power T70
got it, but looks very well, but I will change to see what happend
Old 11-06-2009, 01:31 AM   #36
albert.vazdom
Member#: 217939
2006 impreza Sti
master power T70
Ok! we doit! I do this things and the car now is working!!
1. change camshafts sensors
2. change the fuse 11
3. check and duble check timing belt
4. check sensors and grounds
5. plug everything and clean every sensor and dublecheck all is ok
I donīt know exactly the problem but one of the 5 points have to be the problem
thanks for every opinion and post that was very helpful!
Old 11-06-2009, 10:23 AM   #37
Haelan
Member#: 151045
2004 JBP WRX
Glad it worked out for ya
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 07:45 PM.
