Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 11-05-2009, 12:12 PM   #1
JDM_OBP
Member#: 105409
05 black
WFC#061 I've made it!!
Default Rusted Lugs
Not sure if this is the right section, but I figured some of you detailers have had experience with rust. I have a set of Project Kics R40 neo chrome lugs that are the open-ended style lugs. As with all open-ended lugs, the inside of the open ended lug has started to rust due to being exposed to all the elements, i.e. rain, sun etc. I just want to know whats a quick fix for this. I only use them with my "nice" set of wheels, so while they're off I want to freshen them up. I've heard of the vinegar method, but I want to see what other techniques are out there. thanks in advance.
And mods feel free to move to right section if need be.
-Will
JDM_OBP is offline   Reply With Quote
Old 11-05-2009, 04:07 PM   #2
pnutbutta
Member#: 192572
2007 Impreza
I'm thinking it's probably just rust stains from your wheel studs. The Kics lugs are going to be made out of aluminum, and as we know, aluminum doesn't rust. I would spray some wd40 on a rag and rug the rag through the lugs. see if that helps.
pnutbutta is offline   Reply With Quote
Old 11-05-2009, 04:16 PM   #3
JDM_OBP
Member#: 105409
05 black
Thanks man I'll give that a shot. Yea I think they're just "stained" from my studs.
Old 11-05-2009, 04:16 PM   #4
ADAS1223
Member#: 159853
2005 concaved cusco
www.subieworld.com
yeah, i was going to say i didnt know of any steel lugs. maybe coat the studs next time you put them on. some grease or paint the ends
ADAS1223 is offline   Reply With Quote
Old 11-05-2009, 04:30 PM   #5
kjgerz
Member#: 121382
'03 wfcrew
carbon bronze pearl'd!
this happened with my r40 lugs too. I tried wd40 once, granted it wasn't a very thorough job since they were still on the car. it definitely helped them though
kjgerz is offline   Reply With Quote
Old 11-05-2009, 05:25 PM   #6
littlewhitewagon
Member#: 103068
06 WRX wagon & 08
MX-5 PRHT GT 6MT
The R40 are made of steel. They can rust, but most likely it is from the studs. Aluminum lugs are not a smart idea for racing, they are only for street. Check race cars, you will never find an aluminum lug nut, they are either steel or titanium.
The kics lugs will benefit from a light coat of a Teflon lubricant everytime you remove them.
All original equipment lug nuts are made of steel except for exotics like the Lambo which has titanium lugs... Superleggera.
littlewhitewagon is offline   Reply With Quote
Old 11-05-2009, 05:40 PM   #7
z28dreams
Member#: 181826
2005 Legacy GT
GRP
I've been using Corrosion Block on anything that might rust - battery terminals, lugs, pretty much anything metal.
Disclaimer: It's actually a marine spray that my parents sell, but lots of people use it on their cars. If anyone wants to check it out let me know and I can probably hook you up w/ a small discount.
z28dreams is offline   Reply With Quote
Old 11-05-2009, 05:40 PM   #8
z28dreams
Member#: 181826
2005 Legacy GT
GRP
mods: please delete, duplicate post for some reason
Last edited by z28dreams; 11-05-2009 at 05:41 PM. Reason: mods: please delete, duplicate post for some reason
Old 11-05-2009, 08:56 PM   #9
JDM_OBP
Member#: 105409
05 black
thanks for the info guys. yea I'm thinking about putting some type of coating on them afterwards. It'd be a pain to redo them after everytime I use them.
Old 11-05-2009, 09:16 PM   #10
littlewhitewagon
Member#: 103068
06 WRX wagon & 08
MX-5 PRHT GT 6MT
It usually not recommended to use anything on the lug nuts because of the heat, splatter, and possibility of not maintaining torque.
Old 11-05-2009, 11:13 PM   #11
pnutbutta
Member#: 192572
2007 Impreza
Originally Posted by littlewhitewagon View Post
It usually not recommended to use anything on the lug nuts for possibility of not maintaining torque.
I've read this many times, and I never put anything on wheel studs, such as lubriants etc., if you think about it, there would be a different torque spec with a liquid present. Which, with open ended lugs, may fling out through the threads and change torque specs, potentially being very unsafe... Good point littlewhitewagon, I just had to elaborate for those who may not think of "why"
Old 11-06-2009, 02:39 AM   #12
kjgerz
Member#: 121382
'03 wfcrew
^yeah good look indeed. never thought of that but it definitely makes sense.
my solution to this problem: I wont be buying open ended lugs again
Old 11-06-2009, 05:35 AM   #13
disaster999
Member#: 73197
anti seize
some will say it will mess up the torque spec, some swears by it.
my friend swears by it and never had a problem...and hes pretty anal about his car.
i guess if its for racing applications, then i wouldnt use it. street shouldnt be a problem
disaster999 is offline   Reply With Quote
Old 11-06-2009, 07:46 AM   #14
09NewfieWRX
Member#: 59036
09 WRX
Originally Posted by disaster999 View Post
anti seize
I've been using anti-seize for over 20 yrs without incident on the lugs, never had a issue and it certainly makes it easier for lug nut removal.
As for the rusted lugs, I use a Dremel with the wire brush attachment to clean off the rust and polish the lugs.
09NewfieWRX is offline   Reply With Quote
Old 11-06-2009, 12:08 PM   #15
littlewhitewagon
Member#: 103068
06 WRX wagon & 08
MX-5 PRHT GT 6MT
Open ended lugs have this issue, it's a fact of life with stock studs. But if you have extended studs, you have no other option since it would make contact with your acorn caps. A quick brush with a soft wire brush is all it takes to clean the studs.
Old 11-07-2009, 12:32 AM   #16
JDM_OBP
Member#: 105409
05 black
yea definitely, no more open ended lugs for me.
I did the wd40 method today and it got most of it off. Will take the dremel and wire brush to it on Sunday and try and get the rest off and polish the insides as well.
Old 11-07-2009, 09:03 PM   #17
pnutbutta
Member#: 192572
2007 Impreza
dremel may ruin your lugs just as a warning. id suggest a fine steel wool to start, if that doesnt work, do whatever, but i dont see a dremel and wire brush being very easy on your finish...
Old 11-08-2009, 04:15 AM   #18
littlewhitewagon
Member#: 103068
06 WRX wagon & 08
MX-5 PRHT GT 6MT
I've never had to use anything other than WD-40 or Tri-Flow to clean and protect my R40s. I never use power tools on my studs or lugs to clean. I only clean my lugs/studs (other than weekly car washes) once a year.
Old 11-08-2009, 11:52 PM   #19
disaster999
Member#: 73197
just slap on some anti seize on it, it will instantly return it to its "silver" color!
Old 11-09-2009, 12:10 AM   #20
ADAS1223
Member#: 159853
2005 concaved cusco
www.subieworld.com
they make endcaps for r40's
Old 11-09-2009, 12:50 AM   #21
kjgerz
Member#: 121382
'03 wfcrew
^just searched and saw that they do now. pretty cool.. of course the caps wont work on the old lugs though
Old 11-10-2009, 01:06 AM   #22
JDM_OBP
Member#: 105409
05 black
would be nice to have endcaps. but don't want to buy another set of R40's. Guess I'll just clean them everytime I take them off
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 07:43 PM.
