Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 11-06-2009, 01:29 PM   #1
brucers25
Member#: 124242
2000 Impreza 2.5 RS
Sadona Red
Default Whats the.....
Whats the average life of a cadilitic converter ? And if it needs to be replaced will it make the car bog down while trying to accelerate ? I'm not getting any codes. I know, I need a clutch but don't think that would case the car to bog down going down the road.
brucers25 is offline   Reply With Quote
Old 11-06-2009, 01:48 PM   #2
Dirty25RS
Member#: 56731
2004 STi WRB,04 WRX
2010 Volvo C30R-design
a catalytic converter will last a decade or so, or untill you get a bad tune or bag gas and blow a hole in it. It will not cause the car to bog down unles it becomes blocked. If it was blocked you'd notice other things like...lower than regular amount of exhaust coming out the tailpipe.
Your car would most likely throw a code if the cats were bad. It has an 02 sensor that is only there to make sure the cats are working.
Dirty25RS is offline   Reply With Quote
Old 11-06-2009, 01:56 PM   #3
Back Road Runner
Member#: 60082
2002 Forester
When exactly does it bog and under what cases does it and does it not bog?
Old 11-06-2009, 10:47 PM   #4
brucers25
Member#: 124242
2000 Impreza 2.5 RS
Sadona Red
If I just take off it starts to do it,then goes away when i give it more gas. It also does it when I'm going along. I don't notice any sputtering or anything. I give it more gas and it clears up.
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 08:23 AM.
